Procedures Required by ISO 9001:2008
Chris_Anderson
#55
Re: ISO 9001:2008 Required Procedures
While six procedures are required of the 2000/2008, this does not mean that six separate documents are required. "Documented procedures" means that it is documented in QMS procedures somewhere.
In 1994, many thought that 20 procedures were required of the standard. This was not true, in fact it illustrates an element-by-element approach--which is a bad idea from the perspective of quality assurance.
Now that the 2000/2008 standard explicitly requires six procedures, many think that six is the clever/magic number of procedures. Same mistake.
The number of procedures depends upon how many processes are in operation that impact quality. Don't confuse activities with processes here, and you'll be okay. (Focus on major processes--processes at their highest level, maybe.)
A procedure simply describes how a process is carried out. If you have a process, you have a procedure. The standard does not, and never has, identified companies' "quality system processes" (with the exception of the required support processes). So the number of procedures (beyond the required six) depends on the organization--not upon the standard.
Don't write procedures to address the requirements you sited, write procedures to describe the processes. Then review them to make sure that conformity to the sited requirements is clear, as applicable.
The standard requires that (4.1a) processes are determined, (4.1b) sequence and interaction of these processes are determined, (4.1c) criteria and methods are effective, (4.1d) resources and information are available, (4.1e) monitor, measure, and analyze these processes, and (4.1f) improvement actions happen. Nowhere does it say this has to be documented. Determined--yes.
I can conform to all of these requirements without a documented procedure using a lean system. Work cells aligned in balanced flow order, just in time signals, visual indicators, andon lights, takt times, 5S, error proofing, etc. And there would be no doubt to anyone what the the process is, its sequence, interaction, criteria, methods, measurements, and improvement are occurring. Would you insist that I must document this in a procedure? For whom? Everyone already knows what to do and they can show that they are doing it.
Randy
#56
The answer is in 4.2.1d. If ya hafta...Yes If ya don't hafta....No
aboziad55
#58
Hi All
I'm new member in the cove
Could you tell me if I can merge all 6 mandatory procedure in one procedure and write each one in the separate section
Could you attach blank or example of 6 mandatory procedures
Bonhomme
#59
Well, since you insist. :notme:
Very useful, thank you :eek:
Even if I wonder why the dog is part of the "call for help" team but not the "give a hug once safe" one :bonk:
edit : to be somehow useful, Aboziad55, you can indeed merge part or all 6 of the mandatory procedures into a single document if it better suits your company needs. 9001 doesn't require a specific template/format
As for examples, you could try searching the Post Attachment List : http://elsmar.com/Forums/fileslist.php?mode=allfiles&sortby=filename&pageamt=1&criteria=procedure
Gman2 Can I use ONLY the six required procedures in my ISO 9001 QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K List of procedures and forms or records required by ISO 15189:2012 Document Control Systems, Procedures, Forms and Templates 2
I Quality Procedures (as required by ISO 9001) for Inspection Bodies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Quality Manual - ISO 17025 required Mandatory and Operational Procedures ISO 17025 related Discussions 7
E List of Sales Procedures required for ISO 13485 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Identifying procedures that are NOT required by ISO 9001 Quality Manager and Management Related Issues 17
G Rookie to the ISO 9001:2008 World - Required Procedures and Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
V List of Required Procedures as per ISO 13485 & MDD EU Medical Device Regulations 8
D ISO 9001:2008 Six (6) Required Procedures Presentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
V Mandatory Procedures required by ISO 14001-2004 ISO 14001:2015 Specific Discussions 10
M The 6 documented procedures required by ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
Ajit Basrur ISO 17025 - Required Procedures and Records ISO 17025 related Discussions 11
H Any examples of the required ISO 9001 Procedures for a Small Recruitment Company Document Control Systems, Procedures, Forms and Templates 7
M Adding More Procedures than are Required by ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D How many procedures are required by ISO 14001? ISO 14001:2015 Specific Discussions 12
I ISO 13485 - List of required / needed procedures and records attached ISO 13485:2016 - Medical Device Quality Management Systems 51
M Input Needed (Help): My List of 'Required' ISO 9001 Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I Required ISO 9000:2000 Procedures - Are procedures still necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P ISO 9001:2000 - Required Procedures or minimum required number? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
Marc ISO 9001:2000 Required Procedures Listing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Are 2 Hard Copies of Procedures and Instructions Required? ISO 13485:2016 - Medical Device Quality Management Systems 6
A AS9100 Rev D - List of Required Procedures Document Control Systems, Procedures, Forms and Templates 5
K AS9100:2016 (Rev. D) Required Procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 19
O QMS / EMS required procedures ISO 14001:2015 Specific Discussions 4
S Forecasting and Material Planning - Are formal procedures required? Document Control Systems, Procedures, Forms and Templates 3
M Mining Operation Sand Plant - Required Standards and Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N AS9110 Audit Stage 2 - What procedures are required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Changes required to procedures after introduction of SAP Document Control Systems, Procedures, Forms and Templates 3
M Additional Procedures required for QA Department Document Control Systems, Procedures, Forms and Templates 10
J How to determine what procedures are required - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
S Number of Documented / Controlled Procedures Required by TS 16949 IATF 16949 - Automotive Quality Systems Standard 6
E TS 16949 Clause 4.2.3 - How many Procedures are Required? IATF 16949 - Automotive Quality Systems Standard 13
A Policies and Procedures are required but what is the reason? General Measurement Device and Calibration Topics 16
Q What are the required procedures for Medical Device Specification Developer? ISO 13485:2016 - Medical Device Quality Management Systems 24
E Are we required to update our procedures even though no changes? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M List of FDA Required Procedures Other US Medical Device Regulations 5
A Are two separate procedures required for Corrective action and preventive actions Document Control Systems, Procedures, Forms and Templates 38
B What other Procedures are required apart from the Basic Six & Management Review? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T What Are The "6" Procedures Required by ISO9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Ajit Basrur List of mandatory or required procedures for 21 CFR Part 820 ISO 13485:2016 - Medical Device Quality Management Systems 9
S EN AS 9100 Procedures and WI (Work Instructions) Required Document Control Systems, Procedures, Forms and Templates 3
T Sarbanes Oxley Act (SOX) linkage to a documented QMS - Detailed Procedures Required? Document Control Systems, Procedures, Forms and Templates 21
P Procedures Required by TS 16949 Document Control Systems, Procedures, Forms and Templates 3
F How many procedures are required by TS 16949:2002 Document Control Systems, Procedures, Forms and Templates 6
A The 7 Procedures Required by TS 16949 IATF 16949 - Automotive Quality Systems Standard 15
S Detail Required in Documented Procedures Document Control Systems, Procedures, Forms and Templates 7
Y Procedures on Contract Review Document Control Systems, Procedures, Forms and Templates 3
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
