Procedure Required for Measuring a Process?
F
FrameReader
Hi everyone.
I'm going to use a Fire Department analogy to frame this question.
Suppose that a fire department has made a commitment to the municipality that it serves that a maximum of 17 minutes will pass between
a) the fire alarm going off in the station
b) the first fire truck arriving at the scene of the fire
I think I'm right to believe that the Fire Department would need a corrective action procedure to deal with those instances when we fail to arrive at the scene of a fire within 17 minutes. We've got that.
I'm unclear, however, as to whether we need to actually define a procedure outlining how we go about measuring our response time.
It seems to me that measuring the response time is a cut & dry affair - basically, we start the clock when the alarm goes off, and we stop it when we arrive at the scene. That's it. Then we hold ourselves accountable for the results.
I'd rather not write a procedure detailing how exactly the response time is measured if I don't have to.
So I'm thinking, wouldn't it be sufficient for the quality manual / quality policy / quality objectives to specify the 17-minute response time, without getting into the details of how we determine when to 'start' and 'stop' the 'response time' clock.
Thank you in advance for your thoughts,
FrameReader
Randy
You've got response time pegged pretty good, I (we) did the same thing 30 years ago with our response time (I was a police officer) and we made money from it with the community.
Your question is whether or not you need to document the method by which response will be measured, as I understand it. Unless there has been some dramatic change in dispatching use what has historically been done and accepted...Note the time of the call being received, note the time that the unit is dispatched, and note the time they state they have arrived. More often than not, even in this day of electronic everything, there is going to be a written log...this is your record. So basically...NO, you already have a procedure that may have been working well for years.
As you noted, any deviation from your planned time of 17 minutes will be addressed by a CA, but have you considered Preventive Actions as well? Your 17 minute time is an objective, but is it realistic based upon your circumstances and is it an actual objective defined by you or is it a requirement defined by others?
A procedure is defined as a specified way to carry out a process. So every process should have a procedure. The question is does the procedure have to be documented? To answer that look at 4.2.1, specifically note 2. If you need the process to be documented to avoid unwanted variation in the process, then NECESSITY requires documentation. If the procesess can be repeated without unwanted variation, then no documentation may be necessary.
Hi everyone.
FrameReader
Without knowing what you mean by "need," (is it terms of conformity to a standard, or just what makes sense) a couple of thoughts come to mind. First, you should be careful about defining absolutes like this because our old friend Murphy is always lurking in the shadows. Better, I think, to define a target of some sort and then measure your continualous ability to meet it. In order to do this, you have to understand the variation in the system, and what the system can reasonably be expected to do.
The other thing is that you're dealing with a measurement system, and in order for measurements to be meaningful, they must be reasonably consistent. This means that everyone who measures must use the same system and method. To define such a method and then not capture it as a written requirement wouldn't make much sense to me.
yodon
I'm reminded of the airlines' measurement for "on time." If I understand correctly, airlines measure "on time" by the time they back away from the gate. The plane could sit on the tarmac for hours and hundreds could miss connectng flights. But if they backed away from the gate at the prescribed time, they were on time.
So from a consumer, that measurement doesn't mean all that much to me. I realize there are a lot of factors that are out of the airlines' hands; but it's not a meaningful metric to me.
Typically, measurement of the process is included in the process description documentation, since it's required to show if the process is performing as planned. As Randy says, it's not necessary to have 'yet another' document.
Hi everyone.
FrameReader
Assuming that this scenario was developed with the intention to apply it to ISO 9001, keep in mind that there are only six topic that require a documented procedure. Determining response time, or for that matter documenting how to monitor your processes is not one of them.
So there probably is no "need" to have a written procedure for this. That doesn't keep you from having one if you think it would be beneficial.
M MDR - Is a formal GSPR Procedure required? EU Medical Device Regulations 21
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Risk Based Thinking - Is a Documented Procedure required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
J Is a Procedure required for Corrective, Preventive, and Non Conformities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Is policy required for each procedure in ISMS ? IEC 27001 - Information Security Management Systems (ISMS) 3
S Labeling & Packaging Procedure required by the state of California ISO 13485:2016 - Medical Device Quality Management Systems 4
S Is it required to upgrade an AS9100 B Procedure Manual to AS9100 Rev. C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J Are these things really required in a document control procedure? Document Control Systems, Procedures, Forms and Templates 17
Q Is a Documented Procedure required for HR (Human Resources) Document Control Systems, Procedures, Forms and Templates 39
J Engineering/Document Change Notice Procedure required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K ISO/TS 16949:2009 Required Processes and Documented Procedure Requirements IATF 16949 - Automotive Quality Systems Standard 11
A What is an Appeals procedure as required by ISO/IEC 17020:1998 Other ISO and International Standards and European Regulations 5
Q Consultation and Communication - Documented Procedure Required? OHSAS 18001 4.4.3 Occupational Health & Safety Management Standards 2
C Monitoring and measurement - 7.6 of ISO 13485 - Documented procedure required? ISO 13485:2016 - Medical Device Quality Management Systems 5
Le Chiffre Is a written procedure required for handling significant change? ISO 13485:2016 - Medical Device Quality Management Systems 7
M Procedure binding even if not required by the standard - Where's the requirement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 59
Stuart Andrews Design Control - Help required with procedure! Design and Development of Products and Processes 3
Raffy Continuous Improvement in ISO 9001:2000 - Separate Procedure Required? Preventive Action and Continuous Improvement 4
B Establishment and Product Registration Procedure - UK & EU UK Medical Device Regulations 0
M Procedure for communication between authorized rep and distributor Other ISO and International Standards and European Regulations 0
M Article 22 - Include statement in procedure pack? EU Medical Device Regulations 1
S Classification of a Sterile Procedure Pack EU Medical Device Regulations 0
A Management of change procedure for ISO 45001 Occupational Health & Safety Management Standards 5
L Product and process Deviation procedure Manufacturing and Related Processes 1
C IVD Metrological traceability without a reference measurement procedure General Measurement Device and Calibration Topics 11
M GP-12 procedure form and requirements Customer and Company Specific Requirements 1
R Procedure pack EU EU Medical Device Regulations 1
B Process / Procedure - Radiographic (X-Ray) Non-Film Document Control Systems, Procedures, Forms and Templates 0
M Procedure for vigilance system according to new MDR EU Medical Device Regulations 0
M Procedure for clinical evaluation according to new MDR EU Medical Device Regulations 10
S Production Work Order Procedure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
E System&Procedure pack or accessory EU Medical Device Regulations 0
K Contract Manufacturer Do they need a complaint procedure? Medical Device and FDA Regulations and Standards News 8
E Design and Development file Procedure ISO 13485:2016 - Medical Device Quality Management Systems 0
B Procedure facility license in karnataka Manufacturing and Related Processes 3
S MDR - System and procedure pack article 22 and all sub processes that apply ISO 13485:2016 - Medical Device Quality Management Systems 0
P Software verification and validation procedure IEC 62304 - Medical Device Software Life Cycle Processes 6
B Procedure packs with non-medical devices EU Medical Device Regulations 1
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
J Example of a defined procedure for carrying out Material Review Board (MRB) Manufacturing and Related Processes 0
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
A SPC procedure / flow chart Statistical Analysis Tools, Techniques and SPC 2
J Action Not defined in procedure - NC - Incoming inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 4
U Procedure pack components EU Medical Device Regulations 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 8
J Strategy for MDR Regulatory Compliance Procedure ISO 13485:2016 - Medical Device Quality Management Systems 4
