Procedure for Control of Data, Documented & Electronic needed
Riverbend
If anyone has this type of procedure,l I would love to see how you addressed the issue. It is new to me and I have already written & implemented over 200 Procedures & work instructions, this one is a wee bit out of my area of expertise.:truce:
Hello Riverbend.
Yes, this topic has been covered (is that a pun?) and many people have (I'm sure) posted their approach to document controls, including electronic version.
Please feel free to do a search. At the bottom of each thread there are also listed related threads. See what you come up with and feel free to return to this thread if your needs aren't met. We're here to assist!
SteelMaiden
Welcome! As Andy said, there are some related threads at the bottom of the page, there are also documents available through links at the top of the page (post attachments list, more free files). But most of all, instead of relying on what someone else has done, why not start with where you are? How do you control data? Since you ask about "documented and electronic" I am making the assumption that you are talking about things like production data (characteristic measurements etc)? I am sure that you already have some sort of policy for computer back-ups, and also some method of filing paper/hard copy/handwritten information?
Just explain what it is you do already, who is responsible, how often you do it (back-ups), how long you keep it.
Wes Bucey
I think you are in the right church with your question, but perhaps you sat in the wrong pew and can't hear the sermon. In my opinion, you need a good overview of exactly what is possible with "electronic document management" before you can write procedures on actually doing it. The topics listed below this thread may change from time to time as folks add new terms in their posts. Using different permutation of search terms using the advanced search utility here in the Cove can help you get that overview.
Some time back, I wrote a post on this general topic which included this excerpt
Here is a copy of a post I wrote several years ago - most of it is pertinent today.
here's a copy of something I wrote on the ASQ Forum on 9-3-2004:
I know lots about "electronic document management" (EDM) software.
I need a lot more information about the scope of your operation to make a meaningful suggestion.
Make sure you know and understand the difference between "document sharing" and "document management."
Here's a brief summary to start you off:
Document Management Software
Background:
An organization wants to improve efficiency of document management by “grafting” a program over current legacy files and all newly-created files which will provide the following minimum benefits:
a) Ease of Search & Retrieval (on different fields/characteristics)
b) Ensure only the most recent revision is available on standard Search menu
c) Automate the procedure of notifying pertinent parties a document is ready for redlining
d) Maintain an audit trail for the status of documents (released or waiting for checking/approval [and by whom])
e) Allow “full preview” of documents without opening native programs – i.e. AutoCAD documents can be viewed without latest revision of AutoCAD being resident on user’s computer.
f) Permit “group printing” of documents, regardless of native file format.
g) Maintain up to 30 security levels on any document, determining whether user has authority to create, modify, redline, view, print, copy, etc.
How do they work?
The primary feature of Document Control Software is a relational database which manipulates very small files called “metatags”, which relate to certain attributes of documents. Basic attributes are file name, revision level, author, topic, key words, type of file format, etc. which are used for field headings in the database.
By querying the database, a user retrieves a “menu” of documents which meet the search criteria. Self-contained viewing software permits a user to view and print documents, regardless of the native file format. The views can be scrolled, zoomed, and cropped (i.e. user can print an enlarged detail of a document.)
Users who have redline authority can markup documents without invoking the native file program (the redlines are saved as “overlays” in separate files without changing the original document.)
Users who have checking/approval/redline authority can be automatically notified via email when a document is ready for their review. The program will track when and whether the review is completed and maintain an audit trail for “real time” status reports on any or all documents in the review process.
By keying on the attribute “Revision level”, the program can ensure only the most recent, authorized revision is available to most users, reserving authority to view “superseded” documents to special categories of users.
An important consideration in grafting legacy documents into the new system is choosing fields pertinent to the organization. Many documents, like autocad and word documents have features which provide automatic tags (create date, author, department, etc.) [click on "properties" under File in a Word document to get an idea of already available fields.]
The problem is most users write documents which still show "valued customer" as the author because they have never explored the Properties feature.
An expense to consider is going back into each legacy document and adding the meta tags which allow for sorting and retrieval.
I hope this helps - there are many consultants like me who would come in and give your organization background on choosing the best brand for your organization. Caution is "Are they truly independent or do they have bias toward one brand?"-Wes Bucey, Quality Manager
I didn't add in that post that most software programs have web versions, too. In point of fact, the documents "could" be located either on one server or scattered among hundreds or even thousands of hard drives or servers as long as they were connected or accessible via password over a network, a virtual private network, or the internet.
Somewhere else, I wrote
Why not take the entire QMS system paperless? Is your company a public company? Will you ultimately want to include Sarbannes in your thinking?
It appears the toughest part is that you want to go back and include all your legacy data (FAI) as well.
