Process Auditing Clause 7.3 Design and Development
K
kgott
One of our business units does design and design verification for pressure equipment (boilers etc,) for its external clients.
Before I arrived, their certification was in jeopardy. My instructions have been to work with them to get them back on track and keep the certification.
However, I want to do more than that, I want to help them get real benefit out of 9001 so they?ll see real benefit in it and achieve more than just re-certification.
The CB has indicated they will be focusing on ?Design and Design Verification? (Section 7.3) at the next audit. It has been decided that I will do an audit focusing on Section 7.3, design and development so we can iron most of the problems out before the CB comes in the first quarter of 2013.
Auditing is my weakest link and I know that process auditing will be more beneficial for them than clause auditing so I?m going to have a go at it for the first time. I really want to get this as right as I possibly can because I want to provide these people with good useable information and build/retain my own creditability.
The procedures this business unit uses are a combination of highly detailed work instructions, some work flow process description and regurgitation of 9001 so in my view, they are of somewhat limited usefulness in terms of auditing the process.
Is it possible to audit S.7.3 using the process approach and if so could I please have some ideas on the sorts of questions I need to think about and ask?
The truth is I?m feeling a bit under the pump with this.
Thanks k
John Broomfield
kgott,
You could practice auditing any process that is meant to add value to information.
As well as following APG advice also remember to audit design change control when dealing with nonconforming product (design changes: include "use as is" and repair dispositions unless approved repair specifications apply).
The design process also result in documented information such as: "as-builts", user manual, labeling, packaging and maintenance manuals.
Leave configuration management for another day.
Best wishes,
John
Marcelo
Any clause of a process-based standard can be audited using the process approach.
For some ideas, generally this means auditing focusing in the following questions, deriving more related questions as the audit progress:
What are you trying to do?
How do you make it happen?
How do you know it?s right?
How do you know it?s the best way of doing it?
How do you know it?s the right thing to do?
(those are from the best book on quality standards process auditing, IMHO, Hoyle's ISO 9000:2000: Auditing Using the Process Approach)
somashekar
Get a complete grip of all the design plan and design inputs that has been considered in a project and make a check if any statutory and regulatory inputs are included (since you mention pressure equipment)
A drill down in the audit into how design inputs were collected, agreed and freezed before next steps brings all the inputs to the platform (perhaps including cost). An other question to ask is if the design review / verification / validation activities made any changes to the design plan / design inputs or brought in new inputs.
In the audit of all other design and development activities where the main task is to bring out design outputs that meets the input requirements.... ask.
Show me how which design input is met and who approves it.
It may sound simple, but let us know that the design inputs are broader and outputs may be several much beyond what can be expected in input. The design and development expertise must be in a position to link, relate, explain and approve all the outputs to the several inputs. (A sound knowledge of the design and development in question with the auditor helps in this)
So we see that the D&D steps which replicates a PDCA can be audited by coming back to the Plan (design plan / input) several times and at several stages, to see how design outputs meets input requirements.
Colin
When I conduct audits on a design department I select a couple of recently finished projects (depends upon time and the size/complexity of the projects) and follow them as they pass through the design process.
You can either start at the beginning and work through or start at the end and work back (at least that way you know the job has been completed).
So if start at the beginning I want to know things like 'what did the customer ask for? was there a specification or performance criteria quoted, etc (by the way, you may have to go to sales for this information).
How did they plan the design and was it agreed with the customer - was any slippage allowed for?
How are the design inputs stipulated and is there evidence that any applicable statutory and regulatory requirements have been included?
And so on .. in other words, I will work my way through the design process, using 7.3 and a real project looking for evidence but also interfacing with other departments such as sales, purchasing, production, testing, etc as required.
There are also other potential clauses such as customer satisfaction, nonconformance, document control, records, etc that you will pick up along the way. e.g. when you look at the drawings, check their revision status and make a note of it. When you look at the test results, make sure they were using the same version.
qusys
Thanks k
Use process approach asking for the inputs/outputs of the process, how the process is measured, with what procedures and how, which kind of skills/competence is required, how the personnel react in case of problems etc...
Ask for the records produced by the process and if they met requirments.Undestand links with other QMS processes and verify if there are shortcomes . Check at efficiency and effectiveness of the processe as well as at the continual improvement. This from general standopoint, you can also investigate the application of the process to a specified example or product ( for instance, one as new product introduction and one as mature).:bigwave:
Mikishots
However, I want to do more than that, I want to help them get real benefit out of 9001 so they’ll see real benefit in it and achieve more than just re-certification.
The CB has indicated they will be focusing on “Design and Design Verification” (Section 7.3) at the next audit. It has been decided that I will do an audit focusing on Section 7.3, design and development so we can iron most of the problems out before the CB comes in the first quarter of 2013.
Auditing is my weakest link and I know that process auditing will be more beneficial for them than clause auditing so I’m going to have a go at it for the first time. I really want to get this as right as I possibly can because I want to provide these people with good useable information and build/retain my own creditability.
The truth is I’m feeling a bit under the pump with this.
Thanks k
Process approach for D&D? Absolutely. Here's how I do it:
I start with a turtle (gahh...run!) and map out what's coming into the process and what's going out from it.
Example
Inputs:
Effect on WIP
Safety and regulatory requirements
Effects on constituent parts and systems
Existing design
Impact, cost, manufacturability, inspectability
Inputs from key development team members as required (procurement, order handling, planning, tech writers etc).
Inputs directly from customer.
Outputs:
Design drawings, specs, substantiations
Tech manual changes if needed. Service bulletin requests if needed.
