Problems with Unrealistic Customer Expectations
I?m having problems with unrealistic customer expectations and need to be able to properly explain this with supporting formulas/numbers/terminology.
I?ll use one of our midsize chassis for example. It has 363 inspections points on it. It?s a mixture of both cosmetic and mechanical inspections points. We can build anywhere from 40-60 chassis a day. (40 chassis x363 inspections points = 14,520) So at a minimum that?s 14,520 opportunities for an inspector to miss a defect. This is a manual inspection process. Nothing automated. These chassis run down a single production line so we only have one inspector reviewing this.
Whats the correct terminology for describing this antiquated process as being invalid. What formulas should I be using to support and direct us into a better process?
I appreciate the help guys & gals
Mikishots
Re: Unrealistic customer???
I would start be making a study of those 363 inspection points. Are they all considered critical by the customer? Have you conducted a risk analysis on the points themselves (if there is an escape)? Cosmetic inspections can be tough, because invariably they are listed as critical by the customer:D
Once that has been studied, it would make sense to determine if a sampling plan for the non-critical points can be made.
Without more info, that's all I can really offer.
Miki, we previously determined that the labels and required components of the chassis would be the critical points. But as you mentioned, anytime a non-critical defect is identified out in the field, then it becomes critical. Its to the point now where our customer is arguing that all 363 inspection points per chassis are critical.
I just don't expect a human inspector to be 100% succesful
Helmut Jilling
Auditor / Consultant
Try this on them, (but they probably won't get it) -
By definition, if all points are critical, then they are all equal, then none are more critical than the others. Thay are all equally important and normal. Critical only works if there are distinctions between importantance.
For example, imagine if regular inspection points are 1 star, but important ones are two stars. However, over time, all inspection points have become 2 satrs. then they are all equivalent. You must begin to mark some of them as 3 stars to differentiate the important ones. then, eventually, all become 3 stars. This inflation could just creep without end...
Obviously, the customer is not very knowledgable in this regard. All inspections can be deemed important, but it only benefits if the more important oones are indicated as such.
K
KathySmith
The customer is always right even when they are wrong. But you only have so much resource (time and labor) to inspect parts. And I bet maybe just a handful of those features are off and critical and or easy to mess up and all the other features are hard to screw up and okay.
It sounds like you?re in a quality hole that is very hard to get out of. Trust and credibility come to mind when a customer is shot gunning, almost in a punitive fashion. You may need to do a complete first article type inspection, maybe for a handful of parts to regain confidence, working weekends. And you better make sure to fix the features that got this part on the customer's short list, a.s.a.p.!
Then you need partners/support on your side to be the bad cop, a front office spokesman, preferably someone that controls the resources $$$. Quality folks have to relent to money folks, because we are all in business to make money, not the customer?s quality department. The big/bad guy to call up and say, added inspection will cost you or is does not make any sense when the only problem is??. This works unless you have lots of competition ready to steal the business at no notice.
This gives you a little time to get the real problem fixed and better make sure it gets fixed. Just a ?what if? scenario.
......but isn't there a standard or formula that can tell us how accurate we can expect human inspection to be? A formula that dictates if you have X-number of inspection points by Y-number of units will only provide Z-number accuracy....does that makes sense ?
Sorry, there isn't one.
And if your customer can't see the logic of it a formula wouldn't help you anyway...
Mistake proofing, positive process control, maintenance and SPC can help you ensure capability.
bobdoering
Stop X-bar/R Madness!!
Not sure if you want to go there...it is a slippery slope. They may come back and say you need to tighten your process tolerances to accomodate the error you have identified. Then you will be painted into a very, very small corner. You would have been better off just doing the inspections.
