Procedure equals a process?
Kirby
OK EC friends, I'm back.
If you've seen some of my earlier posts you may remember , but here's a bit of history.
In July 2019 I came to a small company that had their first AS9100 certification audit in Jan 2019 (After four months of preparation and with the aid of an SME / consultant that based the QMS on a generic "canned" AS9100 package.). When I came aboard the individual assigned the Quality rep responsibilities had spent much, much more time in the field performing his "old" job (Field Tech) than actually supporting the QMS. Consequently we were < 6 months from our first surveillance audit and had very little to support compliance to the AS requirements. Management mandated that the current rep would no longer be involved in the off-site activities that had kept him from focusing on the QMS, and of course, they hired me to help. I was fortunate to have had 20+ years in a Quality Assurance post with one company, a good part of that time we were AS certified (first a little bit of B, then to C) , but I had been performing in a different role the last few years (since 2015). The QMS that I had managed was developed over years (and I had the advantage of working with the same consultant during the entire time) so a lot of what I learned and facilitated was specific to that company / industry. I really didn't know how much I didn't know until I began this post. We recently completed the surveillance audit and did pretty good.
At any rate when this company submitted the stage 1 information prior to certification, they identified five "Processes" - Management & Support Processes, Customer Management, Design Management, Purchasing / Supplier Management, and Production Management.
However another part of the submission package, titled "Process Identification" came with the following instructions:
" This chart identifies what AS9100/AS9120 requirements are addressed in which processes and helps to assure that all AS9100/AS9120 requirements are addressed in your system. Please ensure that all clauses have been covered and identified to the relevant processes. The processes identified on this table should agree with the processes identified on your process map or in your manual. INSTRUCTIONS: Fill in the table below with the processes identified by your organization in the left hand column and the Process Owner and the procedure/work instruction/flowchart that describes the process and the metric/measure used to determine effectiveness of the process. Then in the right-hand columns place an “x” to indicate the AS9100/AS9120 clauses which are addressed by that process. "
And a table with the following fields 1) Process 2) Process Owner 3) Procedure / flowchart 4) Process Effectiveness Metric, as well as columns for each AS clause, 4.1, 4.2, etc. . The following is an example of how this form was filled-out : First entry - The Quality rep filled in field 1 with "Process : P-400 Organizational Context (Our documented procedure) and nothing in the "Procedure / flowchart" or "Process Effectiveness Metric" fields, then checked the columns for 4.1, 4.2, 4.3, and 4.4 - (these are the AS clauses that this procedure addresses). The same pattern was followed for every one of our procedures ("Process : P-500 Leadership" with 5.1, 5.2, & 5.3 columns "checked') and so on for 29 documented procedures. I'm not sure that this is the intended use for this "form", but I suspect it was not - maybe I'm wrong?
So, to the point of my entry today (Sorry it took so long but I felt like it was important to provide some background.) After I came aboard, one of the things that needed addressed was Internal Audits. I put together a tailored generic "checklist" and conducted and recorded an internal audit pretty much based on departmental responsibilities / clauses (I know...), and it was enough to allow the auditor not to write a finding, although he did note an opportunity for improvement. Now I'd like to schedule process based audits, using the processes noted in paragraph 1, above, but I'm having a hard time communicating this to the Q rep as he is certain that a procedure equals a process. I feel that multiple procedures may support a process, for example our Management and Support Processes process may be supported by our procedure P-400 Organizational Context, and by our procedure P-930 Management Review (just to name a couple) and I plan to use standard AND procedure interview questions.
I may be way off base and I'd sure like to hear what folks in the EC community have to say.
John Broomfield
Process means work while a procedure (documented or not) is the specified way of carrying out the work.
Many of us though do not clearly differentiate between process and procedure, hence the confusion.
Kirby is right in saying that a procedure may describe or specify more than one process.
For example, how many processes are covered by the procedure for managing continual improvement?
For an answer please see Interesting Discussion - What should be changed in the next Edition of ISO 9001? ISO 9001:2023
John Predmore
If a procedure is not a process, what is a procedure
In our system, a process is shown as a system diagram ("turtle"), with inputs, outputs, resources and roles/responsibilities. While there are inputs and outputs, the process is understood to be in continuous operation. In contrast, a procedure is shown as a flowchart with a beginning point and one or more ending points. For example, the process of Control over External Providers has no beginning or end, but the purchasing procedure shows a sequence beginning with a recognized need to buy something and ends with a Purchase Order document.
Golfman25
Get rid of the semantics. It only confuses things. Like your company, we identified 5 or 6 "major" processes. Things like Purchasing, Manufacturing, Management Review/Analysis and the like. Those overarching processes have procedures that make them up. So for example, Purchasing -- big process. But several things go into it such as supplier review, supplier performance monitoring, purchasing, receiving, etc. Like John, we use a turtle diagram for audits which will list the applicable procedures, records, and such to be audited during the process audit of purchasing.
Marc
Hunkered Down for the Duration
John Broomfield
So a process is always a procedure no matter the extent to which is documented?
I think not.
I'm still convinced that process is the work (usually by humans and machines) and procedure is the specified way of doing the work (and, of course, a procedure may not be documented).
