Procedures Required by ISO 9001:2008
Chance
#12
Re: ISO 9001:2008 Required Procedures
Why do you think that it's necessary for a procedure for a process? Why, for example, can't a process be defined verbally? Or maybe a form used to check off and record the various steps through the process?
Just interested in the discussion as to why...
It would be a nightmare to control if procedures are not written. Then everybody will do it their own way, at the end of the day everybody will have different outputs. How can you cantrol that if you have not written anything. How can you justify who is doing wrong or right?
Chance
#13
To list the processes will meet the requirements of 4.2.2.c. this is how I interpret the standard. The procedures will just make it easier to understand the process.
We created a flowchart specifying input, process, output.
TXSUN
#14
That was one of my original questions. : )
I could not find it on the cove, so I had to turn to Google. :confused: This is what I found:
PRM: The process reference model is a logical representation of the elements of the processes that can be performed at a basic level. Using the reference model in a practical application might require additional elements suited to the environment and circumstances.
If anyone has additional information on this acronym, as it relates to ISO9001:2008, I would GREATLY appreciate it! (Especially if I am wrong!):popcorn:
#15
It would be a nightmare to control if procedures are not written. Then everybody will do it their own way, at the end of the day everybody will have different outputs. How can you control that if you have not written anything. How can you justify who is doing wrong or right?
Not at all! In a small company, there are often processes which work very well without documentation. I agree a bigger company might need more documentation, but it has to be addressed case by case and not - ever - a mandate when ISO 9001 doesn't require it and it's no justification for doing the documentation!
Your points are apropos to determine if documents might be needed, but not justification in and of themselves.
#16
I had asked earlier what PRM stands for, as I had never seen the abbreviation. You didn't ask about it originally; you used it as if you knew what it means. Now that you've provided a definition, it sounds like some kind of flowchart. There are people who are in the habit of renaming common things in the misbegotten belief that the new names seem more important or official, or something. These people and their abbreviations should be avoided. I wouldn't worry about it, in other words.
Chance
#17
IMHO, processes have to be documented in such a way that we can see and figure out where we can improve. It does not have to be because ISO require or don't require. We have to document good business practices.
Also, it helps when new hires come onboard, they can refer to the written procedure. I don't quite understand why you said my points are apropos. Anyway, those are just my humble opinion, that is how I forsee it. Things will become messy and chaotic if procedures are not written. There is no way you can validate if people are doing it right or wrong. :2cents:
V
vanputten
#18
Chance:
Are you saying that every process you are involved in is documented? There is no way to optimally document every process. It is not needed and would be a nightmare to control and manage.
Is there a documented procedure on how to start your car? How to order from a fast food restaurant? How to swing on a swing at a play ground? How to send an e mail? How to use the internet? Is a child provided with a documented procedure as to how to tie a shoe?
Many, many processes in life and business are not documented but understood and repeatable. Some process are beneficial to document based on how complex it is, how critical it is, how widespread the use is, how often the process is performed, the identified risks, etc.
#19
ap·ro·pos (pr-p)
adj.
Being at once opportune and to the point. See Synonyms at relevant.
adv.
1. At an appropriate time; opportunely.
2. By the way; incidentally: Apropos, where were you yesterday?
prep.
With regard to; concerning: Apropos our date for lunch, I can't go.
Chris_Anderson
#20
People need to know outcomes not procedures. A Process map is sufficient for explaining the process. Most new hires get trained through on-the-job training (OJT) and are then let loose. Focus people on process outcomes, defects, and nonconformances and you will have a system to evaluate their training (6.2.2). Procedures are not required for every process but outcomes are...
