Procedure Numbering System suggestions
GStough
#11
Re: Procedure numbering system???
... Once you have chosen, you are more or less stuck with your decision. It can be a real headache to change it later, so take your time.
I can second that, Claes! When I first arrived at my current job, the numbering system was cumbersome and confusing. Shortly after settling into my new job, the doc ctrl clerk and I worked together to develop a simpler and more logical system. The enormous quantity of procedures, work instructions, formulas, specs, etc. in the QMS all must be changed (DCR'd in our case) to reflect the new numbering system. We've been working on this elephant one bite at a time, though, slowly plugging along. We've made much progress, but there are still many more to be revised.
In a previous life, we used a similar system as described by Discordian and it worked well, if a little cumbersome with all the alpha-numeric designations.
P
potdar
#13
How big is your organisation and your documentation?
The documentation requirements are so nicely trimmed today that I find a simple numbering sufficient.
QM - Quality Manual
P99 - Process including Flow Chart / Procedure
W99 - Work Instruction
F99 - Format
If you have a larger volume, our friends have already suggested adding the department / function code.
Coury Ferguson
Moderator here to help
#14
Everyone has provided good suggestions here. It really depends on what works for the Company, for ease of following, and simple understanding.
jmurph01
#16
We use XXY-##
Where XX is the 2 leter department coed, Y is the type of document and then ## is the document number.
QA = quality dept
EN = engineering dept
PR = production
P = procedure
I = instruction
F = form
so and example is QAF-5 which is quality dept. form number 5, or ENI-45 which is engineering work instruction number 45.
jmurph01
#18
How about Arabic numerals like:
1
2
3
4
5
and so on?
Why not just keep it simple and esy to use?
Randy - I agree with trying to keep it simple. I find our system works well due to the large number of documents we are working with. On our network drive there is a folder for documents and then a folder for each department. By puting in department codes, it allows people to find their documents faster. I think for a smaller place, having only a number would work well.
U
Umang Vidyarthi
#19
1
2
3
4
5
and so on?
Yes Randy,I am using simple numericals viz:
1.0
1.1,
1.2.1,1.2.2,....
8.5,
8.5.1,8.5.2,
and it's working fine for me.But there are large organisations whose data is huge,there fore they have to demarcate their data department-wise,hence alpha-numeric system works better for them.Bottom line is,it is the user(OP) who has to decide what he is comfortable with.
Umang:rolleyes:
DaMann
#20
We Use ...
8.2.2 = Measurment and Monitoring Process
8.2.2-C1 = 1st Prodedure under this section
8.2.2-C2 = 2nd Procedure under this section
etc....
8.2.3 = Measuring and Monitoring of Product
8.2.3-C1 = 1st Procedure under this section
8.2.3-C2 = 2nd Procedure under this section
etc....
Makes it easy to know what section a WI is Refering to.
Damann
J ECR to ECO to ECN Procedure and numbering system Document Control Systems, Procedures, Forms and Templates 4
W Procedure Clause ?Level? Numbering System explanation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
S Numbering of Pages in a Revised Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
MarilynJ6354 Procedure Numbering - Is there any reason we HAVE to number our procedures? Document Control Systems, Procedures, Forms and Templates 30
N Quality Procedure numbering - Transitioning Document Control Systems, Procedures, Forms and Templates 6
E Procedure Numbering Change? Still the need for maintaining Level 1, 2, 3, documents? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B Procedure packs with non-medical devices EU Medical Device Regulations 1
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
J Example of a defined procedure for carrying out Material Review Board (MRB) Manufacturing and Related Processes 0
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
U Procedure pack components EU Medical Device Regulations 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
J Strategy for MDR Regulatory Compliance Procedure ISO 13485:2016 - Medical Device Quality Management Systems 4
A IVD in MDR procedure pack EU Medical Device Regulations 2
G RoHS Procedure REACH and RoHS Conversations 2
John Predmore Configuration Management as a process instead of a procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
W Using tailoring guidelines to tailor a QMS procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Change management procedure when 7.3 is not applicable ISO 13485:2016 - Medical Device Quality Management Systems 5
L Sample Procedure from Contract Manufacturer Prospective ISO 14971 - Medical Device Risk Management 1
T Internal Nonconformance procedure thoughts (AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M UDI procedure/ report 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
DuncanGibbons Resources for aiding in procedure, work instruction and manufacturing plan development and management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Article 22 Procedure Pack Labelling EU Medical Device Regulations 4
N EU MDR - Applicability Article 22 Systems and Procedure Packs CE Marking (Conformité Européene) / CB Scheme 4
M Example of statement for procedure pack MDR Article 22? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 0
R Procedure, Frequency and Acceptance Criteria for Replicate, Recalibration, Before-After and Intermediate Checks ISO 17025 related Discussions 8
B FDA-Medical Device Reporting (MDR )procedure compliant with 21CFR section 803 US Food and Drug Administration (FDA) 0
M MDR - Is a formal GSPR Procedure required? EU Medical Device Regulations 20
Moncia Production Planning procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
L Purchasing procedure and workload ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Roles and accountabilities procedure? ISO 13485:2016 - Medical Device Quality Management Systems 9
K Procedure equals a process? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
M EU MDR - RA procedure for EU EU Medical Device Regulations 5
F Procedure for Device End of Life/Obsolescence Other Medical Device and Orthopedic Related Topics 3
A MAH license transfer (medical device registrant) procedure in Indonesia Other US Medical Device Regulations 0
F ISO 13485 8.2.3 Reporting to regulatory authorities: Question regarding a procedure for this clause. ISO 13485:2016 - Medical Device Quality Management Systems 4
J Manufacturing procedure / work instruction depth ISO 13485:2016 - Medical Device Quality Management Systems 12
F Hi friends, can anyone show me an example of a procedure for ISO 13485 6.4.1 Work Environment? ISO 13485:2016 - Medical Device Quality Management Systems 2
U Product Lifecycle Procedure Guidance Design and Development of Products and Processes 7
V Datron 4707 or 4708 33K, NAVAIR or TB cal procedure General Measurement Device and Calibration Topics 1
