Procedure vs. Instruction - What constitutes a procedure? What are the differences?
tomstwincam
I have a question for everyone. If this is in the wrong forum please forgive me. I spend all of my time in the AS9100 forum anyways.
Is their a fine line on what can be called a procedure and what can be called an instruction?
My problem is we have close to 50 procedures here. I recently brought up the argument that some of these are more like work instructions rather then procedures. So what is what?
BadgerMan
Moderator
Re: Procedure vs. Instruction
IMO......no.
So what is what?
Our somewhat antiquated system loosely defines them as:
Procedure – Who does what, when, and where.
Work Instruction – How it is done.
You are doing well.......we have roughly triple that amount! ;)
Randy
This has been debated since the Egyptions built the Pyramids........here's the bottom line.....as long as you and your organization know the difference it doesn't really matter "what the stuff that is written that tells you what to do and how to do it" is called.
Normally....here's where everyone and his brother is going to tell you how to boil water.....normally we see "procedures" providing information covering a broad process or activity and "instructions" providing information related to specific required tasks within the process or activity....
In the end, it doesn't really matter as long as you can use them , they are controlled as required and serve the needs you have.
Caster
An Early Cover
There is also a nasty stink of elitism in these words - I hate 'em
Staff people need only broad direction because they are so smart (procedure)
Factory pukes need detailed work instructions because...well just because
Never mind that the factory guy can run a million dollar CNC lathe, while the director of operations can't book a meeting in Outlook
And don't get me started on policies.....what a waste of paper...just do it already
We need just enough documentation to get the job done, the names I like are method or technique, a bit more neutral.
Randy
Re: Procedure vs. Instruction - What constitutes a procedure? What are the difference
Caster?
Is there some bitterness or frustration here that needs to be discussed?
Big Jim
In ISO 9001:2000 there are only six required procedures. They are defined in 4.2.3, 4.2.4, 8.2.2, 8.3, 8.5.2, and 8.5.3.
It doesn't really matter if these six are call procedures, although it would certainly be more "auditor friendly".
The other "procedures" and/or "work instructions" can be called anything you like, and documentation of them is optional as long as you meet the requirements of 4.2.1d "The quality management system shall include documents needed by the organization to ensure the effective planning, operation and control of its processes . . . "
U
Umang Vidyarthi
Guest
According to my understanding - 'Procedure' is a specified series of action, to be executed in the same manner, to obtain the same result under the same condition.
In other words, 'Procedure' is a sequence of processes, when undertaken in the laid down sequence, produces the described result.
The work instruction, is a prescribed and proscribed Instruction, combining command and explanation, for each and individual process in the 'Procedure'.
Umang :D
Moderator
The required six may also be called something other than "procedure." It's the substance that's important.
Top