Google "electronic document management" to see some other thoughts on this topic. I hesitate to recommend ANY product by brand name, because the competitive nature of the business is that one company can be hopelessly obsolete in a month or two and another can have a great breakthrough in the same period. Regulatory laws change quickly - a user's current and projected situation in that regard are important factors. Current quantity of documents and projected number of authors and changes are a major factor. Collaboration with suppliers and customers is another big factor.
-Wes Bucey, Quality Manager ___
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
A Process Control / Control Charting Procedure Capability, Accuracy and Stability - Processes, Machines, etc. 1
E Ask for supplier control procedure which conforms to IATF16949 IATF 16949 - Automotive Quality Systems Standard 0
S Question about environmental control - Pest control management procedure ISO 13485:2016 - Medical Device Quality Management Systems 5
A AS9100 Rev D - Procedure for Product Safety & Control of Counterfeit Part (Format) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
H Combined Procedure - Control of Non-conforming Product, Corrective and Preventive Document Control Systems, Procedures, Forms and Templates 14
M I Attached My first Document Control Procedure for your Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Gman2 My Attached Document Control Procedure for your Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C How to document many document control systems with one Document Control Procedure? Document Control Systems, Procedures, Forms and Templates 6
Q Do cut-in ECOs trigger "control of nonconforming product" procedure? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Blood Collection Inventory Control Procedure example wanted Business Continuity & Resiliency Planning (BCRP) 3
E Procedure for Control of the Release of Laboratory Notebooks Other ISO and International Standards and European Regulations 3
L Document Control Procedure - Revision Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C Control of Documents Procedure - Audit Nonconformance Document Control Systems, Procedures, Forms and Templates 30
F Nonconforming Product Procedure vs. Control of Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Quality Control Procedure and Procedure for Evaluating Sub Contractor Document Control Systems, Procedures, Forms and Templates 1
B Document Control Procedure - Please Critique Document Control Systems, Procedures, Forms and Templates 5
J Document Control Procedure for the Construction Industry - Help Document Control Systems, Procedures, Forms and Templates 4
J OHSAS 18001 Clause 4.4.6 Operational Control Example Procedure Occupational Health & Safety Management Standards 9
S Customer Provide Control Procedure & Changes of Products and QMS Control Procedure ISO 13485:2016 - Medical Device Quality Management Systems 5
B Document Control Procedure - Critique Wanted Document Control Systems, Procedures, Forms and Templates 5
D Converting to Electronic Document Control - Procedure Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
J New Procedure - Changes in measurement devices listed on the Control Plan FMEA and Control Plans 1
A Document Control Procedure Change 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K Link between Control of Documents, CPAR & Control of Non-Conforming Product Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Procedure for Control of Nonconforming Materials and Products - Example wanted Nonconformance and Corrective Action 6
J Control of Production Procedure - ISO 9001 Clause 7.5.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Please review and critique our new Document Control Procedure ISO 13485:2016 - Medical Device Quality Management Systems 4
T Control of Production Equipment - Seventh Procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Crusader Local Control Document procedure....define it or not? Document Control Systems, Procedures, Forms and Templates 24
J Document Control Procedure - Review and Feedback Needed Document Control Systems, Procedures, Forms and Templates 9
K ISO 9001 Clause 4.2.4 Control of Records - Documented Procedure help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Are these things really required in a document control procedure? Document Control Systems, Procedures, Forms and Templates 17
Q Document Control Procedure - Too much detail? Document Control Systems, Procedures, Forms and Templates 8
T QSP 4.2.3 Control of Documents Procedure - Content and Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
T Request for a Design Control Procedure or Process Flow for HVAC Design Document Control Systems, Procedures, Forms and Templates 1
C Change Control Plan/Procedure for Slickline/Wireline Services (Oil Field) Quality Manager and Management Related Issues 1
A Design/Change Control Procedure - How to cope with Changes during Development? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 26
K Allergen Control Procedure example and advice wanted Food Safety - ISO 22000, HACCP (21 CFR 120) 2
C Product Safety Control example procedure wanted Document Control Systems, Procedures, Forms and Templates 4
K Must every CCP (Critical Control Point) have a (documented) procedure? Food Safety - ISO 22000, HACCP (21 CFR 120) 4
T Document Control System and Procedure Advice wanted Document Control Systems, Procedures, Forms and Templates 3
S Outdated Document Control Procedure & Upcoming Audit Document Control Systems, Procedures, Forms and Templates 7
J Kindly Review my Control of Non-Conforming Product Procedure Nonconformance and Corrective Action 8
J Feedback on Document Control Procedure Document Control Systems, Procedures, Forms and Templates 20
M Documented Procedure for Control of Nonconforming Product - Electricity Generation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M Procedure for Control and Maintain of Records in each Design Stage 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
