Process Capability Analysis Binomial or Normal using Minitab 15
brahmaiah
#31
Interesting thread surrounding process capability and Binomial data. Would you not want to transform the data as it is a unilateral spec and non-normal?
From this transformed data, the new control limits could be established and pre & post modification results for capability and p or u control chart derived.
However this was just a thought, if I am flawed in my thought process - please let me know. I come across this issues sometimes too!
Thanks.
Eric
Your thoughts are too wild and have no theoritical or practical basis.
V.J.Brahmaiah
brahmaiah
#33
What would you suggest? Can you help?
SPC has been discussed in this forum almost inexhaustively I suggest you to refer previous posts on this subject. If you still want me to help, please provide following information on the process data you are refering to;
1.Operation name
2.Machine name
3.Method of data collection
4.The collected data in an appropriate chart
5.Is the machine automatic/CNC/Manual
6.Characeristics measured and the tolerance
All are important to calculate the process capability
V.J.Brahmaiah
Stijloor
#34
1.Operation name
2.Machine name
V.J.Brahmaiah
Is that your suggestion for this post?
Stijloor.
tahirawan11
#36
1.Operation name
Curing of composite material
2.Machine name
The product is a 'Carbon Fibre Reinforced Slab' made by a similar process
Finished part is scanned using a NDT ultrasound scanner and a 'image' is obtain which gives us the 'void content'. For detail see previous posts.
attached
the process is a mix of automatic and manual work
6.Characteristics measured and the tolerance
'Voids content' or Porosity left within product, it is given in 'percentage' and the tolerance limit is 0-15. The values cannot go below 0. The lower the values the better it is.
We have only one case where the end product was out of specs (voids % 16) and based on root cause analysis done so far we have seen a good co-relation relation between 'vacuum lost' and 'void %'. During the manufacturing process we apply vacuum to the product to take out the air and if we have a 'vacuum lost' during the process we can see high void content. I have also seen that either we can have very good parts (no vacuum lost) or very bad parts (vacuum lost) and very few parts between lower and upper specs. limits. So i was thinking control chart may not be very useful to predict any future performance. After the process change i have seen improvements but now i am more interested to know how the process will behave in future.
bobdoering
Stop X-bar/R Madness!!
#37
One of the things we have not discussed is the variation from the measurement process. Have you performed a gage R&R to see how much of the variation - or even the fliers - come from the measurement itself? Both the measurement and the process are very "organic", so it would be good to sort out each one's participation.
A key to any statistical evaluation is total variation. Your data represents all variation - not just the variation of the process. It is always a good reminder to consider that when we look at data.
:topic: Your process reminds me of the old days when I molded carbon fiber/polyimide composite aircraft engine bearings and components. Ah, those were the days.... Do you look at cracking (in addition to porosity) as a participant in the voids, too?
brahmaiah
#38
1.Operation name
2.Machine name
attached
Thank you for your detailed information about your curing process.
'The data' ie the actual porosity observed falls under non-normal distribution.The characteristic(porosity)has a one sided specification means there is no value below zero.Process capability calculation in the normal procedure is not possible.You have to decide with your customer another method to asses the process capability of your process.This is the recommendation of Clause no.2.2.11.5 of PPAP -fourth edition.
Even if you are not following TS16949 requirement.The theory is same.
Now there are two alternative methods for you to proceed (in agreement with your customer).They are:
1.100% inspection for porosity.
2.Sampling inspection with '0' AQL.and
100% control on the optimum vacuum level in your moulding process.
Your control plan should specify minimum required vacuume level in the process characteristic colomn.
In addition ,your ultrosonic flaw detection process could contain a huge MEASUREMENT UNCERTAINITY FACTOR ang GRR VARIATION.
V.J.Brahmaiah
Statistical Steven
Statistician
#39
What is wrong with using the capability analysis for a nonnormal distribution that is available in Minitab? It also has capability for binomial and Poisson.
bobdoering
#40
That is a good question - since this is a Minitab forum. My guess Weibull distribution is more appropriate, however, for the unilateral void issue.
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
C Minitab Binomial Process Capability Analysis Chart Explanation Using Minitab Software 1
C Process Capability - Attribute Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
C Process Capability - Variables Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
A Cnpk (Non-Parametric Capability Analysis) to assess whether the Process is Stable Capability, Accuracy and Stability - Processes, Machines, etc. 7
D Capability Analysis for Packing Process in Food Manufacturing Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Capability Analysis (Cpk) of torque driver process Capability, Accuracy and Stability - Processes, Machines, etc. 5
E Process Capability Analysis for a Service Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Does a Chronically Unstable Process need a Capability Analysis? Statistical Analysis Tools, Techniques and SPC 10
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Proving Process Capability of a Packing Machine Capability, Accuracy and Stability - Processes, Machines, etc. 6
N Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
S Regression Control Chart - Process Capability Statistical Analysis Tools, Techniques and SPC 18
M How to determine Process Capability using Minitab 17 Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Long Term Process Capability from miltiple Machines and Fixtures Capability, Accuracy and Stability - Processes, Machines, etc. 3
E What Data do we need for Welding and Repair Process Capability? Six Sigma 1
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
S What is the difference between Process Capability and Machine Capabilty Capability, Accuracy and Stability - Processes, Machines, etc. 13
V How to Assess Process Capability at the Development or Optimization Phase Capability, Accuracy and Stability - Processes, Machines, etc. 6
kedarg6500 Sample Size for Short Term & Long Term Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Is it the same process capability or performance in 8.2.3.1 and SPC? IATF 16949 - Automotive Quality Systems Standard 1
E Binomial Process Capability Sample Size - Variables Data Capability, Accuracy and Stability - Processes, Machines, etc. 4
M On Subgroups in Control Charts and Process Capability Statistical Analysis Tools, Techniques and SPC 3
N SPC and Process Capability Using a Romer Arm Statistical Analysis Tools, Techniques and SPC 6
J Interpreting Process Capability results and ratios Capability, Accuracy and Stability - Processes, Machines, etc. 1
J Go or No-Go Process Capability Quality Tools, Improvement and Analysis 8
S Process Capability with Negative Exponential Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
V Process Capability to reconfirm the Inspection Frequency Manufacturing and Related Processes 3
B Sample Size based on Process Capability Indices (Pp/Ppk)? Capability, Accuracy and Stability - Processes, Machines, etc. 20
P Calculating Process Capability from Data of attached spreadsheet Statistical Analysis Tools, Techniques and SPC 4
D How to measure Process Capability for Homogeneous Batch Manufacturing Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Burrs affecting measurements and Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 7
G Assessing Process Capability on Variation (Hardware Adjustment Mean Shift) Capability, Accuracy and Stability - Processes, Machines, etc. 4
D Calculating Upper-CL/Lower-CL and Process Capability Statistical Analysis Tools, Techniques and SPC 8
V Defining Subgroups and Importance of Subgroups in SPC and Process Capability Statistical Analysis Tools, Techniques and SPC 6
T Process Capability - Understanding what Process Capability Indices mean Capability, Accuracy and Stability - Processes, Machines, etc. 17
Q TS 16949 Process Capability Requirements - Cpk ≥ 1.67 on All Key Parameters? IATF 16949 - Automotive Quality Systems Standard 8
S Process Capability questions - Calculating Cpu using Minitab Six Sigma 6
C Sample Size Calculation Formula for Process Capability Statistical Analysis Tools, Techniques and SPC 25
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
