Procedures in Communication, Operational Control, etc. - ISO 14001
Daminda
In 3.19 standard says about Procedure. It says "specified way to carry out activity or a process". But there is no details that need to cover under Procedure(s).
The Standard mention about establishing, implementing and maintaining procedures in Communication, Operational Control, Evaluation of Compliance and etc.
Can any one explain me the patterns and the things that should be included when documenting "Procedures" to above mention areas?.
I think, there should be one "Communication Procedure" for a company but there can be many "Operational Control Procedures". Is it better to keep one good format for Procedure writing.
The standard also says that " Procedure can be documented or not". Then how the company prove the verbal Procedure is enough? and how the auditors prove that verbal is not enough?
There is no requirement for any of those to be documented, however many companies decide to document procedures to ensure continutiy and constancy in the operation of processes.
The best way to write the procedure is to flow chart the major steps of the process. Then you can add details about each step, showing responsibilities, resources, information, metrics and the like. Add as much detail as the process operators need.
For example, in the process for communication. What are the basic steps you use to communicate? Then who performs which step? What resources, information, materials, etc are needed? How will you know the step was performed properly? All of these questions could be asked for each step of the process. And as needed, that information could be included in the procedure (which is the annotated flowchart, or a narrative of the steps you outlined in the flowchart)
Hope that helps
Daminda
Mr. Dave,
Your explanation helped me lot.We are a construction company. We have sites at all over the country and performs different activities in different sites. Is it better to keep one good Procedure format (covering all needs) to avoid the generation of different patterns?.
Auditors ask for documented procedures specially in the area of "Operational Control" always. Please attach if you have any sample procedures.
Can you please explain me the item "4.4.6 Operational Control". Specially "The organization shall identify and plan those operations that are associated with the identified significant environmental aspects consistent with its environmental policy, objectives and targets, in order to ensure that they are carried out under specified conditions,"
That would depend on if the activites were very similar. If there is a good deal of variation between sites, then a site-specific procedure would be more beneficial. Another option (and I think the best) would be to have one generic procedure to cover all sites, but have site specific addendums to cover the variations.
I will try to find something to attach, but at best it would only be a reference. You need to have something that meets your individual needs. BTW, although auditors may ask for documented procedures, no documented procedure is required by the standard.
The operational controls relate to your significant aspects. So, therefore, they probably should not be conflicting with your EMS. For example, part of the environmental policy has to include prevention of pollution. Your operational controls probably should not include dumping construction waste in a local ditch. In most cases, operational controls will be spelled out in the environmental programs. In some cases, you add environmental operational controls into the normal process control.
Hope that helps.
Daminda
Mr Dave,
Thank you very much for the help. One question remains with me Sir, Are Operational Controls based on to "Activities" or "Aspect"?
Mr Dave,
The short and confusing answer is yes. Now for the explaination. Aspects are elements of your activites, products and services. So, in regard to operational controls, we typically control the activity. However, there may be times when we control the product, such as in storage of liquids. You might have operational controls that involve inspection, maintenance, etc of liquid storage containers. Moving the liquid is an activity, so you would have operational controls for that activity.
I have found that most operational controls will be on the activity, because that is where the aspect is at greatest risk for variation. Make sure you consider start up, shut down, normal operation and emergency operations.
Hope that helps.
Good questions!
Randy
Mr Dave,
Neither and both........They are based on meeting the requirement of controlling significant aspects to prevent not fulfilling or meeting policy commitments (continual improvement, complying with applicable legal and other requirements, preventing pollution) and achieving objectives and targets.
Your "controls" must also contain specific language about operational criteria, performance parameters and operational charaterisitics that can be monitored and/or measured to ensure ability/adequacy of meeting requirements and the effectiveness of the control itself.
Daminda
Can anyone please explain me, do we have to write Operational Controls only for significant aspects?.
Randy
Here's what ISO 14001 states and only you can figure out how to make it work for your organization.
The answer is right in front of you...........
they are carried out under specified conditions, by
a) establishing, implementing and maintaining a documented procedure(s) to control situations where their absence could lead to deviation from the environmental policy, objectives and targets, and
b) stipulating the operating criteria in the procedure(s),
Daminda
Sir, according to the standard I understand Operational Controls only for activities that are associated with the identified Significant Aspects. But our Auditor asked operational controls for every activity.
I want to clarify this. What was point applied by our auditor?.
