Procedures, Work Instructions & Documents served as guidelines only!
tkevmoore
I'm currently in an AS9100 Lead Auditor training class. One of our exercises involves reviewing a sample manual and verifying it's compliance to Section 4.2.2 (same in ISO as AS). One of the clauses in the sample manual stated:
In our quality system, documented procedures are those procedures that are required by the ISO 9001:2000/AS-9100 standards. Other procedures , work instructions and documents are used for reference, guidelines and training purposes only and are not followed precisely as written
This apparently was based on a real life example and was not non-compliant to the standard. I know my instructor wants us to think out of the box, but it's very hard for me to get past 10 years of ISO auditing to accept that documents don't have to be followed. Someone help me see the light.
Tom
Marcelo
Re: Documents as guidelines
In a process-based management system, what is important are the outputs of each process. Procedures are step-based collection of activities that define how to do something, and, because of past misinterpretations of auditors and users, generally have nothing to do with the output of the process, only with the output of the procedure.
It´s really not that much important how you get to the output needed if you consistently do so. Controls (and they´re generally related with procedures) are only needed if you do not consistently procedure the desired output (this is measured by the way by your process kpi which is related with the process objective, meaning the process output).
In our quality system, documented procedures are those procedures that are required by the ISO 9001:2000/AS-9100 standards. Other procedures , work instructions and documents are used for reference, guidelines and training purposes only and are not followed precisely as written.
Tom
My only issue with it is that if an auditor were to observe a process being operated "precisely as written," it would be a nonconformity. If it were to say, "...not always followed precisely as written," it would be OK.
Sidney Vianna
Post Responsibly
Tom
Tom, firstly, I would like to commend you for being upfront about your question. Sometimes, people come here asking for help with a situation similar to yours, but they pretend it is something else, rather than some type of training exercise.
The training you are undergoing and the instructor probably have some kind of "expected" answer for the scenario you describe. I don't know the expected answer. However, if this scenario is indeed based on an actual manual, we would have a situation where an organization is trying to preempt possible non-conformities in case an auditor finds a process not following the requirements of these "additional" procedures, work instructions, etc....
It is a silly game. What is the purpose of having "reference documents" if they don't serve the purpose to define the processes and activities?
ISO 9001 4.2.1 d) states
documents needed by the organization to ensure the effective planning, operation and control of its processes, and
emphasis is mine.
So, what you have here is an organization trying to create a preemptive loophole in case they are caught not following their own command media. They can not, in my opinion, state something in the manual that contradicts the standard they are supposed to comply with. A good discussion will ensue, I suspect.
PS. Is your instructor, proponent of out of box thinking, a habitual Cover?
G
gagegirl
The company I work for would love to use that in there procedures. They do not currently word it in that way but do it anyway.
But to help with your question.
My company references all customer supplied quality requirements. For example, our largest customer has requirements that cover everything from sampling, to gaging requirements for 3A threads. The problem with this statement, from my own experience at this company, is that some work instructions are required by each and every operator and inspector. How would a company define which are to be "followed precisely as written" and which are not? It may help them pass an audit, but when something goes wrong in the field there is nothing documented as to what was or was not performed during the manufacturing process. Work instructions can be ever changing on the floor but never make it to document control.
As to the comment from mmantunes...It may not be important how you got to a consistently manufactured product until something goes wrong then the first question from engineers and supervisors alike is ... Did you follow the work instructions? Because it is the first step in eliminating factors to get to the root cause.
JaneB
I agree with Sidney. If they're needed, one can state how & when and/or state when they can or should be ignored.
Often this kind of thing occurs when either procedures/documents aren't well structured (eg, procedures are far *too* prescriptive and more detailed than they need to be, or the structure doesn't allow for differences at the detail level) or they're not kept current. Either of which can be - and should be - fixed.
But I do wonder if it's actually the simpler answer, from the wording of the Q itself:
and if it's just the common old chestnut of 'we only have to have 6 procedures in our quality system because that's all ISO requires'. In which case the response is no, not OK, and the ref. that Sidney gave - ISO 9001 4.2.1 d)
JaneB
Yes, exactly so. You nailed it.
Marcelo
I´m not saying that there should not be procedures, just that the process approach to quality system is not about having 20-plus-steps procedures for everything, when the most important is the process output and not the output of a single procedure. This "procedures for everything" was generally what was done in the past and the main reason for the implementation of the process approach.
So, i don´t see a need for every procedure to be included in the quality system. Only the key procedures, key controls and key indicators. Other documents can, in my opinion, be used just as guidelines and that would be ok. IF a NC happen, then you can see if these guidelines were followed and if not, maybe you need to put some control in the form of a and detalied step which HAS to be followed and put this in your quality system, but not the other way around (creating a web of procedures that no one will follow and consequently putting your system at risk of meeting a bad auditor which still thinks in the "write what you do, do what you write" way).
Russ
We have just made a change in how we handle these. We use Work instructions for when it needs to be done the same way or it can affect quality. The next tier below that is what we call Standard Work. These are considered the "Best" way to do a task but it can be done other ways without comprimizing quality. Work Instructions are auditable and Standard Work is not.
We just cleared an ISO audit and they had no problem with this approach. It does force you to look at the significance of the document!
