Process Audit Checklist Example - Feedback Please
H
Hodgepodge
I have been thinking about combining process auditing and checklists. I do see how it would be easy to lose sight of the goal and let a checklist mentality keep one from understanding if a process was being performed correctly and effectively. However, I think if a checklist were created correctly, it would be beneficial, kind of like a hyper-specific PEAR.
Attached is a sample checklist. I am using the Temper Etch Inspection process as my example. The idea is to have the auditor be knowledgeable (or an expert) in the subject process. Then use the checklist to make sure each key step in the process is performed correctly by witnessing the inspector complete the process, asking questions along the way as necessary to ensure the auditor has an understanding of what the inspector is doing and why.
Could you please take a look at my example checklist and provide feedback? You don't have to be an expert in temper etch inspection to give feedback on the checklist. I'm looking for feedback on the idea.
A quick look and I don't see anything about a process, really! I see a lot of documentation being reviewed available and so forth, but I can't identify the key activities of a process...what's the input? Is it checked to make sure it's correct, what's the process of etching? Steps? What's the output? How is it verified and so on. The other things are (possibly) important as support to the process but they appear to swamp the checklist and hide the actual process...
But then, I've just driven 12 hours, so my head's about to explode...
Jen Kirley
Quality and Auditing Expert
It looks like a useful checklist, but when I do my process audits I am careful to include things like
  • numbers of whatever calibrated instruments are used, including gauges, thermometers/thermocouples for ovens,
  • a means to verify the equipment setup matched the process design (as the job router or similar document for that run would show),
  • evidence of lot number traceability,
  • control of nonconforming product (does AS9100 require segregation or marking of nonconforming product before it goes into rework or disposition?),
  • the suppliers of whatever chemicals/materials going into the process have been approved,
  • cleanliness controls, if any are maintained beyond the physical cleaning of the part. (Isopropyl alcohol vs. mineral spirits, etc
I hope this was useful.
ssz102
i check it quickly, the most contents for this checklist are describle the documents available and the inspector's qualify
i think the process audit is more attention process produce and running, this is lack in this checklist to you, such as equipment parameter setting and changing, people and material and operation method managing and so on
harry
The problem, I think, is that you had the process flow etched behind your mind and those points listed are what you intend to check at the critical points/areas. However, for those that have no idea of your process flow, it looks like just some random disconnected items to check.
H
Hodgepodge
Andy,
With the temper etch process, the output is verification that over tempering of the parts surface has or has not occurred due to abusive machining. If it has occurred, this process will detect it. The output is the detection, or lack thereof, of burn marks. For it to be useful, the machine operator should be immediately notified of the inspection results good or bad.
How do you make sure you are doing it correctly? It is a special process. The way to make sure it was done correctly is to use trained personnel who use a controlled, documented, approved process. The inspectors are supposed to etch samples that are known to be over tempered at the start of each day to ensure the process and chemicals are adequate. This audit would also be a sort of practical test as well.
The idea was to have the auditor be knowledgeable (or an expert) in the subject process and have the procedure in front of him/her.
P.S. I hope your head is still intact! We need it around here! ;)
H
Hodgepodge
Good ideas! I didn't think to have the equipment listed with calibration details checked. I will include all of these items in the checklist.
Do you have a sample process audit checklist example you could share? My idea is to have all the main requirements listed so the auditor will not forget anything.
H
Hodgepodge
Andy,
I've been looking at your process football. If I audit my processes, management responsibilities through preventive action, it seems I will have audited document control and record control. I will have seen that the correct documents have been used and were available. I will have seen the records that are created by each process. I will have seen where the documents and records are stored. This being said, I believe I will have indirectly audited document and record control. I wouldn't need a separate audit of these two processes. Is this acceptable?
If there were findings relating to document or record control in any of the audits, that could trigger an audit of that process.
Mikishots
I'm having a hard time understanding why this would be identified as a special process; the fact that the inspection is possible (and its process detailed) would seem to indicate that the resulting output is very capable of being monitored and measured. If you're verifying surface hardening by inspection, it's not a special process.
I'm not a fan of Yes/No checklists because they are very limited in the info they contain. The structure of this checklists indicates that it is simply a compliance checklist and does not lend itself to a process flow in any way that I can see. Will you collect samples? How many? Will you cite work orders you looked at? What are the requirements to pass the work to the next cell?
