Process Approach & Continual Improvement Clauses and Evidence of its Effective Use
Q
qmsboy
Hi There,
What are all the sub clauses of ISO 9001 are of particular relevance/importance in relation to the process approach and continual improvement and according to these sub-clauses what evidence could demonstrate that an organisation is using these principles in an effective manner?
Re: Process approach&Continual improvement clauses and evidence of it's effective us
Hi There,
The standard is based on this philosophy and accepts your process approach as you define relevant to your organization. The standard asks you to detail it in the manual which comes under your documentation requirements of your established QMS.
When all your processes plan, do, check and act to meet the desired outcome of the organization, your wheel of ongoing quality management moves with time and when you begin to further act taking customer requirements and internal measurement and analysis to improve from where you started, you continually improve.
The clause 0.1 and 0.2 of the ISO9001 says it in such simple words
For specifics see clause 8.4 and 8.5
Q
qmsboy
Then what are these clauses in ISO 9001:2008 4.1(f),4.2.3(b),5.1, 5.3(b), 6.1(a),8.1(c),8.5.1 ? Moreover,I am looking for precise answer as I am not confident in ISO 9001 interpretation.
4.1 f) implement actions necessary to achieve planned results and continual improvement of these processes.
Tells you to consider it in your QMS general requirements.
4.2.3 b) to review and update as necessary and re-approve documents
Tells you to keep your QMS documents updated and approved as necessary
5.3 b) includes a commitment to comply with requirements and continually improve the effectiveness of the quality management system,
Asks you to state this commitment in your quality policy so that all actions have directions towards continual improvement.
6.1 a) to implement and maintain the quality management system and continually improve its effectiveness
Tells you to determine and provide such resources including human resources capable of implementing, maintaining and continually improving your QMS
8.1 c) to continually improve the effectiveness of the quality management system.
Your measurement, analysis and next steps must be also directed towards continual improvement of your QMS. It gives a general framework to plan your measurement analysis and improvement processes.
8.5.1 Continual improvement
The organization shall continually improve the effectiveness of the quality management system through the use of the quality policy, quality objectives, audit results, analysis of data, corrective and preventive actions and management review.
Provides a framework for improvement continually through well applied CA and PA processes.
As you do the specifics keeping in line with the general directions as these said above your QMS is step by step moving forward with the intention of planned continual improvement.
I'm not sure about how good of a list you have there.
For continual improvement there is a good list in 8.5.1.
For the process approach, all of 4.1, not just f. 4.1 is where the "shalls" start and they start with the process approach. Most everything in 4.1 (if not everything) is repeated later. The one with the most teeth is probably 8.2.3.
I would go further and say that EVERYTHING from 4.1 to 8.5.3 is about continual improvement.
qusys
Re: Process Approach & Continual Improvement Clauses and Evidence of its Effective Us
Hi There,
Suggestion could be to have a process in place , even though it is not a requirement of ISO 9001 but for ISO TS.
However it could be helpful as well for ISO 9001.
It is important to note that continual improvement applies to your QMS processes through a combinationon of the item cited in 8.5.1 ( quality policy, quality objectivies...). From a general point of view, it is a sort of "raising the bar" continually ( step by step) by the organization.
Q
qmsboy
Hi all,
What about the following?is this matches with my query?Could you complete the list by filling missed information and adding missing clauses?
4.1(f)- what is the evidence?I don't know:(
5.4.1 - quality objectives - reduction in repair/rework,reduction in energy consumption,reduction in defect etc are evidence.
5.6 - management review - audit data, customer feed back, process performance etc as evidence.
7.1 - planning of product realisation - what is the evidence?I don't know:(
8.2.1 - Customer satisfaction - customer satisfaction survey data as evidence.
8.2.3 - monitoring&measurement process - data collected from monitoring and measurement like defect data,scrap data,customer satisfaction data etc. as evidence.
8.2.4 - monitoring and measurement of product - Inspection data,contamination check etc as evidence.
8.4 - data analysis - data from measuring and monitoring,internal audit,purchase data as evidence
8.5.2 - CA (Is this part of process approach?I don't know):(
8.5.3 - PA (Is this part of process approach?I don't know):(
:thanks:
K
kgott
One thing I've wondered is, is it possible, or would it be likely, to get an NC from a certification authority for not demonstrating an act of, or having sufficient evidence of committment to continuous improvement?
thanks - k
ssz102
4.1,the evidence have: quality management system(quality manual, procedure and WI etc), record related was established by your company according to ISO standard
7.1 the quality objectives and requirements of product, record and documents and operation or inspection instruction with production process needed
8.5 CA&PA, the results of compare between prior to and after improvement and corrective action report
qusys
thanks - k
Yes, it is possible.