I think you're ascribing motive (trying to create a loophole) without enough evidence of intent. There are times when the best-laid plans go astray, and the documentation doesn't account for unexpected possibilities. To say that production should be delayed (and perhaps customers should be disappointed) while documentation catches up with necessary process changes is short-sighted, imo. Sometimes you have to do things on the fly.
Q Work instructions - Referencing other documents including procedures Document Control Systems, Procedures, Forms and Templates 18
D A matrix tracking all procedures, work instructions, and documents Document Control Systems, Procedures, Forms and Templates 4
S Are 2 Hard Copies of Procedures and Instructions Required? ISO 13485:2016 - Medical Device Quality Management Systems 6
R How to Control Videos as part of the QMS Documented Procedures and Instructions Document Control Systems, Procedures, Forms and Templates 2
K Definition Work Instructions and Procedures (The difference between) Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 12
A Is a Change Notice needed if I change the Procedures and Work Instructions?? Document Control Systems, Procedures, Forms and Templates 4
K Creation of Quality Manual, Procedures Manual, Work Instructions and Guidelines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
W Procedures, Forms, Instructions for ISO 14001 ISO 14001:2015 Specific Discussions 10
S Procedures and/or Work Instructions for New User Manual? Document Control Systems, Procedures, Forms and Templates 2
B Policies, SOPs (Standard Operating Procedures) and WIs (Work Instructions) Quality Manager and Management Related Issues 2
E Manufacturing without Procedures and Work Instructions Document Control Systems, Procedures, Forms and Templates 12
C Procedures or Work Instructions on Roll Flagging for a flexible packaging company Document Control Systems, Procedures, Forms and Templates 5
A Reduction of Pages in Work Instructions and Procedures Document Control Systems, Procedures, Forms and Templates 5
N Procedures vs. work instructions? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
kmyers Gage Calibration Procedures or Instructions Document Control Systems, Procedures, Forms and Templates 3
G Definition of Terms in procedures and work instructions Document Control Systems, Procedures, Forms and Templates 14
Z How to Establish Simple and Efficient Procedures and Operating Instructions Document Control Systems, Procedures, Forms and Templates 16
B Who is the author of your procedures and work instructions? Document Control Systems, Procedures, Forms and Templates 13
E Job training to procedures and work instructions - Do you have to train to forms? Training - Internal, External, Online and Distance Learning 7
S EN AS 9100 Procedures and WI (Work Instructions) Required Document Control Systems, Procedures, Forms and Templates 3
E Documenting forms, procedures or work instructions - Serial numbers? Document Control Systems, Procedures, Forms and Templates 1
K Looking for templates for writing procedures & work instructions - printing Document Control Systems, Procedures, Forms and Templates 10
W The difference between Technical Procedures and Work Instructions Document Control Systems, Procedures, Forms and Templates 4
T Definition SOP's (Standard Operating Procedures) vs. Work Instructions - Differences? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 20
Manix Standard Operating Procedures (SOP's) - Are these simply Operator Work Instructions? Document Control Systems, Procedures, Forms and Templates 6
J TS 16949 Consultant said "Get rid of all of these Procedures and Work Instructions" Document Control Systems, Procedures, Forms and Templates 14
G Can Work Instructions be audited? 'Local' vs. Corporate policies and procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
S Manufacturing Process Work Instructions vs. Work Procedures - Differences? Document Control Systems, Procedures, Forms and Templates 10
G Forms have no linkage to procedures or instructions - How to address? Document Control Systems, Procedures, Forms and Templates 9
R Talsico Process Picture Map software to write their procedures / work instructions? Quality Assurance and Compliance Software Tools and Solutions 2
SteelMaiden SOPs (Standard Operating Procedures) vs. Policies, Procedures and Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
T Difference between written calibration procedures and calibration work instructions? General Measurement Device and Calibration Topics 8
Randy The Need to Update / Revise Work Instructions and Procedures Miscellaneous Environmental Standards and EMS Related Discussions 5
H Does ISO 9001:2000 require a Master List of Procedures, Work Instructions, etc? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A ISO 9000 Documentation Requirements - Procedures and job instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D If records are cited in procedures, do they have to be cited in work instructions? Records and Data - Quality, Legal and Other Evidence 2
D Do Procedures and Work Instructions have to have Document Numbers? Document Control Systems, Procedures, Forms and Templates 9
R Scientific Operating Procedures For Sterilization Practices in India PSA/2012/1 Other Medical Device Regulations World-Wide 0
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
DuncanGibbons Are the IQ OQ & PQ procedures applicable to the aerospace industry? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
B Procedures for Complaint Handling and Post Market Surveillance EU Medical Device Regulations 7
A Recall/Adverse event report procedures in Kuwait/Qatar/Kenya Other Medical Device and Orthopedic Related Topics 2
S Use of "Shall" versus "Should" in Procedures ISO 13485:2016 - Medical Device Quality Management Systems 21
F Recommended practice for furnishing Technical Procedures ISO 17025 related Discussions 1
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
F ISO 17025:2017 Clause 7.4.1 - Requirements for Procedures ISO 17025 related Discussions 4
M MDR Annex IX Chapter I, 2.2 (c) - Device identification procedures during manufacture. EU Medical Device Regulations 1
R How to improve a Validation program and procedures to FDA (21 CFR part 820) & ISO13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
N ISO 9001: 2015 - Example standards policies, procedures, acknowledgements and checklists ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Quality System Processes without Documented Procedures Document Control Systems, Procedures, Forms and Templates 39