H
Hodgepodge
Oddly enough, I have the answers to all of these questions in my head and understand what I would do to answer them in an interview. However, I see that the checklist is lacking in many regards. Looks like I will continue on without the checklist.
M MSDS process audit - Can any one give idea for checklist of the same Occupational Health & Safety Management Standards 14
C Internal Audit - Process Clause Matrix / Audit Checklist ISO 13485:2016 - Medical Device Quality Management Systems 7
L Request APQP Process Internal Audit checklist APQP and PPAP 2
K Process Audit Checklist For Powder Coating Required Process Audits and Layered Process Audits 2
F Airport Internal Audit Checklist (Cleaning, Project Process, Maintenance, etc) Internal Auditing 3
B Can I use Internal Audit Checklist to do Process Audit? Process Audits and Layered Process Audits 9
R Process Internal Audit Checklist for Service Organizations wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
H Checklist to Audit an Injection Molding Process needed Supplier Quality Assurance and other Supplier Issues 6
P Internal ISO 9001 Audit - Process Audit Checklist Internal Auditing 31
O Process Audit Checklist - Generic vs. Process Specific Process Audits and Layered Process Audits 17
B Blow Molding Process Audit Checklist Supplier Quality Assurance and other Supplier Issues 5
Jen Kirley Anyone have an audit checklist for PSM (Process Safety Management)? Internal Auditing 1
D PPAP Audit Checklist to Audit our PPAP?s against the Current Process APQP and PPAP 8
Z SMT and Sheet Metal Supplier Process Audit Checklist Supplier Quality Assurance and other Supplier Issues 5
S TS/ISO 16949 Process Audit Checklist required Process Audits and Layered Process Audits 3
D How to create an Process Oriented ISO 14001:2004 Audit Plan & Checklist General Auditing Discussions 21
E Supplier audit checklists for special processes - Plating Process audit Checklist Process Audits and Layered Process Audits 2
B Chrysler PFMEA Audit Criteria Checklist to evaluate your Process FMEA FMEA and Control Plans 7
Q The Checklist to ISO/TS16949 - Is it a Process Audit or Elemental? Process Audits and Layered Process Audits 8
I ISO 13485 Practical Internal Audit Checklist - Standard vs. Process Based Internal Auditing 26
J Process Audit Checklist to document Internal Process Audit results Process Audits and Layered Process Audits 19
D Process and Product Audit Checklist - Product Realization, Effectiveness of Process General Auditing Discussions 8
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Description of the requirements of clause 9.2.2.3 manufacturing process audit- needs your feedback IATF 16949 - Automotive Quality Systems Standard 0
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
K Differences between Manufacturing Process Audit & Layered Process Audit Lean in Manufacturing and Service Industries 4
C Can You Internally Audit a Process You Own? Internal Auditing 25
K Layered Process Audit (LPA) Software IATF 16949 - Automotive Quality Systems Standard 5
D Has anyone undergone a BARDA (HHS) audit as part of their grant process? Other Medical Device Regulations World-Wide 0
V Process and Internal Audit Criteria matrix wanted Internal Auditing 8
A What does a good business practice Process Audit look like for AS9100D? Process Audits and Layered Process Audits 9
B Process audit note sheet IATF 16949 - Automotive Quality Systems Standard 2
E How do I create a FMEA for the Internal Audit process? Internal Auditing 11
T Example System & Process Audit Check Sheet for IATF 16949 IATF 16949 - Automotive Quality Systems Standard 1
R AS9100D Internal Audit Process Checklists ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C What is an Airbus Industrial Process Control Assessment (IPCA) Audit Passing Score General Auditing Discussions 1
Sidney Vianna Proposed Change to 3rd Party Audit Process - Limiting Scope of Audit Registrars and Notified Bodies 19
P Internal Audit Matrix Process Query ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
O VDA 6.3 Process Audit Template wanted VDA Standards - Germany's Automotive Standards 5
C Customer Satisfaction Process - Audit "Suggestion for Improvement" General Auditing Discussions 14
Q KPI (Key Performance Indicators) for the Audit Process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
M Cement Production Process Audit Process Audits and Layered Process Audits 3
G Metal Stamping Process Audit Questions Manufacturing and Related Processes 8
Y The challenge of why should we have ISO9001 and process audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Remote Support Location Audit - Engineering prototyping and process evaluation Internal Auditing 2
