Problems with Competence/Skills Matrix (6.2 Human Resources)
Mario Alberto83
Hello everybody
Standard says:
Personnel performing work affecting conformity to product requirements shall be competent on the basis of appropriate education, training, skills and experience.
Is it enough to have a competence matrix based on job descriptions? Job descriptions depict job competence requirements (knowledge, skills, experience, etc.) or?do I need to include specific processes in the matrix?
1) Is it enough to say that an operator can perform all machining operations assuming that the operator has general knowledge and experience in CNC machining based on his resume?
2) If previous statement does not suffice...does the operator have to be determined competent based on his skill regarding machining specific processes (WI?s)? (cutting, turning, drilling, milling, part marking, etc.)
I have witnessed in a previous job that auditors look for competence evidence, which is not limited to saying that the operator knows how to machine in CNC but they ask for evidence that he was trained , evaluated and determined competent vs our internal processes (WI?s).
Would the first statement suffice or I should include specific processes in our skills matrix?
I would be grateful for your guidance
Big Jim
There may be more to the picture than shows here, but it would be safe to say that you should have no trouble with your approach.
The standard is not prescriptive as to how you go about it. You get to determine. As long as you have a reasonable explanation as to how you meet the requirements of the standard it is up to you. The auditors you mentioned seem to be going beyond the scope of the standard (requirement creep).
insect warfare
QA=Question Authority
Agreed. I would like to throw in that (unless the company or its interested parties imposed their own requirements for this) training is only one way to achieve competency, therefore it is only one of the inputs that gets transformed to the desired output of competence. Misinformed or misguided auditors too often want to see "training records" first before checking up on if it's even required for that particular activity (particularly because most companies do utilize training records to some degree), which is assumed as safe hunting grounds for most of these auditors.
And training does not always assure competence, since it does not have the same effect on everyone. Observation of one's activities is usually the most effective method of assessing their competence. If I saw your CNC machinist doing his/her job effectively, I wouldn't question their competence at all.
Brian :rolleyes:
K
kgott
Observation of one's activities is usually the most effective method of assessing their competence. If I saw your CNC machinist doing his/her job effectively, I wouldn't question their competence at all.:rolleyes:
Just adding to what insect warfare said. Competence can be defined as [FONT=&quot]'Demonstrated ability to apply the knowledge and skills required to perform a task to the required quality and in the required time, in accordance with required safety controls.[/FONT]'
You can determine the competence of a CNC operators by giving him/her a piece of material and a drawing of a finished item showing dimensions and tell them to make it in xyz time to xyz dimensional accuracy following the required safety procedures.
If they can do it then they are competent, simple as that. Record the event just for good measure.
The Almighty Bearing
Our company addressed this issue by implementing training check sheets in addition to our training matrix.
The check sheets are controlled documents that cover job-specific training items - usually non-QMS trainings. When a new employee joins a department their check sheet is filled out by their manager based on prior experience. Next to each training item on the check sheet are a series of columns, and each column denotes a level of understanding/competency. (See the attached example)
The check sheets solved two issues we were experiencing:
1) It provides evidence of employee-specific on the job trainings that have been completed along with their current level of understanding/competency.
2) It reduced the size of our training matrix by rolling multiple job-specific trainings into one training document.
