Process Audit recommendation within ISO TS 16949? Does it exist like in VDA?
jrubio
#11
Thanks Howard for your format
Howard the format you recommended to audit is excellent, it goes though the proccess deeply.
Thanks.
:applause: :biglaugh: :yes: :whip: :thanx:
O
Osman
#12
Hi every Body..
First Thanks for this wonderdull and useful forum or website..:)
really since i got these Forums, im coming back agian and again, and im not getting enough from it :applause:
i have a Question related to a process audit .. In control plan does 100% isnpection means that process is critical?
hope to get answer fron u .
ralphsulser
#13
Hi every Body..
No it doesn't mean the process is critical, but it could be a designated control item which is critical. Usually if a process is designated 100% inspection it means that it is not capable of achieving a Cpk of 1.33 or more.
jrubio
#14
But if the charasterist is Safety or Critical usually operating 100% Test is used with a quick Test (Red light or green light often used in electronics).
Imaging an anti gas war mask, we produced in the last company I worked, the clamps for the filters for these masks were critical /Safety and 100% inspection (I would say better 100 Tested) were required.
:biglaugh:
jrubio
#15
100% inspections
In my opinion, these kind of Tests are functional Tests based on attributive characteristic (not continuos variables), which must not be used to measure capability according to MSA book, Thease charasterists are not used to measure capability due to this task would be very difficult to measure in all the products (It is used in parallel).
But sometimes with Laser devices on some variables it could be done.
Or Special attributive Camaras (Artificial Inteligence with neuronal nets)
ralphsulser
#16
Imaging a anti gas war mask we produced in the last company I worked the clamps for these masks were critical /Safety and 100% inspection (I would say better 100 Tested) were required.
:biglaugh:
Well yes, I can understand your comments related to 100% TESTING required for a critical function of saftey related items.
jrubio
#17
ralphsulser, your previous message was brilliant, thanks :applause:
To be honest the variables with usually the companies used for measuring capability (i.e Thickness) are not the typical defects they search in the 100% inspection Test due to these Tests often search for attributive defects.
That´s why the companies still have Quality problems, the defects usually are in the field of attributive defect, due to continues variables are easier to control it via Statistical mode (Gauss), but attributive is more complex for enterprises, I would say that there are a few of them that really use attributive statical tools for attributive (Size of sample, Binomial, ;Mil standard, ...)
The general concept (I know that this is hard but is true) I heard from a Quality Manager was "if you search more you will find more defects" or "The higher the size the higher the number of defects found" :lmao:
It is corious that the kind of defects claimed by the Customers ofter are not put in the FMA, Transport damage, Handeling defect, bad shipment...
O
Osman
#18
is it possible to prepare control plane with out Fmea?
Thanks all I appreciate your replies :)
what i got now is that if we are performing 100 inspection its not necessary mean that the process is critical. and there could two reasons as jrubio & ralphsulser mentioned
1- the process is Not capable Cpk of 1.33
2- the inspection is conducted to attribute
To give u a clear picture to what im facing , an OEM select us to do a 2nd party audit for his suppliers by checking the compliance of OEM MQC (Quality manufacturing chart ) "very similar to Control plan", and the suppliers MQC. At suppliers MQC we found they are writing 100% inspection in front of some processes with out pointing these are critical, my senior say that they should put critical symbol, and if its Not critical why they are doing 100% inspection !!
I think it could be easier to know which process is critical if the suppliers conducting FMEA with MQC but most of them prepare the MQC with out FMEA !!
sunwen
#19
Does it exist a Process Audit recommendation within ISO TS?
When we were under VDA norm, VDA issued manuals to carry on the process Audit and Product Audit, my question is if there are something similar in ISO TS 16949.
I ask that because we are following auditing this proccess under VDA manual due to we have not seen any manual or recomendation from IATF.
Your help would be much appreciated.
Cheers!
