Procedure for Translating User Documentation to comply with MEDDEV 2.5/5
andreiafilipaf
Hi
I want to define a procedure for translating user documentation, and to comply with MEDDEV 2.5/5.
Does anyone have a good receipt for this procedure so that I do not forget about all relevant issues?
Thank you!!!
Andreia
RA Guy
There have been other discussions related to this "requirement" elswhere on this site:
Manual Translation procedure for the translation of our manuals into other languages
I would suggest, the following may be important aspects to consider if you write a formal process:
Supplier management - qualification and monitoring of any translation or translation validation services your company uses
Risk management - when translating labels, focus on the aspects of safe and effective use of the device and consider the user of the device (for example is the device for home use or professional use or both). Durinig product development, can symbols or human factors engineering mitigate risk of a device being used by different language groups?
Validation of translations - most translation service providers, even those that have some specialization in medical technology will not provide the best translations on first pass. This is often due to literal translations of common terms that may have specific meaning when used in the context of your device. It is common to use post transation reviewers who both speak/read the translated language fluently and who are familiar with the technology/medical speciality of the medical device.
Most importantly, don't go to translation until your "native" language labeling has been optimized in terms of risk management and validation. Investing the time in developing concise, effective, easy to use labeling should lower both translation costs and improve the quality of the translations.
Best of luck.
curiousone
HELP! I am trying to find a definitive answer regarding translation. Must all information found on packaging be translated? Our product information can be found either on the packaging or on the product insert. How much of the marketing information must be translated? Do we have to translate all information found on the packaging or insert or just the instructions for use. I would greatly appreciate any and all information.:thanx:
Ronen E
Problem Solver
Moderator
The answers depend on the market(s) you will be selling into (different regulations for different markets). Those would be...?
Ronen E
Problem Solver
Moderator
The European Union mostly.:thanks:
MDD Article 4:
4. Member States may require the information, which must be made available to the user and the patient in accordance with Annex I, point 13, to be in their national language(s) or in another Community language, when a device reaches the final user, regardless of whether it is for professional or other use.
From Annex I, 13.1:
...This information comprises the details on the label and the data in the instructions for use.
As far as practicable and appropriate, the information needed to use the device safely must be set out on the device itself and/or on the packaging for each unit or, where appropriate, on the sales packaging. If individual packaging of each unit is not practicable, the information must be set out in the leaflet supplied with one or more devices...
For more details, as well as specifics about the types of information that are mandatory under this clause (and therefore may be subject to translation requirements) - consult annex I point 13 in its entirety.
Cheers,
Ronen.
c.mitch
For EU, there's a document from the Team-NB.
Have a look at this:
http://www.team-nb.org/index.php?option=com_docman&task=doc_download&gid=946&Itemid=38&lang=en
The document is somewhat old (2008) but I use it this way:
-if a language is mandatory, no need to look further, translate it
-if it's not, go to the official agency of the country to see if things have changed.
Unfortunately, there's no document at the EU level which gives the translation requirements for each country. You have to search in the websites of each country.
Regards.
curiousone
Could you please explain to me what this means: "in red the MS not yet checked".
I thank you for all your help! I was unsure of "what" was all considered labeling. My concern was whether or not we were required to translate all text on the labeling or just the instructions for use.:thanks:
curiousone
I have two questions regarding the use of pictures and/or symbols for instructions for use: If we use pictures to depict the instructions for use, must we also use the statement "Instructions for Use" and then of course have to translate that phrase? Also, is it acceptable to use pictures and/or symbols to depict the IFU's and possibly eliminate the need for verbiage? Of course, I understand the pictures/images must clearly represent the IFU's to eliminate any risks.
I would appreciate any expertise on this matter. I thank you in advance for your help.:thanks:
c.mitch
I would say it depends on the class of your device. If it is class I and VERY simple and its intended use is well-known without possible confusion, you could argue that you meet the essential requirements #13.x, with normalized symbols only.
Regards,
Mitch.
B Procedure packs with non-medical devices EU Medical Device Regulations 1
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
J Example of a defined procedure for carrying out Material Review Board (MRB) Manufacturing and Related Processes 0
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
U Procedure pack components EU Medical Device Regulations 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
J Strategy for MDR Regulatory Compliance Procedure ISO 13485:2016 - Medical Device Quality Management Systems 4
A IVD in MDR procedure pack EU Medical Device Regulations 2
G RoHS Procedure REACH and RoHS Conversations 2
John Predmore Configuration Management as a process instead of a procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Change management procedure when 7.3 is not applicable ISO 13485:2016 - Medical Device Quality Management Systems 5
L Sample Procedure from Contract Manufacturer Prospective ISO 14971 - Medical Device Risk Management 1
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
M UDI procedure/ report 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Article 22 Procedure Pack Labelling EU Medical Device Regulations 4
N EU MDR - Applicability Article 22 Systems and Procedure Packs CE Marking (Conformité Européene) / CB Scheme 4
M Example of statement for procedure pack MDR Article 22? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
R Procedure, Frequency and Acceptance Criteria for Replicate, Recalibration, Before-After and Intermediate Checks ISO 17025 related Discussions 8
B FDA-Medical Device Reporting (MDR )procedure compliant with 21CFR section 803 US Food and Drug Administration (FDA) 0
M MDR - Is a formal GSPR Procedure required? EU Medical Device Regulations 20
Moncia Production Planning procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
L Purchasing procedure and workload ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Roles and accountabilities procedure? ISO 13485:2016 - Medical Device Quality Management Systems 9
K Procedure equals a process? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
M EU MDR - RA procedure for EU EU Medical Device Regulations 5
F Procedure for Device End of Life/Obsolescence Other Medical Device and Orthopedic Related Topics 3
A MAH license transfer (medical device registrant) procedure in Indonesia Other US Medical Device Regulations 0
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
J Manufacturing procedure / work instruction depth ISO 13485:2016 - Medical Device Quality Management Systems 12
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 2
U Product Lifecycle Procedure Guidance Design and Development of Products and Processes 7
V Datron 4707 or 4708 33K, NAVAIR or TB cal procedure General Measurement Device and Calibration Topics 1
R MDR Article 22: Systems and procedure packs Other Medical Device Regulations World-Wide 12
I Containment procedure for parts after a power outage. IATF 16949 - Automotive Quality Systems Standard 1
F ISO 17025:2017 Format for Procedure and Records Document Control Systems, Procedures, Forms and Templates 3
H Statistical Techniques Procedure - What should be included Document Control Systems, Procedures, Forms and Templates 4
E AS9100 installtion procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Procedure on Privacy Policy in the ISO 13485 quality management system ISO 13485:2016 - Medical Device Quality Management Systems 3
