Procedure Numbering - Is there any reason we HAVE to number our procedures?
MarilynJ6354
Is there any reason we HAVE to number our procedures? In the past I have used a database that always assigned a number but what the employee saw was a title. Now the format we are using makes us manually assign a number if we want one and it is entered in the title. We have the document history at the bottom of each document, we have links to referenced documents in both the quality manual and procedures, so is there any real NEED for a number, i.e. QP 4.2, etc.?
CarolX
Re: Procedure Numbering
Hi MarilynJ6354,
There is no requirement for numbering, but many people have a need to do it. I say, if it works for you and you don't need it, eliminate it!
ddunn
You do not have to number. You can use title and date or revision.
An advantage to using numbers is if the title changes you don't loose traceability to the original document. If this information is in your document history then no big deal.
Sleepless
The only reason I used numbering was to make it easier for auditors to see that my Quality Manual is in synch with the standard. Without them, my audit would be much more labor intensive.
tonya07
I have the thrill of straightening out our QM that was orginally done by consultant (and not very well I might add). It seems that the procedures/elements are not numbered correctly.... can you tell me where I can look to assure that the numbering system is correct? I am very new to all of this!
Thanks!
Thanks!
Welcome to the Cove:D
What makes you think things are not numbered correctly? There is no requirement for written procedures and work instructions to be numbered in any particular way (or at all, for that matter), nor does numbering have to be associated with elements of the standard. Your documentation system should be designed in a way that works well for your company.
Likes: db
Let me echo Jim on the howdy :bigwave:
Also, what Jim says it right on. The ISO requirement is that documents "remain...readily identifiable," (4.2.3 e). Exactly HOW you identify them is up to you. Now, if they are numbered in some odd ball fashion that defies logic, then by all means re-number them the way that makes sense. The bottom line, as Jim pointed out, is that is needs to work well for you.
Hi, i'm thinking do you satisfy the standard? And does your auditor agree?
4.2.3 Control of documents
Documents required by the quality management system SHALL be controlled. Records are a special type of document and SHALL be controlled according to the requirements given in 4.2.4.
A documented procedure SHALL be established to define the controls needed
a) to approve documents for adequacy prior to issue,
b) to review and update as necessary and re-approve documents,
c) to ensure that changes and the current revision status of documents are identified,
d) to ensure that relevant versions of applicable documents are available at points of use,
e) to ensure that documents remain legible and readily identifiable,
f) to ensure that documents of external origin are identified and their distribution controlled, and
g) to prevent the unintended use of obsolete documents, and to apply suitable identification to them if they are retained for any purpose.
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
J ECR to ECO to ECN Procedure and numbering system Document Control Systems, Procedures, Forms and Templates 4
S Numbering of Pages in a Revised Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
W Procedure Clause ?Level? Numbering System explanation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Procedure Numbering System suggestions Document Control Systems, Procedures, Forms and Templates 54
N Quality Procedure numbering - Transitioning Document Control Systems, Procedures, Forms and Templates 6
E Procedure Numbering Change? Still the need for maintaining Level 1, 2, 3, documents? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B Procedure packs with non-medical devices EU Medical Device Regulations 1
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
J Example of a defined procedure for carrying out Material Review Board (MRB) Manufacturing and Related Processes 0
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
U Procedure pack components EU Medical Device Regulations 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
J Strategy for MDR Regulatory Compliance Procedure ISO 13485:2016 - Medical Device Quality Management Systems 4
A IVD in MDR procedure pack EU Medical Device Regulations 2
G RoHS Procedure REACH and RoHS Conversations 2
John Predmore Configuration Management as a process instead of a procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Change management procedure when 7.3 is not applicable ISO 13485:2016 - Medical Device Quality Management Systems 5
L Sample Procedure from Contract Manufacturer Prospective ISO 14971 - Medical Device Risk Management 1
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M UDI procedure/ report 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Article 22 Procedure Pack Labelling EU Medical Device Regulations 4
N EU MDR - Applicability Article 22 Systems and Procedure Packs CE Marking (Conformité Européene) / CB Scheme 4
M Example of statement for procedure pack MDR Article 22? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
R Procedure, Frequency and Acceptance Criteria for Replicate, Recalibration, Before-After and Intermediate Checks ISO 17025 related Discussions 8
B FDA-Medical Device Reporting (MDR )procedure compliant with 21CFR section 803 US Food and Drug Administration (FDA) 0
M MDR - Is a formal GSPR Procedure required? EU Medical Device Regulations 20
Moncia Production Planning procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
L Purchasing procedure and workload ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Roles and accountabilities procedure? ISO 13485:2016 - Medical Device Quality Management Systems 9
K Procedure equals a process? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
M EU MDR - RA procedure for EU EU Medical Device Regulations 5
F Procedure for Device End of Life/Obsolescence Other Medical Device and Orthopedic Related Topics 3
A MAH license transfer (medical device registrant) procedure in Indonesia Other US Medical Device Regulations 0
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
J Manufacturing procedure / work instruction depth ISO 13485:2016 - Medical Device Quality Management Systems 12
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 2
U Product Lifecycle Procedure Guidance Design and Development of Products and Processes 7
V Datron 4707 or 4708 33K, NAVAIR or TB cal procedure General Measurement Device and Calibration Topics 1
