Process Approach Litmus Test - Procedure Titles
Status
Not open for further replies.
I
ISO 9001 Guy
Yes or no, does your system documentation include QMS procedures bearing titles like, "Customer Property?" "Product Identification?" "Inspection and Test Status?" "Preservation of Product?" Procedure titles indicate QMS structure. A QMS is a system of processes. Procedures describe these processes. So procedures indicate processes that have been identified as being necessary to the QMS.
Jen Kirley
Quality and Auditing Expert
Re: Process Approach Litmus Test
I may be missing something. What does the title have to do with it? I don't care what they are called, I want them to sensibly describe the plans and controls necessary to ensure both internal and external customers enjoy positive results.
Colin
Speaking as a consultant, no. There are times when the title of the procedure happens to coincide with the title of a clause e.g. document control, audits, etc, and I sometimes would write a procedure for purchasing if the company want it as a separate entity. On the other hand, I am just starting a project where we have a procedure called 'materials management', which includes planning, purchasing, goods in and receipt and handling of customer property.
Titles are somewhat meaningless without context of the business. What are you looking to discuss?
I
ISO 9001 Guy
Yes, Colin, I agree that in some cases an organization's processes happen to align with the requirements, as you indicated, in the case of support processes. The clauses cited are specifically related to realization processes (from section seven). To treat realization requirements as if they are processes (by dedicating QMS procedures to them) is to employ an elemental approach--contrary to the process approach.
I
ISO 9001 Guy
Since a procedure describes how a process is carried out, a QMS procedure describes how a QMS process is carried out. If you have a procedure, it describes a process. (Per definitions in ISO 9000:2005.)
A QMS is a system of processes. Documents designed to answer a standard's requirements, rather than to describe processes, exemplify an elemental approach--which is not the process approach demanded of the standard.
somashekar
Just some procedures with titles as mentioned in the opening post does not say much about lack of a process approach ... unless otherwise an assessment shows that these procedures are operating in isolation aka elemental without links and takeovers.
Stijloor
<snip>A QMS is a system of processes. Documents designed to answer a standard's requirements, rather than to describe processes, exemplify an elemental approach--which is not the process approach demanded of the standard.
While I am all in favor of the process approach, it is not required by ISO 9001:2008. ;)
Stijloor.
I
ISO 9001 Guy
That's why it's only a litmus test--but it's very accurate if you think about it. Organizations using all of these procedures are very likely to be employing an elemental approach. A brief investigation during stage 1 auditing should confirm that the process structure suggested by the documentation has not been effectively determined. Such procedures demonstrate a confusion between requirements and processes, thus procedurally confusing processes with property, activities, methods, etc.
Although an organization might process customer property, customer property is not ordinarily an organizational process. (Rather, it's a clause or sub-clause of the standard.) If customer property is a QMS process, for sake of argument, and is properly documented as such, then how does an organization measure and improve this process?
Here's some official guidance relevant to this discussion:
From ISO/IAF ISO 9001 Auditing Practices Group Guidance on: Identification of Processes, June 5, 2009. (http://isotc.iso.org/):
". . . 2. A process has defined objective(s), input(s), output(s), activities, and resources
If the auditee does not understand that a process must have defined (but not necessarily measurable) objective(s), input(s), output(s), activities, and resources, the auditor should try reformulating the questions to the auditee avoiding the use of QM jargon, e.g. Can you explain to me your operations here? What are the basic jobs carried out in your department? What information do you need to start your work? Where does it come from? Who receives the result of your work? How do you know if you’ve done your job correctly? etc..
This should help the auditor to establish whether the processes (as per ISO 9001) are already defined, have clear inputs, outputs, objectives and so on. . .
". . . 4. The auditee/auditor considers that each clause or sub-clause of ISO 9001
must be defined as a separate process. If the auditor considers this as the right approach, he should refer to relevant ISO documents
, (notably the ISO/TC 176/SC 2 document N544 ISO 9000 Introduction and Support Package: Guidance on the Concept and Use of the Process Approach) which clearly indicates the contrary.
If the auditee considers this as the right approach, it is recommended that the techniques outlined in section 2 (above) should be used."
From ISO/TC 176/SC 2/N525R2, Introduction and support package: Guidance on the documentation requirements of ISO 9001:2008, October, 2008 (http://www.iso.org/iso/iso_catalogue/management_standards)
“An organization that has not used a process approach in the past will need to pay particular attention to the definition of its processes, their sequence and interaction.”
“It is stressed that ISO 9001 requires (and always has required) a ‘Documented quality management system’, and not a ‘system of documents’.”