Inspection plans
ID of key characteristics critical for product acceptance
Test reports
Records of reviews
I make sure that the processes that feed into D&D are defined and that the owners of those processes are aware of the requirements set out in the D&D process. Same goes for the output processes. The biggest thing is to find out how the process determines effectiveness; how is it determined when things are going sideways? What does the process say to do about it when it happens? If it has already happened and a fix was offered, did it work? Why or why not?
Short, but at least it might give you some ideas.
K
kgott
Right; I've made a mistake I shouldn't have made.
I went through the business unit procedure for how they control jobs (designing pressure equipment) and identified questions I should ask for each stage of the process, mostly relating to evidence to establish how well the practice matches the theory. (procedure) (Despite wanting to do a process audit I think I have actually done a procedure audit.)
Trouble is; I have made the basic mistake of not comparing the requirements of the procedure with the requirements of S.7, Product Realisation.
This means that I did not ask for or sight evidence of the relevant sections of S.7 being completed.
My question is; how do I account for this in my audit report?
I must admit I have also become a little confused about clause 7 being about the design and development of the business unit service and the fact that their service is design and verification of design.
thanks
S Auditing - by department, clause or process? General Auditing Discussions 14
tony s What is the automotive process approach for auditing? IATF 16949 - Automotive Quality Systems Standard 2
J Recomended Values - Auditing process in a supplier IATF 16949 - Automotive Quality Systems Standard 18
P Auditing "process validation" process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Suggestions for a UK based course in Process Auditing wanted Training - Internal, External, Online and Distance Learning 2
A Best Method of Auditing an Installation Process at a client job-site ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Where in the ISO 9001 standard it asks for process based auditing? Process Audits and Layered Process Audits 6
K Auditing New Product Introduction Process General Auditing Discussions 21
P System Audit Approach - Application of VDA 6.3 - Process Auditing VDA Standards - Germany's Automotive Standards 2
L Stability of the Process vs Improvement during Auditing General Auditing Discussions 8
R On Auditing Internal Audit Process - How Independence can be Established Internal Auditing 4
G The future of the Process Approach to Auditing General Auditing Discussions 10
R Auditing a process outside the realm of the formal Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Process Auditing in a Distribution Company Process Audits and Layered Process Audits 3
M Auditing the Internal Audit Process - 8.2.2 General Auditing Discussions 2
J Auditing the Internal Auditing Process - Audit Nonconformance General Auditing Discussions 3
J Help in Process Auditing - Turtle Diagram Examples Internal Auditing 2
K The Value of Turtle Diagrams in Process Auditing Internal Auditing 27
V Relevance of Process Based Auditing (PEAR) to regulated industry. US Food and Drug Administration (FDA) 3
Q Auditing Management Review - Who audits the management review process? IATF 16949 - Automotive Quality Systems Standard 5
B Process Approach to Auditing Quality Management System Internal Auditing 12
J Auditing the Budgeting Process (ISO 9001) General Auditing Discussions 13
A Auditing sufficiency of documented quality objectives vs the real process Internal Auditing 14
B Internal Auditing of a Process or Workplace? OHSAS 18001 Occupational Health & Safety Management Standards 12
A Green Belt Project for Improving Internal Process Auditing and Metrics Six Sigma 5
K Auditing the Internal Vendor (Supplier) Management Process Supplier Quality Assurance and other Supplier Issues 2
P Auditing Process Classics - I am planning to take CQA exam Professional Certifications and Degrees 5
T Can an Internal Auditor be involved in the process they are auditing? Internal Auditing 8
A Process approach to auditing ISO 9001:1994 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Layered Process Auditing (LPA) for a service provider Process Audits and Layered Process Audits 4
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
D Information Technology Process Audit - Suggestions for Auditing IT IATF 16949 - Automotive Quality Systems Standard 12
Z First time Auditor - Auditing an Outsourced Process General Auditing Discussions 3
J Determining Legal& Statutory requirements while Auditing Design & Development process Design and Development of Products and Processes 8
A Process Approach to Auditing Undocumented Processes at the System Level Internal Auditing 7
W What is meant by Process Approach Auditing and What questions should be asked? Process Audits and Layered Process Audits 11
C Reference Guide for Process Auditors - Yet another Process Auditing Tool General Auditing Discussions 1
H Auditing Lean as a process - Where to begin? Internal Auditing 9
5 Process based Internal Audits, instead of auditing to the elements of the standard Internal Auditing 21
R Auditing Accounting as a Key Process - TS16949 Audit Internal Auditing 6
R Process Auditing - Identifying/Monitoring "Key" Processes Sufficient? Process Audits and Layered Process Audits 5
J Internal Process Auditing - Auditor Unhappy - Wants Layered Process Audits Process Audits and Layered Process Audits 13
V Process approach based internal auditing Internal Auditing 1
S Automotive Process Approach Auditing sanctioned interpretations S1 04 04 General Auditing Discussions 1
P Process vs Elements/Checklist - Is the old method of auditing the clauses still legal General Auditing Discussions 41
H Auditing - System Approach and Process Approach Differences? General Auditing Discussions 20
M Internal Auditing of our APQP Process - Who can audit APQP? IATF 16949 - Automotive Quality Systems Standard 5
C Simple four-box process model - Referenced in ASQ Process-based auditing course General Auditing Discussions 5
I Process Auditing for our TS system - Please help and review if you would be so kind Process Audits and Layered Process Audits 7
howste New IATF Sanctioned Interpretation: Automotive Process Approach Auditing ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 14
