Where is common sense when you need it?
Too bad the King of Common Sense, a.k.a Jim Wynne, is absent. Silly Girl, excellent point. Technically, the pundits, ISO "virtuosos", could say that Notes are not part of the requirements. The 1994 edition of ISO 9001, paragraph 4.2.2.b) had this explicit requirement. For some reason, the 2000 doesn't. But like you and others are saying, what would be the reason to document processes and activities via command media if there was no expectation of deployment and enforcement?
Where does it say that the employees have to be alive when clocking in? In absence of a dress code, where does it say that employees must wear clothes? Where does it say that you are expected to answer the phone when it rings or emails?
Do we need a standard that tells us to breathe? Where is common sense?
silly girl said:
Actually NOTE 1, under 4.2.1 states:"Where the term 'documented procedure' is appears within the International Standard, this means that the procedure is established, documented, implemented and maintained."