-TAB
K Ground Bond Test for Class I Medical Electrical Equipment - calibration problems IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
K Problems with process equipment ISO 13485:2016 - Medical Device Quality Management Systems 4
A Feedback of typical maintenance problems with LMI digital probes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S New problems exporting to Germany - February 2019 ISO 13485:2016 - Medical Device Quality Management Systems 7
C Resource allocation problems in Software DFMEA FMEA and Control Plans 4
R Tapping problems - 3/8" hot roll pickled & oiled steel - seeking expertise Manufacturing and Related Processes 15
Marc Problems - Contacting Us about Problems (How To - Etc.) Elsmar Xenforo Forum Software Instructions and Help 0
Marc Youtube - Viewing problems Elsmar Xenforo Forum Software Instructions and Help 4
O How do reduce the risk of suppliers having similar problems? Supplier Quality Assurance and other Supplier Issues 4
L Problems while documenting the SOUPs used for the software we are developing IEC 62304 - Medical Device Software Life Cycle Processes 4
W Problems with our new Auditor (a Ph.D. with four months experience) ISO 13485:2016 - Medical Device Quality Management Systems 25
L Relying on Suppliers - Most Quality and Warranty problems are caused by Suppliers Supply Chain Security Management Systems 5
M The biggest gaps and problems in QMS or Quality in Automotive Misc. Quality Assurance and Business Systems Related Topics 3
I Request an FDA GUDID Account - Problems Other US Medical Device Regulations 3
S Document Review Problems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L How to avoid Nonconformance Reoccurrence problems IATF 16949 - Automotive Quality Systems Standard 20
C Software Process Implementation Problems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Bottle Labeling Machine Problems - Non conformance in FCMG industry Nonconformance and Corrective Action 8
T Contacting the Supplier's CB vs a Supplier Audit - Nonconformance Problems AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Peter Fraser Problems and Deficiencies with the ISO 9001:2015 Draft ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
B Quality problems that cost Millions of dollars (or euros, or pounds, etc.) Quality Manager and Management Related Issues 7
AnaMariaVR2 How Open Innovation is Solving Some of NASA?s Trickiest Problems World News 0
T A survey on problems during ISMS implementation - need help IEC 27001 - Information Security Management Systems (ISMS) 2
S Common Electric Fan Motor Problems Reliability Analysis - Predictions, Testing and Standards 3
ScottK Is anyone else having problems uploading Proprietary Names into the DRLM? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
M FDA Warning Letter - Product Association with Search Engine Results - Problems Ahead? US Food and Drug Administration (FDA) 10
M Problems with Unrealistic Customer Expectations Customer Complaints 12
AnaMariaVR2 Chronic Regulatory Compliance Issues Causing Drug Shortages & Safety Problems Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Q Method on how to cause people to solve problems Benchmarking 5
O Aerospace Registrar Problems - Starting Over? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
M 8.2.4 Problems with Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Problems with Supplier - Always with 100% Sorting - No Corrective Actions Supplier Quality Assurance and other Supplier Issues 22
G Product Returns are above average for Labeling Problems Quality Manager and Management Related Issues 4
V Supplier's First Run had Plating Problems - Can they Strip, Re-Plate and PPAP them? APQP and PPAP 14
1 A New Job - Replaced a QM who passed away - BIG Problems Quality Manager and Management Related Issues 25
N English as a Second Language - English problems with Legal Terms Contract Review Process 2
Uriel Alejandro Problems with the Employee Skills Matrix - Document Control System Quality Manager and Management Related Issues 8
L Avoiding Recurrence of the Supplier?s Quality Problems Supplier Quality Assurance and other Supplier Issues 5
M Problems implementing ISO 13485 for Software-Only Medical Device Manufacturers? ISO 13485:2016 - Medical Device Quality Management Systems 4
B How can I resolve Chronic Nonconformance Problems? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Problems with the application of EN 62366:2008 IEC 62366 - Medical Device Usability Engineering 13
F Can you tell me if this table is correct? Gage R&R Problems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
D Quality Metrics to use to solve Problems Quality Tools, Improvement and Analysis 5
P Self Motivation - How to keep it when overwhelmed with problems? Career and Occupation Discussions 13
S Systemic Problems Identified in Audit and How to Fix Them IATF 16949 - Automotive Quality Systems Standard 10
T Lollipop Production Line Problems - Defectives and Root Cause Analysis Reliability Analysis - Predictions, Testing and Standards 6
T Big problems with Inspection - Manual Operation - Needs experts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 27
C Efficient Supplier Development and Problems with Buyers Supplier Quality Assurance and other Supplier Issues 5
V Common Coating Problems in Refinery Manufacturing and Related Processes 1
S What are the common Problems preventing (Gaps) Implementation of ISO 14001? ISO 14001:2015 Specific Discussions 7