From ISO/TC 176/SC 2/N544R3, ISO 9000 Introduction and Support Package: Guidance on the Concept and Use of the Process Approach for management systems, October, 2008 (http://www.iso.org/iso/iso_catalogue/management_standards):
“All processes should be aligned with the objectives, scope and complexity of the organization, and should be designed to add value to the organization.”
“. . . each organization should define the number and type of processes needed to fulfill its business objectives. It is permissible for a process that is required by ISO 9001:2008 to be part of a process (or processes) that is already established by the organization, or to be defined by the organization in terms that are different to those in ISO 9001.”
Status
qualprod Shortening processes complying with process approach ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
tony s What is the automotive process approach for auditing? IATF 16949 - Automotive Quality Systems Standard 2
M APQC PCF (Process Classification Framework) and ISO 9001 - Processes Based Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Does Japan accept the Bracketing Approach for Process Validation Japan Medical Device Regulations 1
A How do we implement a Process Approach ISO 13485:2016 - Existing GMP QMS Other ISO and International Standards and European Regulations 2
P System Audit Approach - Application of VDA 6.3 - Process Auditing VDA Standards - Germany's Automotive Standards 2
B How do you approach the "Safe Launch" Process APQP and PPAP 17
M Process Approach: Types & number of processes required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
WCHorn Quality Digest article on the Process Approach to ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W Help explaining the need for the Process Approach AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q Introducing Process based approach on Production Floor Manufacturing and Related Processes 6
K How Can I Implement the Process Approach in AS9100C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
Y What is a Process Approach Audit? Process Audits and Layered Process Audits 8
G The future of the Process Approach to Auditing General Auditing Discussions 10
Q Process Approach & Continual Improvement Clauses and Evidence of its Effective Use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M PFMEA (Process FMEA) - What is the best approach? FMEA and Control Plans 14
Q Process or Departments - Document Content and Managing the Process Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B Process Approach - Convert System of Documentation into System of Managed Processes Misc. Quality Assurance and Business Systems Related Topics 2
L Consultant not following Process Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 34
J Why Process Approach? Why not Process Method? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Process Approach to Auditing Quality Management System Internal Auditing 12
Q ISO 13485, ISO 9001 QMS and FDA Requirements - Process vs. Compliance Approach? ISO 13485:2016 - Medical Device Quality Management Systems 4
Q Process Approach - Special Focus? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Marc Process Approach Challenge - Please Define what the 'Process Approach' is Misc. Quality Assurance and Business Systems Related Topics 48
I Poll: Should auditors promote the process approach? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 331
Howard Atkins Process Approach Requirement for Internal Audits in TS 16949 IATF 16949 - Automotive Quality Systems Standard 46
A Process approach to auditing ISO 9001:1994 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
K FMEA is the Best C.I approach for process improvement? Preventive Action and Continuous Improvement 3
A Can the Process Approach be used to audit Management Commitment and how? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
A Systematic history of process approach Philosophy, Gurus, Innovation and Evolution 5
P Process Approach - Implementing ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 11
apestate Is the Process Approach optional? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Calculating Cpk for Tubing Wall Thickness - Extrusion Process - How to approach? Statistical Analysis Tools, Techniques and SPC 16
A Process Approach to Auditing Undocumented Processes at the System Level Internal Auditing 7
W What is meant by Process Approach Auditing and What questions should be asked? Process Audits and Layered Process Audits 11
U Process based Audit Approach vs. Clause based Audit Approach Process Audits and Layered Process Audits 49
Anerol C Process Approach Training Material ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
W Process approach - Auditor issued OFI (opportunity for improvement) on clause 8.2.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
O Training on ISO9001 Process Approach Training - Internal, External, Online and Distance Learning 13
P What is the Process Approach in Payroll? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Implementing the Process Based Approach - Reality check needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
B Process Approach Audit Plan - What a Process Approach Audit Plan Looks Like Internal Auditing 19
H Process Approach - Apply it into the system procedure Document Control Systems, Procedures, Forms and Templates 0
M Supply and Delivery - How should I approach the work for a specific process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T QSE basics and QMS process audit approach - What are the QSE basics? IATF 16949 - Automotive Quality Systems Standard 3
V Process approach based internal auditing Internal Auditing 1
Crusader Process Approach beef - Registrar says that we 'should' use the process approach General Auditing Discussions 20
S Automotive Process Approach Auditing sanctioned interpretations S1 04 04 General Auditing Discussions 1
M Document Review Audit Findings - Design and Process Approach Design and Development of Products and Processes 2
