Problems implementing ISO 13485 for Software-Only Medical Device Manufacturers?
Marcelo
I know there´s some Covers working for software-only medical device manufacturers (when the manufacturer produces only medical devices which are software).
Have you had any problem when implementing ISO 13485? For example, are there clauses/requirements which might be non-applicable/difficult to implement/weird?
c.mitch
Hello Marcello,
I think you ask this question because the ISO 13485 is going to be updated :)
Software in medical devices is the heart of my job. We had problems when setting up the standard with:
-purchases:the clause 7.4.1 is not easily applicable when your purchase only CD's for production. So we have a purchase procedure but it is not often used.
-production: clause 7.5 and its subclauses, we did an extensive interpretation of these to stick to the problems of deployment of software in heterogeneous environments of our customers.
-post market: clauses 8.x, we did the same interpretation to stick to the #1 problem of soft : bugs, and #2 problem : enhancements. Procedures about change control, NC and CAPA are adapted to software maintenance. They are strongly linked to the problem resolution requirements of IEC 62304.
The best way to implement ISO 13485 to software is to have two senior people: a senior quality manager and a senior soft project manager. The first explains to the last the goals of each clause and they find the way to interpret these clauses to software.
The TR 80002-1 is a guidance on ISO 14971 for software.
We miss the TR xxxxx, the guidance on ISO 13485 for software!
Obrigado
Mitch.
Marcelo
Hello Mitch
Yes, that´s why I´m asking this.
Thanks a lot for your input.
Can i ask you some question to clarify some points?
- 7.4.1 - is it not easily applicable (meaning, you have difficulties applying the requirement) or is the only problem is that the procedure required is not used very often (and thus seems like a document burden, but can be easily implemented)?
- 7.5 - I can understand the problem you have, but not the link to the standard. Which clauses are you referring to? Can you give some example?
- 8.x - yeah, that´s a very interesting point, and it´s a complex interaction. You will really need to make a strong link to IEC 62304. But it isn´t again very clear to me, I don´t in principle see any problems because the general requirements of ISO 13485 can accommodate any other more detailed requirement, for example of IEC 62304 (at least this is the idea). I would say that it does require a lot of work, but not that it is problematic. Or have you noticed something really problematic, meaning, you needed to remove an ISo 13485 requirement due to a requirement of IEC 62304 or something like that?
Again, thanks for all your feedback!
c.mitch
Just a document burden. We seldom use it when we have to sell hardware (like a PC) with our software. For software, the challenge is more in selecting and purchasing the right software development tools and libraries during conception. We use FDA guidances for that.
Indentification and traceability. We don't have the notion of lot or batch, neither the notion traceability of lots. But it's very important to know the versions of software deployed in customers facilities. We interpreted the requirements of identification and traceability with amplified procedures to manage the deployment and traceability of software versions.
Thanks god, no! Doesn't ring a bell, did we miss something? :)
Software activities are disproporsionate, with big conception, tiny production and immense maintenance. So, NC, CAPA and change control really matter. Once again, the real problem is the mental gymnastics to interpret the 13485 requirements in the light of usual problems of software life-cycle.
A TR about implementing 13485 for soft would help, like the TR 80002-1 about 14971 for soft.
Hope it helps.
Mitch.
Marcelo
Thanks again Mitch.
Just as a general comment, in the case of clause 7, ISO 13485 permits that you deem some requirements non-applicable due to the nature of the device:
If any requirement(s) in Clause 7 of this International Standard is (are) not due to the nature of the medical device(s) for which the quality
management system is applied, the organization does not need to include
such a requirement(s) in its quality management system
It´s generally thought that this applies to the requirements to implants/sterile, but in fact it´s for all of Clause 7. Ans software, in my opinion, has a nature in which some of the requirements of clause 7 might not apply (not saying that yours is the case here) 9and yes, you will have a good time arguing with a certification body on that)
I liked the idea of a TR, but I´m not sure there´s enough discussion here to create a whole document.