Gman2 Can I use ONLY the six required procedures in my ISO 9001 QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K List of procedures and forms or records required by ISO 15189:2012 Document Control Systems, Procedures, Forms and Templates 2
I Quality Procedures (as required by ISO 9001) for Inspection Bodies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Quality Manual - ISO 17025 required Mandatory and Operational Procedures ISO 17025 related Discussions 7
E List of Sales Procedures required for ISO 13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Identifying procedures that are NOT required by ISO 9001 Quality Manager and Management Related Issues 17
G Rookie to the ISO 9001:2008 World - Required Procedures and Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
V List of Required Procedures as per ISO 13485 & MDD EU Medical Device Regulations 8
D ISO 9001:2008 Six (6) Required Procedures Presentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
V Mandatory Procedures required by ISO 14001-2004 ISO 14001:2015 Specific Discussions 10
M The 6 documented procedures required by ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
Ajit Basrur ISO 17025 - Required Procedures and Records ISO 17025 related Discussions 11
H Any examples of the required ISO 9001 Procedures for a Small Recruitment Company Document Control Systems, Procedures, Forms and Templates 7
M Adding More Procedures than are Required by ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D How many procedures are required by ISO 14001? ISO 14001:2015 Specific Discussions 12
I ISO 13485 - List of required / needed procedures and records attached ISO 13485:2016 - Medical Device Quality Management Systems 51
M Input Needed (Help): My List of 'Required' ISO 9001 Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I Required ISO 9000:2000 Procedures - Are procedures still necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P ISO 9001:2000 - Required Procedures or minimum required number? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
Marc ISO 9001:2000 Required Procedures Listing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Are 2 Hard Copies of Procedures and Instructions Required? ISO 13485:2016 - Medical Device Quality Management Systems 6
A AS9100 Rev D - List of Required Procedures Document Control Systems, Procedures, Forms and Templates 5
K AS9100:2016 (Rev. D) Required Procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 19
O QMS / EMS required procedures ISO 14001:2015 Specific Discussions 4
S Forecasting and Material Planning - Are formal procedures required? Document Control Systems, Procedures, Forms and Templates 3
M Mining Operation Sand Plant - Required Standards and Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N AS9110 Audit Stage 2 - What procedures are required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Changes required to procedures after introduction of SAP Document Control Systems, Procedures, Forms and Templates 3
M Additional Procedures required for QA Department Document Control Systems, Procedures, Forms and Templates 10
J How to determine what procedures are required - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
S Number of Documented / Controlled Procedures Required by TS 16949 IATF 16949 - Automotive Quality Systems Standard 6
E TS 16949 Clause 4.2.3 - How many Procedures are Required? IATF 16949 - Automotive Quality Systems Standard 13
A Policies and Procedures are required but what is the reason? General Measurement Device and Calibration Topics 16
Q What are the required procedures for Medical Device Specification Developer? ISO 13485:2016 - Medical Device Quality Management Systems 24
E Are we required to update our procedures even though no changes? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M List of FDA Required Procedures Other US Medical Device Regulations 5
A Are two separate procedures required for Corrective action and preventive actions Document Control Systems, Procedures, Forms and Templates 38
B What other Procedures are required apart from the Basic Six & Management Review? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T What Are The "6" Procedures Required by ISO9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Ajit Basrur List of mandatory or required procedures for 21 CFR Part 820 ISO 13485:2016 - Medical Device Quality Management Systems 9
S EN AS 9100 Procedures and WI (Work Instructions) Required Document Control Systems, Procedures, Forms and Templates 3
T Sarbanes Oxley Act (SOX) linkage to a documented QMS - Detailed Procedures Required? Document Control Systems, Procedures, Forms and Templates 21
P Procedures Required by TS 16949 Document Control Systems, Procedures, Forms and Templates 3
F How many procedures are required by TS 16949:2002 Document Control Systems, Procedures, Forms and Templates 6
A The 7 Procedures Required by TS 16949 IATF 16949 - Automotive Quality Systems Standard 15
S Detail Required in Documented Procedures Document Control Systems, Procedures, Forms and Templates 7
Y Procedures on Contract Review Document Control Systems, Procedures, Forms and Templates 3
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