I think execute the process , product and management systems audit based on VDA mannuals is ok!!! maybe it is verbose, but it does is helpful!:applause:
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
U Internal Auditor not trained but done Audit for some process Nonconformance and Corrective Action 5
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
B Using Unreleased Documents & Process Maps for Internal Audit purposes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Description of the requirements of clause 9.2.2.3 manufacturing process audit- needs your feedback IATF 16949 - Automotive Quality Systems Standard 0
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
M MSDS process audit - Can any one give idea for checklist of the same Occupational Health & Safety Management Standards 14
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
K Differences between Manufacturing Process Audit & Layered Process Audit Lean in Manufacturing and Service Industries 4
C Can You Internally Audit a Process You Own? Internal Auditing 25
C Internal Audit - Process Clause Matrix / Audit Checklist ISO 13485:2016 - Medical Device Quality Management Systems 7
K Layered Process Audit (LPA) Software IATF 16949 - Automotive Quality Systems Standard 5
D Has anyone undergone a BARDA (HHS) audit as part of their grant process? Other Medical Device Regulations World-Wide 0
V Process and Internal Audit Criteria matrix wanted Internal Auditing 8
A What does a good business practice Process Audit look like for AS9100D? Process Audits and Layered Process Audits 9
B Process audit note sheet IATF 16949 - Automotive Quality Systems Standard 2
E How do I create a FMEA for the Internal Audit process? Internal Auditing 11
T Example System & Process Audit Check Sheet for IATF 16949 IATF 16949 - Automotive Quality Systems Standard 1
R AS9100D Internal Audit Process Checklists ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C What is an Airbus Industrial Process Control Assessment (IPCA) Audit Passing Score General Auditing Discussions 1
Sidney Vianna Proposed Change to 3rd Party Audit Process - Limiting Scope of Audit Registrars and Notified Bodies 19
P Internal Audit Matrix Process Query ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
O VDA 6.3 Process Audit Template wanted VDA Standards - Germany's Automotive Standards 5
C Customer Satisfaction Process - Audit "Suggestion for Improvement" General Auditing Discussions 14
Q KPI (Key Performance Indicators) for the Audit Process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
M Cement Production Process Audit Process Audits and Layered Process Audits 3
G Metal Stamping Process Audit Questions Manufacturing and Related Processes 8
Y The challenge of why should we have ISO9001 and process audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Remote Support Location Audit - Engineering prototyping and process evaluation Internal Auditing 2
R Audit Planning - Process Audit agenda - VDA 6.3 VDA Standards - Germany's Automotive Standards 4
M Universal Process Audit Form Document Control Systems, Procedures, Forms and Templates 1
P May I combine the Process Audit and Product Audit into Delphi's LSR? Customer and Company Specific Requirements 3
P System Audit Approach - Application of VDA 6.3 - Process Auditing VDA Standards - Germany's Automotive Standards 2
Crimpshrine13 Is VDA 6.3 required for Manufacturing Process Audit (ISO/TS 16949)? Manufacturing and Related Processes 5
S How would you audit this process? General Auditing Discussions 5
N Internal Process Audits - 7.1 Planning - How do YOU audit it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
W Internal Audit of the Internal Audit Process Internal Auditing 15
J Does this look like a Process Audit? Process Audits and Layered Process Audits 6
Stijloor AIAG Layered Process Audit 2nd Ed. (CQI-8) is now available. IATF 16949 - Automotive Quality Systems Standard 1
P Audit Design Process every Surveillance Audit - AS9104 Requirement? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
Q Chrysler required FMEA and Control Plan Document Audit Forms and Process Audit Check FMEA and Control Plans 7
SATHYABALARAMAN Process assessment & scheduling the audit IATF 16949 - Automotive Quality Systems Standard 4
H Layered Process Audit Hard Copy Records Retention Records and Data - Quality, Legal and Other Evidence 6
L Request APQP Process Internal Audit checklist APQP and PPAP 2
K Process Owners signing Internal Audit Reports Internal Auditing 6
V How to carry out a Process Audit General Auditing Discussions 4
R On Auditing Internal Audit Process - How Independence can be Established Internal Auditing 4
Y What is a Process Approach Audit? Process Audits and Layered Process Audits 8
S Process Audit Plan Terminology Process Audits and Layered Process Audits 5