M Implementing ISO 9001 - Problems - Opposition all around ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
T Organization and personnel problems with quality Other Medical Device and Orthopedic Related Topics 3
J OEM/OBL Problems: Solved by MDCG 2022-7 EU Medical Device Regulations 1
K Ground Bond Test for Class I Medical Electrical Equipment - calibration problems IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Problems with process equipment ISO 13485:2016 - Medical Device Quality Management Systems 4
A Feedback of typical maintenance problems with LMI digital probes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S New problems exporting to Germany - February 2019 ISO 13485:2016 - Medical Device Quality Management Systems 7
C Resource allocation problems in Software DFMEA FMEA and Control Plans 4
R Tapping problems - 3/8" hot roll pickled & oiled steel - seeking expertise Manufacturing and Related Processes 15
Marc Problems - Contacting Us about Problems (How To - Etc.) Elsmar Xenforo Forum Software Instructions and Help 0
Marc Youtube - Viewing problems Elsmar Xenforo Forum Software Instructions and Help 4
O How do reduce the risk of suppliers having similar problems? Supplier Quality Assurance and other Supplier Issues 4
L Problems while documenting the SOUPs used for the software we are developing IEC 62304 - Medical Device Software Life Cycle Processes 4
W Problems with our new Auditor (a Ph.D. with four months experience) ISO 13485:2016 - Medical Device Quality Management Systems 25
L Relying on Suppliers - Most Quality and Warranty problems are caused by Suppliers Supply Chain Security Management Systems 5
M The biggest gaps and problems in QMS or Quality in Automotive Misc. Quality Assurance and Business Systems Related Topics 3
I Request an FDA GUDID Account - Problems Other US Medical Device Regulations 3
S Document Review Problems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L How to avoid Nonconformance Reoccurrence problems IATF 16949 - Automotive Quality Systems Standard 20
C Software Process Implementation Problems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Bottle Labeling Machine Problems - Non conformance in FCMG industry Nonconformance and Corrective Action 8
T Contacting the Supplier's CB vs a Supplier Audit - Nonconformance Problems AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Peter Fraser Problems and Deficiencies with the ISO 9001:2015 Draft ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
B Quality problems that cost Millions of dollars (or euros, or pounds, etc.) Quality Manager and Management Related Issues 7
AnaMariaVR2 How Open Innovation is Solving Some of NASA?s Trickiest Problems World News 0
T A survey on problems during ISMS implementation - need help IEC 27001 - Information Security Management Systems (ISMS) 2
S Common Electric Fan Motor Problems Reliability Analysis - Predictions, Testing and Standards 3
M Problems with Competence/Skills Matrix (6.2 Human Resources) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
ScottK Is anyone else having problems uploading Proprietary Names into the DRLM? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
M FDA Warning Letter - Product Association with Search Engine Results - Problems Ahead? US Food and Drug Administration (FDA) 10
M Problems with Unrealistic Customer Expectations Customer Complaints 12
AnaMariaVR2 Chronic Regulatory Compliance Issues Causing Drug Shortages & Safety Problems Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Q Method on how to cause people to solve problems Benchmarking 5
O Aerospace Registrar Problems - Starting Over? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
M 8.2.4 Problems with Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Problems with Supplier - Always with 100% Sorting - No Corrective Actions Supplier Quality Assurance and other Supplier Issues 22
G Product Returns are above average for Labeling Problems Quality Manager and Management Related Issues 4
V Supplier's First Run had Plating Problems - Can they Strip, Re-Plate and PPAP them? APQP and PPAP 14
1 A New Job - Replaced a QM who passed away - BIG Problems Quality Manager and Management Related Issues 25
N English as a Second Language - English problems with Legal Terms Contract Review Process 2
Uriel Alejandro Problems with the Employee Skills Matrix - Document Control System Quality Manager and Management Related Issues 8
L Avoiding Recurrence of the Supplier?s Quality Problems Supplier Quality Assurance and other Supplier Issues 5
B How can I resolve Chronic Nonconformance Problems? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Problems with the application of EN 62366:2008 IEC 62366 - Medical Device Usability Engineering 13
F Can you tell me if this table is correct? Gage R&R Problems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
D Quality Metrics to use to solve Problems Quality Tools, Improvement and Analysis 5
P Self Motivation - How to keep it when overwhelmed with problems? Career and Occupation Discussions 13
S Systemic Problems Identified in Audit and How to Fix Them IATF 16949 - Automotive Quality Systems Standard 10
T Lollipop Production Line Problems - Defectives and Root Cause Analysis Reliability Analysis - Predictions, Testing and Standards 6
T Big problems with Inspection - Manual Operation - Needs experts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 27