However I think that if an organization does not have it , it will finish by itself.
I think that each organization works for projects, aimed at improving also the QMS processes.
If you measure results with goal and objective and demonstrated that you are adopting spet by step continual imrovement, it is ok.
This is a clear action of top mgmt to sponsor it and plan recommendation for improvement.
If there is no committment to continuous improvement, the question is very serious.:bigwave:
A Question regarding new VDA_AIAG fmea approach for process FMEA FMEA and Control Plans 0
I PFD (Process Flow Diagram) approach. Setup details as part of PFD? APQP and PPAP 5
qualprod Shortening processes complying with process approach ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
tony s What is the automotive process approach for auditing? IATF 16949 - Automotive Quality Systems Standard 2
M APQC PCF (Process Classification Framework) and ISO 9001 - Processes Based Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Does Japan accept the Bracketing Approach for Process Validation Japan Medical Device Regulations 1
A How do we implement a Process Approach ISO 13485:2016 - Existing GMP QMS Other ISO and International Standards and European Regulations 2
P System Audit Approach - Application of VDA 6.3 - Process Auditing VDA Standards - Germany's Automotive Standards 2
B How do you approach the "Safe Launch" Process APQP and PPAP 17
M Process Approach: Types & number of processes required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
WCHorn Quality Digest article on the Process Approach to ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W Help explaining the need for the Process Approach AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q Introducing Process based approach on Production Floor Manufacturing and Related Processes 6
K How Can I Implement the Process Approach in AS9100C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
Y What is a Process Approach Audit? Process Audits and Layered Process Audits 8
G The future of the Process Approach to Auditing General Auditing Discussions 10
M PFMEA (Process FMEA) - What is the best approach? FMEA and Control Plans 14
Q Process or Departments - Document Content and Managing the Process Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
I Process Approach Litmus Test - Procedure Titles ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
B Process Approach - Convert System of Documentation into System of Managed Processes Misc. Quality Assurance and Business Systems Related Topics 2
L Consultant not following Process Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 34
J Why Process Approach? Why not Process Method? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Process Approach to Auditing Quality Management System Internal Auditing 12
Q ISO 13485, ISO 9001 QMS and FDA Requirements - Process vs. Compliance Approach? ISO 13485:2016 - Medical Device Quality Management Systems 4
Q Process Approach - Special Focus? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Marc Process Approach Challenge - Please Define what the 'Process Approach' is Misc. Quality Assurance and Business Systems Related Topics 48
I Poll: Should auditors promote the process approach? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 331
Howard Atkins Process Approach Requirement for Internal Audits in TS 16949 IATF 16949 - Automotive Quality Systems Standard 46
A Process approach to auditing ISO 9001:1994 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
K FMEA is the Best C.I approach for process improvement? Preventive Action and Continuous Improvement 3
A Can the Process Approach be used to audit Management Commitment and how? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
A Systematic history of process approach Philosophy, Gurus, Innovation and Evolution 5
P Process Approach - Implementing ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 11
apestate Is the Process Approach optional? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Calculating Cpk for Tubing Wall Thickness - Extrusion Process - How to approach? Statistical Analysis Tools, Techniques and SPC 16
A Process Approach to Auditing Undocumented Processes at the System Level Internal Auditing 7
W What is meant by Process Approach Auditing and What questions should be asked? Process Audits and Layered Process Audits 11
U Process based Audit Approach vs. Clause based Audit Approach Process Audits and Layered Process Audits 49
Anerol C Process Approach Training Material ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
W Process approach - Auditor issued OFI (opportunity for improvement) on clause 8.2.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
O Training on ISO9001 Process Approach Training - Internal, External, Online and Distance Learning 13
P What is the Process Approach in Payroll? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Implementing the Process Based Approach - Reality check needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
B Process Approach Audit Plan - What a Process Approach Audit Plan Looks Like Internal Auditing 19
H Process Approach - Apply it into the system procedure Document Control Systems, Procedures, Forms and Templates 0
M Supply and Delivery - How should I approach the work for a specific process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T QSE basics and QMS process audit approach - What are the QSE basics? IATF 16949 - Automotive Quality Systems Standard 3
V Process approach based internal auditing Internal Auditing 1
Crusader Process Approach beef - Registrar says that we 'should' use the process approach General Auditing Discussions 20
