Procedures Required by ISO 9001:2008
#41
Re: ISO 9001:2008 Required Procedures
Is there a difference between making scrambled eggs for yourself and making a complicated product for your customer? Do you think there is a proper way to achieve hard chrome plating of .001" thick, or do you just plate them how you feel that day?
What you seem to be missing is that there might well be a proper way to do that sort of plating, but that doesn't mean, in and of itself, that the proper way must be documented.
Sidney Vianna
Post Responsibly
#42
Of course there is. That is exactly why the standard mentions that THE ORGANIZATION must decide the additional documents it needs to implement the processes that affect the quality system.
You should know that one of the biggest criticism to the early versions of ISO 9001 was the emphasis on documentation. Not every process is complex. Some processes can be deployed and improved by "tribal knowledge".
snappy
#43
Here you're referring to "procedure" as a document.
This is exactly the sort of confusion I alluded to in my earlier post. "Procedure" is given more than one meaning. It would have made life a lot simpler if the standard referred to documented processes instead of documented procedures.
Confused indeed.
snappy
#44
The reduced emphasis on documentation was because, IMO, organizations were being told by consultants and auditors alike that the standard required 20 procedures. When surveyed, organizations expressed a disdain for the voluminous (and awful) procedures (supposedly) required by the standard. But the 20 procedures were never required and never a good idea from any clever perspective. Yet many organizations still use such documentation to define their QMSs.
So, the reduced emphasis on documentation was coupled with the endorsement of the process approach to urge documentation to be based upon processes--which would reduce the emphasis on the **** procedures organizations were depending upon to get them through audits.
Under the 1994 scheme, I would write the number of procedures that were right for my client companies--which had no correlation to the number of requirements that pertained to those processes. It was common in smaller organizations to finish with only ten or eleven QMS procedures (covering the realization and support processes). Three to five pages each.
These same documents are effective in describing those QMSs to meet current 9001 requirements despite the changes in the standard in 2000/2008. A QMS does not depend upon the standard for its existence or its definition. Rather, it depends upon the organization and its processes that impact quality.
Ha! I remember garnering criticism for "not even writing the 20 required procedures" from auditors and other consultants under the 1994 scheme. Those who made such comments didn't get it.
Some didn't even notice that the 2000 revision of 9001 rebuked the element-by-element approach. More than a few still think they are experts at the "processes" "required" of the standard.
JaneB
#45
There is a lot unclear thinking when it comes to "procedure" and "process"
Agree with that.
I distinguish between the two, and don't consider them synonyms at all.
ISO 9001 refers to "documented procedures" which is either a redundancy or intended to differentiate between documents and procedures.
I tend to think that it just is being quite clear about the need to have a documented procedure.
In other words, the way the standard is worded, "procedure" and "process" are synonymous
Really? That's not how I read it.
Documents should exist when there's a useful purpose for their existence. If a document can be eliminated without losing something, it should almost always be eliminated, or not written to begin with.
Now there, I am in total 100% agreement with you.
Randy
#46
Time for my :2cents:
It don't really make a dribble what is and what ain't as long as:
1) 4.2.1 is effectively met for the absolutes, and for the little extra's especially, the organization uses 4.2.1d - documents, including records, determined by the organization to be necessary to ensure the effective planning, operation and control of its processes.
...and whatever is documented for whatever reason is controlled by effective implementation of 4.2.3 and/or 4.2.4...DUH!
Folks can document the whole world if they want and call things procedures, processes, poo-pa's or ding-a-lings as long as they know what the difference is and they control whatever must be controlled
:sarcasm: But, whatever is documented, for whatever the reason has to be on 18lb light blue paper with a lily watermark :sarcasm:
Paul Simpson
#48
Guys, guys. This is all defined in ISO 9000. Perhaps we should start from there and see where the lack of clarity is coming from. Didn't we start to discuss this in around 1847? :sarcasm:
My little homespun summary:
There may be more than one procedure for carrying out a process. Procedures can be documented or not.
Hope this helps.
JaneB
#49
Hope this helps.
Yes, exactly.