Y Procedures on Contract Review Document Control Systems, Procedures, Forms and Templates 3
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
DuncanGibbons Model-Based procedures and Architecting the QMS as a System Document Control Systems, Procedures, Forms and Templates 2
R Scientific Operating Procedures For Sterilization Practices in India PSA/2012/1 Other Medical Device Regulations World-Wide 0
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
DuncanGibbons Are the IQ OQ & PQ procedures applicable to the aerospace industry? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Procedures for Complaint Handling and Post Market Surveillance EU Medical Device Regulations 7
A Recall/Adverse event report procedures in Kuwait/Qatar/Kenya Other Medical Device and Orthopedic Related Topics 3
S Use of "Shall" versus "Should" in Procedures ISO 13485:2016 - Medical Device Quality Management Systems 26
F Recommended practice for furnishing Technical Procedures ISO 17025 related Discussions 1
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
F ISO 17025:2017 Clause 7.4.1 - Requirements for Procedures ISO 17025 related Discussions 4
M MDR Annex IX Chapter I, 2.2 (c) - Device identification procedures during manufacture. EU Medical Device Regulations 1
R How to improve a Validation program and procedures to FDA (21 CFR part 820) & ISO13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
N ISO 9001: 2015 - Example standards policies, procedures, acknowledgements and checklists ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Quality System Processes without Documented Procedures Document Control Systems, Procedures, Forms and Templates 39
L IATF 16949 requirements for Product Safety Procedures IATF 16949 - Automotive Quality Systems Standard 14
M FDA News USFDA Final Rule – Medical Device Classification Procedures: Incorporating Food and Drug Administration Safety and Innovation Act Procedures Medical Device and FDA Regulations and Standards News 0
M FDA News The FDA Issues Final Rule on Medical Device Classification Procedures Medical Device and FDA Regulations and Standards News 0
K Assigning the Correct Procedures Applicable to Job Titles General Auditing Discussions 15
M Medical Device News FDA's Policies and Procedures Should Better Address Postmarket Cybersecurity Risk to Medical Devices Other US Medical Device Regulations 0
Q MDSAP Regions and how to include in procedures Other Medical Device Related Standards 2
M Translate Procedures into Spanish Other Medical Device Regulations World-Wide 5
J Nonconforming product procedures SOP help :) Nonconformance and Corrective Action 2
P How to have employees buy-in of quality procedures. Best practices? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M IATF Clause 8.4.2.2 - What procedures does this apply to? IATF 16949 - Automotive Quality Systems Standard 1
S Which ISO 9001 Clause applies to "Procedures are outdated"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
K Proto 6106 and 6106A Adjustment procedures General Measurement Device and Calibration Topics 0
M ISO13485 Documentation packs (manual, procedures, forms etc) ISO 13485:2016 - Medical Device Quality Management Systems 3
S How many QMS processes and procedures? ISO 13485:2016 - Medical Device Quality Management Systems 2
D Job Titles referenced in Procedures IATF 16949 - Automotive Quality Systems Standard 18
Q Management control Procedures & Operational Control Procedures ISO 14001:2015 Specific Discussions 1
S Risk based approach - Procedures already take a risk-based approach to QMS processes ISO 13485:2016 - Medical Device Quality Management Systems 3
G ISO 17025 Calibration Laboratory Assessor's Common Questions and Procedures ISO 17025 related Discussions 11
S Are 2 Hard Copies of Procedures and Instructions Required? ISO 13485:2016 - Medical Device Quality Management Systems 6
I Procedures from recognized standards or specifications ISO 17025 related Discussions 3
I Concerning procedures within Quality Manual ISO 17025 related Discussions 10
S Language of procedures when operating in multiple countries ISO 13485:2016 - Medical Device Quality Management Systems 4
A AS9100 Rev D - List of Required Procedures Document Control Systems, Procedures, Forms and Templates 5
A AS9100D Quality Manual & Procedures needed Quality Management System (QMS) Manuals 4
K AS9100:2016 (Rev. D) Required Procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 19
A Special Procedures for Non Aerospace Customers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Importance of Written Procedures in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q Is KPI in Process Valid if not supported by Procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V QMS / QSR - Reference to Framework - Templates - Procedures for Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
N International / Traceable Standards - Procedures for Calipers, Micrometers, Etc. ISO 17025 related Discussions 2
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R How to Control Videos as part of the QMS Documented Procedures and Instructions Document Control Systems, Procedures, Forms and Templates 2