K Problems with process equipment ISO 13485:2016 - Medical Device Quality Management Systems 4
A Feedback of typical maintenance problems with LMI digital probes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S New problems exporting to Germany - February 2019 ISO 13485:2016 - Medical Device Quality Management Systems 7
C Resource allocation problems in Software DFMEA FMEA and Control Plans 4
R Tapping problems - 3/8" hot roll pickled & oiled steel - seeking expertise Manufacturing and Related Processes 15
Marc Problems - Contacting Us about Problems (How To - Etc.) Elsmar Xenforo Forum Software Instructions and Help 0
Marc Youtube - Viewing problems Elsmar Xenforo Forum Software Instructions and Help 4
O How do reduce the risk of suppliers having similar problems? Supplier Quality Assurance and other Supplier Issues 4
L Problems while documenting the SOUPs used for the software we are developing IEC 62304 - Medical Device Software Life Cycle Processes 4
W Problems with our new Auditor (a Ph.D. with four months experience) ISO 13485:2016 - Medical Device Quality Management Systems 25
L Relying on Suppliers - Most Quality and Warranty problems are caused by Suppliers Supply Chain Security Management Systems 5
M The biggest gaps and problems in QMS or Quality in Automotive Misc. Quality Assurance and Business Systems Related Topics 3
I Request an FDA GUDID Account - Problems Other US Medical Device Regulations 3
S Document Review Problems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L How to avoid Nonconformance Reoccurrence problems IATF 16949 - Automotive Quality Systems Standard 20
C Software Process Implementation Problems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Bottle Labeling Machine Problems - Non conformance in FCMG industry Nonconformance and Corrective Action 8
T Contacting the Supplier's CB vs a Supplier Audit - Nonconformance Problems AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Peter Fraser Problems and Deficiencies with the ISO 9001:2015 Draft ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
B Quality problems that cost Millions of dollars (or euros, or pounds, etc.) Quality Manager and Management Related Issues 7
AnaMariaVR2 How Open Innovation is Solving Some of NASA?s Trickiest Problems World News 0
T A survey on problems during ISMS implementation - need help IEC 27001 - Information Security Management Systems (ISMS) 2
S Common Electric Fan Motor Problems Reliability Analysis - Predictions, Testing and Standards 3
M Problems with Competence/Skills Matrix (6.2 Human Resources) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
ScottK Is anyone else having problems uploading Proprietary Names into the DRLM? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
M FDA Warning Letter - Product Association with Search Engine Results - Problems Ahead? US Food and Drug Administration (FDA) 10
AnaMariaVR2 Chronic Regulatory Compliance Issues Causing Drug Shortages & Safety Problems Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Q Method on how to cause people to solve problems Benchmarking 5
O Aerospace Registrar Problems - Starting Over? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
M 8.2.4 Problems with Monitoring and Measurement of Product AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Problems with Supplier - Always with 100% Sorting - No Corrective Actions Supplier Quality Assurance and other Supplier Issues 22
G Product Returns are above average for Labeling Problems Quality Manager and Management Related Issues 4
V Supplier's First Run had Plating Problems - Can they Strip, Re-Plate and PPAP them? APQP and PPAP 14
1 A New Job - Replaced a QM who passed away - BIG Problems Quality Manager and Management Related Issues 25
N English as a Second Language - English problems with Legal Terms Contract Review Process 2
Uriel Alejandro Problems with the Employee Skills Matrix - Document Control System Quality Manager and Management Related Issues 8
L Avoiding Recurrence of the Supplier?s Quality Problems Supplier Quality Assurance and other Supplier Issues 5
M Problems implementing ISO 13485 for Software-Only Medical Device Manufacturers? ISO 13485:2016 - Medical Device Quality Management Systems 4
B How can I resolve Chronic Nonconformance Problems? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Problems with the application of EN 62366:2008 IEC 62366 - Medical Device Usability Engineering 13
F Can you tell me if this table is correct? Gage R&R Problems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
D Quality Metrics to use to solve Problems Quality Tools, Improvement and Analysis 5
P Self Motivation - How to keep it when overwhelmed with problems? Career and Occupation Discussions 13
S Systemic Problems Identified in Audit and How to Fix Them IATF 16949 - Automotive Quality Systems Standard 10
T Lollipop Production Line Problems - Defectives and Root Cause Analysis Reliability Analysis - Predictions, Testing and Standards 6
T Big problems with Inspection - Manual Operation - Needs experts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 27
C Efficient Supplier Development and Problems with Buyers Supplier Quality Assurance and other Supplier Issues 5
V Common Coating Problems in Refinery Manufacturing and Related Processes 1
S What are the common Problems preventing (Gaps) Implementation of ISO 14001? ISO 14001:2015 Specific Discussions 7
A Problems in Implementation of ISO 9001 - How to React? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