Gman2 Can I use ONLY the six required procedures in my ISO 9001 QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K List of procedures and forms or records required by ISO 15189:2012 Document Control Systems, Procedures, Forms and Templates 2
I Quality Procedures (as required by ISO 9001) for Inspection Bodies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Quality Manual - ISO 17025 required Mandatory and Operational Procedures ISO 17025 related Discussions 7
E List of Sales Procedures required for ISO 13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Identifying procedures that are NOT required by ISO 9001 Quality Manager and Management Related Issues 17
G Rookie to the ISO 9001:2008 World - Required Procedures and Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
V List of Required Procedures as per ISO 13485 & MDD EU Medical Device Regulations 8
D ISO 9001:2008 Six (6) Required Procedures Presentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
V Mandatory Procedures required by ISO 14001-2004 ISO 14001:2015 Specific Discussions 10
M The 6 documented procedures required by ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
Ajit Basrur ISO 17025 - Required Procedures and Records ISO 17025 related Discussions 11
H Any examples of the required ISO 9001 Procedures for a Small Recruitment Company Document Control Systems, Procedures, Forms and Templates 7
M Adding More Procedures than are Required by ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D How many procedures are required by ISO 14001? ISO 14001:2015 Specific Discussions 12
I ISO 13485 - List of required / needed procedures and records attached ISO 13485:2016 - Medical Device Quality Management Systems 51
M Input Needed (Help): My List of 'Required' ISO 9001 Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I Required ISO 9000:2000 Procedures - Are procedures still necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P ISO 9001:2000 - Required Procedures or minimum required number? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
Marc ISO 9001:2000 Required Procedures Listing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Are 2 Hard Copies of Procedures and Instructions Required? ISO 13485:2016 - Medical Device Quality Management Systems 6
A AS9100 Rev D - List of Required Procedures Document Control Systems, Procedures, Forms and Templates 5
K AS9100:2016 (Rev. D) Required Procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 19
O QMS / EMS required procedures ISO 14001:2015 Specific Discussions 4
S Forecasting and Material Planning - Are formal procedures required? Document Control Systems, Procedures, Forms and Templates 3
M Mining Operation Sand Plant - Required Standards and Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N AS9110 Audit Stage 2 - What procedures are required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Changes required to procedures after introduction of SAP Document Control Systems, Procedures, Forms and Templates 3
M Additional Procedures required for QA Department Document Control Systems, Procedures, Forms and Templates 10
J How to determine what procedures are required - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
S Number of Documented / Controlled Procedures Required by TS 16949 IATF 16949 - Automotive Quality Systems Standard 6
E TS 16949 Clause 4.2.3 - How many Procedures are Required? IATF 16949 - Automotive Quality Systems Standard 13
A Policies and Procedures are required but what is the reason? General Measurement Device and Calibration Topics 16
Q What are the required procedures for Medical Device Specification Developer? ISO 13485:2016 - Medical Device Quality Management Systems 24
E Are we required to update our procedures even though no changes? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M List of FDA Required Procedures Other US Medical Device Regulations 5
A Are two separate procedures required for Corrective action and preventive actions Document Control Systems, Procedures, Forms and Templates 38
B What other Procedures are required apart from the Basic Six & Management Review? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T What Are The "6" Procedures Required by ISO9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Ajit Basrur List of mandatory or required procedures for 21 CFR Part 820 ISO 13485:2016 - Medical Device Quality Management Systems 9
S EN AS 9100 Procedures and WI (Work Instructions) Required Document Control Systems, Procedures, Forms and Templates 3
T Sarbanes Oxley Act (SOX) linkage to a documented QMS - Detailed Procedures Required? Document Control Systems, Procedures, Forms and Templates 21
P Procedures Required by TS 16949 Document Control Systems, Procedures, Forms and Templates 3
F How many procedures are required by TS 16949:2002 Document Control Systems, Procedures, Forms and Templates 6
A The 7 Procedures Required by TS 16949 IATF 16949 - Automotive Quality Systems Standard 15
S Detail Required in Documented Procedures Document Control Systems, Procedures, Forms and Templates 7
Y Procedures on Contract Review Document Control Systems, Procedures, Forms and Templates 3
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
