Procedure binding even if not required by the standard - Where's the requirement?
W
W. de Jong
#31
As i far as i see it there are more roads that lead to Rome (as far as this is a correct translation) but you get the point. As always there are different views, the real answer lies somewhere in the middle.
But no need to get hostile guys! Relax :gossip:
Douglas E. Purdy
#32
vanputten said:
Hello All:
I disagree with Randy. 4.2.1d and 4.2.3 only describe requirements for having documents and controlling them. These requirements do not say you have to follow them.
I started a thread about this a long time ago. I asked, where in ISO 9001 is there a requirement that procedures have to be followed?
I never learned the answer. I did receive many replys from "tell the employee to follow it or be fired" to response that indicated the question was without merit.
I started the thread becasue I thought it was interesting that ISO 9001 does not have an overt clasue that states something like all documented processes must be followed.
I think mirrorcrax has raised a worthy question.
I agree with Mirrorcrax. I think the 4.1 f) is as close as we will get to such a requirement.
Regards,
Dirk
I appreciate you giving credence to Mirrorcrax's question, but I am a bit confused. A standard requires that you have documents needed by the organization to ensure the effective planning, operation and control of its processes (4.2.1 d) and you are to conduct internal audits to determine whether the quality management system conforms to the planned arrangements ... (8.2.2 a), but you do not have to comply with the procedures because there is no "Shall" stating that you have to comply with the documents? Am I understanding your position correctly?
Thanks,
Doug
Coury Ferguson
Moderator here to help
#33
This is true. But as you can see, there are many positions on this subject, so lets look and the basic interpretations. Sidney from DnV (Well known Registrar), Randy from BsI (A RAB and/or IRCA accredited Auditor for another well known Registrar), and others that have over 15+ years experience in this field (that most likely have been around the bush and been run over by the train), over this discussion.
At anytime, when there are "Shalls" that require procedures or documents, they must be implemented and subject to audit. In addition, anytime a Company develops Procedures (regardless to the minimum of 6 required by ISO9001:2000) they become part of the Business System and therefore, they are required to be followed and are subject to audit. They also become a Legal and binding document.
BadgerMan
#34
Thanks,
Doug
8.2.2
a. conforms to the planned arrangements (see 7.1), to the requirements of this International Standard and to the quality management system requirements established by the organization, and
b. is effectively implemented and maintained.
Aaron Lupo
#35
Let's ask the question, why the he$$ would you take the time to develop and document a procedure/work instruction (or whatever yo wish to call it) if you don't have any intention of following. Do you have that much time on your hands?
Douglas E. Purdy
#36
BadgerMan said:
8.2.2
I appreciate your bold emphasis, but does having the document in the system make it a requirement, and who determines that it is effectively implemented and maintained? If you have to have a "Shall" in order to make a requirement that has to be complied with by a party or organization, then what is the purpose for the standard and who can enforce it?
Thanks,
Doug
Jen Kirley
Quality and Auditing Expert
#37
This gets right to the heart of the matter, doesn't it?
We make procedures because we feel it's important to do things a certain way each time, and/or to provide guidance for learners, and/or to communicate our methods/controls.
If the procedure is impractical, too hard to use, or wrong, it should be revised. While in the approval process it should be reviewed by various people so as to get feedback on things the author didn't consider, and might edit.
If the procedure is outdated or not needed, obsolete the thing and get to what really matters: providing high value, high quality products and services for internal and external customers.
Coury Ferguson
#39
Jennifer,
I agree with you.
The original post was:
mirrorcrax said:
usually organizations have several procedures that exceed ól 9001's requirements with details related to their business, however, which clause do you think says that once a procedure is developed by the organizationit becomes binding even if not required by the standard, i think the closest is 4.1
Jennifer, do you really think that paragraph 4.1 (ISO9001:2000) is where the requirement is? In addition, do you think that even if procedures/work instructions, when written and implemented (even outside of the 6 required) are binding documents?
I think everyone has gotten a little :topic: here, even me.
Randy
#40
To implement means to do...nuff said.
If you disagree get the paperwork (can be obtained from ANSI) and are such a hot shot, join TC176 and start changing what you don't like, or better yet start your own standards producing body and write your own.
However, if you truly believe that procedures that are part of your system documentation are just for eyewash purposes only and you don't have to do them then please don't cry, sling snot and try to appeal to an accreditation body the big fat and nasty NC's that you could potentialy earn from your head up the fanny attitude if you have a system voluntarily subjected to 3rd party audits and registration by accredited organizations.
:2cents:
This is as always my personal opinion
S MDR - System and procedure pack article 22 and all sub processes that apply ISO 13485:2016 - Medical Device Quality Management Systems 0
P Software verification and validation procedure IEC 62304 - Medical Device Software Life Cycle Processes 4
B Procedure packs with non-medical devices EU Medical Device Regulations 1
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
J Example of a defined procedure for carrying out Material Review Board (MRB) Manufacturing and Related Processes 0
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
U Procedure pack components EU Medical Device Regulations 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
J Strategy for MDR Regulatory Compliance Procedure ISO 13485:2016 - Medical Device Quality Management Systems 4
A IVD in MDR procedure pack EU Medical Device Regulations 2
G RoHS Procedure REACH and RoHS Conversations 2
John Predmore Configuration Management as a process instead of a procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Change management procedure when 7.3 is not applicable ISO 13485:2016 - Medical Device Quality Management Systems 5
L Sample Procedure from Contract Manufacturer Prospective ISO 14971 - Medical Device Risk Management 1
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
M UDI procedure/ report 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Article 22 Procedure Pack Labelling EU Medical Device Regulations 4
N EU MDR - Applicability Article 22 Systems and Procedure Packs CE Marking (Conformité Européene) / CB Scheme 4
M Example of statement for procedure pack MDR Article 22? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
R Procedure, Frequency and Acceptance Criteria for Replicate, Recalibration, Before-After and Intermediate Checks ISO 17025 related Discussions 8
B FDA-Medical Device Reporting (MDR )procedure compliant with 21CFR section 803 US Food and Drug Administration (FDA) 0
M MDR - Is a formal GSPR Procedure required? EU Medical Device Regulations 20
Moncia Production Planning procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
L Purchasing procedure and workload ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Roles and accountabilities procedure? ISO 13485:2016 - Medical Device Quality Management Systems 9
K Procedure equals a process? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
M EU MDR - RA procedure for EU EU Medical Device Regulations 5
F Procedure for Device End of Life/Obsolescence Other Medical Device and Orthopedic Related Topics 3
A MAH license transfer (medical device registrant) procedure in Indonesia Other US Medical Device Regulations 0
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
J Manufacturing procedure / work instruction depth ISO 13485:2016 - Medical Device Quality Management Systems 12
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 2
U Product Lifecycle Procedure Guidance Design and Development of Products and Processes 7
V Datron 4707 or 4708 33K, NAVAIR or TB cal procedure General Measurement Device and Calibration Topics 1
R MDR Article 22: Systems and procedure packs Other Medical Device Regulations World-Wide 12
I Containment procedure for parts after a power outage. IATF 16949 - Automotive Quality Systems Standard 1
F ISO 17025:2017 Format for Procedure and Records Document Control Systems, Procedures, Forms and Templates 3
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
