Procedure as per TS 16949 - Consultant changed text procedure to flow chart
Martijn
#31
Ha, that used to be my job as a consultant, transforming massive piles of written text into sleek flowcharts. Never ever have I heard an auditor complain about that format, including BVQI, BSI & Lloyds. Lloyds even have a "example procedure format" which is in flowchart form.
:topic:
I was wondering this might be a European thing? There's a lot of more things I read about on these forums concerning "authoritive" auditors prescribing how things should be done, and most of them seem US-based.
back on topic:
The thing with written text is that a lot of times changes are not well thought through. "Let's put in another sentence right here to please the auditor". Flowcharts really depict what happens, and can show open ends/interaction with other procedures much more clearly IMHO. Written text procedures tend to become cluttered and poorly maintained with your average Joe Quality manager.
somerqc
#33
At my very first company, I was one of (if not the) first person in the company to change procedures from written text to flowcharts.
This company had a policy of having others visit plants that were already registered (my plant was 4th of 12) to learn how to construct their system (from a format perspective...not content). After I changed to flowcharts, I had 3 visitors AND the registrar's auditors comment on how much they liked the flowcharts and how much it improved the knowledge of the supervisors and workers. I even received comments from the workers.
Since then, I have been a flowchart guy. I have found that most people are visual people and flowchart "invite" them to read the procedure
:2cents:
John
#34
Wow - what does that mean? Do they expect that flow charts will exist to describe (documented) procedures? Are they saying that if a procedure is undocumented that a flowchart would be a way to document it? Is a flowchart going to fix a poorly written, documented procedure? Who fully accepts the flowchart details? The external auditor? If it doesn't satisfy them, but the organization gets and can demonstrate good results, is that still an NC?
I think what they (SRI) are saying is that each mandated procedure has certain "shalls" built in. Each of those a-h things must be evident in the flow chart. If for example, the flow chart for doc control does not mention docs of external origin, then it would be the same as if a documented procedure did not address the documents of external origin.
#35
I agree, but I share Andy's concern over the extraordinarily poor construction of the explanation. It could be condensed to, "Flowcharts are acceptable as documented procedures so long as they are adequately detailed."
#36
Having given more thought to this discussion I think that maybe the terminology may be confusing.
Basically a procedure is a method of doing something and can be described either in the written word, by flow charts, or a sequence of pictures; any method that gets the job while meeting the requirements.
As noted earlier the key word in the Standard is "documented" which I had earlier mis-stated as "written".
#37
... It could be condensed to, "Flowcharts are acceptable as documented procedures so long as they are adequately detailed."
And there is your misconception. You are assuming that brevity, clarity and conciseness are what are important. :bonk: However, the answers must be written in a way that only the writer knows is being said. That way, the reader has to go back to the writer for clarification (think MORE DOLLARS). Will you ever learn?
#38
You're right, I'm sorry. :tg: Once again I go back to George Orwell and Politics and the English Language, an essay that should be required reading for everyone who writes process documentation. An example from the essay:
I am going to translate a passage of good English into modern English of the worst sort. Here is a well-known verse from Ecclesiastes:
I returned and saw under the sun, that the race is not to the swift, nor the battle to the strong, neither yet bread to the wise, nor yet riches to men of understanding, nor yet favour to men of skill; but time and chance happeneth to them all.
Here it is in modern English:
Objective considerations of contemporary phenomena compel the conclusion that success or failure in competitive activities exhibits no tendency to be commensurate with innate capacity, but that a considerable element of the unpredictable must invariably be taken into account.
Note that the essay was written in 1948, so what Orwell describes as "modern English" doesn't seem to have improved much in sixty years.
#39
A little bit off topic. :topic:
Even though my previous post was meant in humor, we do have a tendency to over write our documentation. We tend to want to make our docs "sound" official or important. And we write things at a much more complex level than they really need. Just as SRI's answer could confuse folks, so could our own documentation. We really need to look at what we write to make sure it is clear, concise and brief.
somerqc
#40
Good point DB,
As I write this (a little break for me), I am condensing a 17 page procedure to 5. Why was it 17? We had a group of people that wouldn't do anything unless it was in the procedure :)mad:). They are now gone and the remainder plus replacements are following the procedure as required - the procedure can be condensed to show critical points and responsibilities.
This is my step in simplifying the documentation yet still communicating the requirements of the procedure.:D
This also points out that sometimes you have to do MORE than you want due to the audience you are writing (documenting?) to.
S The procedure for replicate check in calibration lab as per ISO 17025 General Measurement Device and Calibration Topics 2
S Product Risk Assessment and Management Procedure per API Q1 9th Edition Oil and Gas Industry Standards and Regulations 8
A Shall we raise SCAR/CAR for every defect as per our current procedure? Nonconformance and Corrective Action 4
R Storage Procedure per NQA 1 Storage and Handling Requirements Document Control Systems, Procedures, Forms and Templates 6
A Purchasing Procedure example as per ISO 9001:2008 wanted Document Control Systems, Procedures, Forms and Templates 2
C Software Validation Procedure per FDA requirement Qualification and Validation (including 21 CFR Part 11) 3
D Personnel Training - Per Calibration Procedure or Type of Instrument? General Measurement Device and Calibration Topics 3
E Looking for Chrysler FPSC form per procedure PSSP0106 - From Chrysler 2001 PSO manual Customer and Company Specific Requirements 2
G How to get appropriate procedure per area-where to start? Document Control Systems, Procedures, Forms and Templates 11
B Procedure packs with non-medical devices EU Medical Device Regulations 1
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
J Example of a defined procedure for carrying out Material Review Board (MRB) Manufacturing and Related Processes 0
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
U Procedure pack components EU Medical Device Regulations 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
J Strategy for MDR Regulatory Compliance Procedure ISO 13485:2016 - Medical Device Quality Management Systems 4
A IVD in MDR procedure pack EU Medical Device Regulations 2
G RoHS Procedure REACH and RoHS Conversations 2
John Predmore Configuration Management as a process instead of a procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Change management procedure when 7.3 is not applicable ISO 13485:2016 - Medical Device Quality Management Systems 5
L Sample Procedure from Contract Manufacturer Prospective ISO 14971 - Medical Device Risk Management 1
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
M UDI procedure/ report 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Article 22 Procedure Pack Labelling EU Medical Device Regulations 4
N EU MDR - Applicability Article 22 Systems and Procedure Packs CE Marking (Conformité Européene) / CB Scheme 4
M Example of statement for procedure pack MDR Article 22? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
R Procedure, Frequency and Acceptance Criteria for Replicate, Recalibration, Before-After and Intermediate Checks ISO 17025 related Discussions 8
B FDA-Medical Device Reporting (MDR )procedure compliant with 21CFR section 803 US Food and Drug Administration (FDA) 0
M MDR - Is a formal GSPR Procedure required? EU Medical Device Regulations 20
Moncia Production Planning procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
L Purchasing procedure and workload ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Roles and accountabilities procedure? ISO 13485:2016 - Medical Device Quality Management Systems 9
K Procedure equals a process? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
M EU MDR - RA procedure for EU EU Medical Device Regulations 5
F Procedure for Device End of Life/Obsolescence Other Medical Device and Orthopedic Related Topics 3
A MAH license transfer (medical device registrant) procedure in Indonesia Other US Medical Device Regulations 0
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
J Manufacturing procedure / work instruction depth ISO 13485:2016 - Medical Device Quality Management Systems 12