Marc
To me it is semantics. To me a procedure is a way of doing something. Doing something is "work". At best the difference is that a procedure describes how certain specific "work" is done (a process). So, let's just say that you win. A "process" is a "thing" which can be described by a procedure/work instruction/flow chart.
The same nuanced scenario can come into play with the term work instructions. I have been in a lot of companies which did not use the term procedure. Their position was they had "work instructions", not "procedures".
A process is nothing more than A > B > C > D > Etc.
Please help me understand what a process is
I also went through this type of semantics issue way back in 1994 when a registrar auditor argued that the company that I was helping could not use flow charts instead of "standard" text procedures. The auditor lost that 'battle'. A flow chart, properly done, can be a procedure.
S Article 22 Procedure Pack Labelling EU Medical Device Regulations 4
N EU MDR - Applicability Article 22 Systems and Procedure Packs CE Marking (Conformité Européene) / CB Scheme 4
M Example of statement for procedure pack MDR Article 22? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
R Procedure, Frequency and Acceptance Criteria for Replicate, Recalibration, Before-After and Intermediate Checks ISO 17025 related Discussions 8
B FDA-Medical Device Reporting (MDR )procedure compliant with 21CFR section 803 US Food and Drug Administration (FDA) 0
M MDR - Is a formal GSPR Procedure required? EU Medical Device Regulations 20
Moncia Production Planning procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
L Purchasing procedure and workload ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Roles and accountabilities procedure? ISO 13485:2016 - Medical Device Quality Management Systems 9
M EU MDR - RA procedure for EU EU Medical Device Regulations 5
F Procedure for Device End of Life/Obsolescence Other Medical Device and Orthopedic Related Topics 3
A MAH license transfer (medical device registrant) procedure in Indonesia Other US Medical Device Regulations 0
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
J Manufacturing procedure / work instruction depth ISO 13485:2016 - Medical Device Quality Management Systems 12
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 2
U Product Lifecycle Procedure Guidance Design and Development of Products and Processes 7
V Datron 4707 or 4708 33K, NAVAIR or TB cal procedure General Measurement Device and Calibration Topics 1
R MDR Article 22: Systems and procedure packs Other Medical Device Regulations World-Wide 12
I Containment procedure for parts after a power outage. IATF 16949 - Automotive Quality Systems Standard 1
F ISO 17025:2017 Format for Procedure and Records Document Control Systems, Procedures, Forms and Templates 3
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
E AS9100 installtion procedure AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
S Procedure on Privacy Policy in the ISO 13485 quality management system ISO 13485:2016 - Medical Device Quality Management Systems 3
K 820.200 Servicing Procedure - Our system (because there is an API involved) is classified as Class 3 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
D Substance of concern (SOC) management procedure wanted Reliability Analysis - Predictions, Testing and Standards 2
M Informational TGA Consultation: Proposed clarification of the regulatory requirements for medical device systems and procedure packs Medical Device and FDA Regulations and Standards News 2
M Different procedure templates for different standards - We have two different management systems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
N Validation procedure, Major NC CAP - Equipment Validation process is not effective ISO 13485:2016 - Medical Device Quality Management Systems 5
T Something between a manual and a procedure? Document Control Systems, Procedures, Forms and Templates 9
R ISO 13485 Software validation procedure and Quality Objectives Monitoring wanted Document Control Systems, Procedures, Forms and Templates 1
L I'm looking for Translation Procedure Guide MEDDEV 2.5/5 Rev.2 (NOT Rev.3) CE Marking (Conformité Européene) / CB Scheme 0
D Risk Assessment Procedure in accordance with ISO 17025:2017 ISO 17025 related Discussions 5
F Internal Audit - Procedure example Internal Auditing 5
J ISO 17025 - Please share a sample procedure for monitoring the validity of results ISO 17025 related Discussions 1
U Own Procedure was not effectively implemented Problem Solving, Root Cause Fault and Failure Analysis 3
M Procedure or Specification For Extending Gages Calibration Calibration Frequency (Interval) 2
A Process Control / Control Charting Procedure Capability, Accuracy and Stability - Processes, Machines, etc. 1
R Real Example of a currently marketed Procedure Pack CE Marking (Conformité Européene) / CB Scheme 1
DuncanGibbons Additive Manufacturing/3D printing for aerospace (certification procedure) AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
A Certification procedure for OEM/PLM collaboration in the medical device industry in the US - Who bears the regulatory responsability? Other US Medical Device Regulations 10
B AS NZS 5131 - Procedure on Concessions with focus on Steel Fabrication Document Control Systems, Procedures, Forms and Templates 0
alonFAI Please share a medical device company NCMR procedure Other Medical Device Related Standards 4
M Informational MDCG 2019-3 Interpretation of Article 54(2)b – Pre- market clinical evaluation consultation procedure with the involvement of expert panels Medical Device and FDA Regulations and Standards News 0
M Scrubbed version of a labeling procedure that is MDR compliant wanted EU Medical Device Regulations 3
J ISO 13485 8.4 Analysis of Data - Procedure example ISO 13485:2016 - Medical Device Quality Management Systems 1
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
Y My mission is to draft a procedure related to ISO 14155 - Good Clinical Investigation Practices Other Medical Device Related Standards 1
S Looking for procedure on UDI (Unique Device Identification) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
