Process Capability - Bilateral vs. Unilateral Tolerances
kedarg6500
1. I want to know Pc study Procedure for Bilateral Tolerance
a. New Machine Qualification (Machine Capability Study)
b. Process Capability Study
For above a & B points, I want to know when we should use random sampling method (R/d2), OR Serial Sampling method (Standard deviation).
2. Which method is to be adopted for Unilateral Tolerances? - Standard deviation method OR % method (say 80 % of unilateral tolerance)
3. Also I want excel sheets for calculating PC study for all above points.
4. What is the method when subgroup size is 1
5. What is the method when total sample size is less than 25 nos
Marc
I think there are some discussion threads on each of these here, but can anyone help with 4 and 5?
There are a number of Excel spreadsheets posted as attachments to thread posts. Did you check the Attachments Listing? I'm not sure about machine capability Excel spreadsheets.
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Proving Process Capability of a Packing Machine Capability, Accuracy and Stability - Processes, Machines, etc. 6
N Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
S Regression Control Chart - Process Capability Statistical Analysis Tools, Techniques and SPC 18
M How to determine Process Capability using Minitab 17 Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Long Term Process Capability from miltiple Machines and Fixtures Capability, Accuracy and Stability - Processes, Machines, etc. 3
E What Data do we need for Welding and Repair Process Capability? Six Sigma 1
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
S What is the difference between Process Capability and Machine Capabilty Capability, Accuracy and Stability - Processes, Machines, etc. 13
V How to Assess Process Capability at the Development or Optimization Phase Capability, Accuracy and Stability - Processes, Machines, etc. 6
C Minitab Binomial Process Capability Analysis Chart Explanation Using Minitab Software 1
kedarg6500 Sample Size for Short Term & Long Term Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Is it the same process capability or performance in 8.2.3.1 and SPC? IATF 16949 - Automotive Quality Systems Standard 1
E Binomial Process Capability Sample Size - Variables Data Capability, Accuracy and Stability - Processes, Machines, etc. 4
M On Subgroups in Control Charts and Process Capability Statistical Analysis Tools, Techniques and SPC 3
N SPC and Process Capability Using a Romer Arm Statistical Analysis Tools, Techniques and SPC 6
J Interpreting Process Capability results and ratios Capability, Accuracy and Stability - Processes, Machines, etc. 1
J Go or No-Go Process Capability Quality Tools, Improvement and Analysis 8
S Process Capability with Negative Exponential Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
C Process Capability - Attribute Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
C Process Capability - Variables Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
A Cnpk (Non-Parametric Capability Analysis) to assess whether the Process is Stable Capability, Accuracy and Stability - Processes, Machines, etc. 7
V Process Capability to reconfirm the Inspection Frequency Manufacturing and Related Processes 3
B Sample Size based on Process Capability Indices (Pp/Ppk)? Capability, Accuracy and Stability - Processes, Machines, etc. 20
P Calculating Process Capability from Data of attached spreadsheet Statistical Analysis Tools, Techniques and SPC 4
D How to measure Process Capability for Homogeneous Batch Manufacturing Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Burrs affecting measurements and Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 7
G Assessing Process Capability on Variation (Hardware Adjustment Mean Shift) Capability, Accuracy and Stability - Processes, Machines, etc. 4
D Calculating Upper-CL/Lower-CL and Process Capability Statistical Analysis Tools, Techniques and SPC 8
V Defining Subgroups and Importance of Subgroups in SPC and Process Capability Statistical Analysis Tools, Techniques and SPC 6
T Process Capability - Understanding what Process Capability Indices mean Capability, Accuracy and Stability - Processes, Machines, etc. 17
Q TS 16949 Process Capability Requirements - Cpk ≥ 1.67 on All Key Parameters? IATF 16949 - Automotive Quality Systems Standard 8
S Process Capability questions - Calculating Cpu using Minitab Six Sigma 6
C Sample Size Calculation Formula for Process Capability Statistical Analysis Tools, Techniques and SPC 25
D Capability Analysis for Packing Process in Food Manufacturing Capability, Accuracy and Stability - Processes, Machines, etc. 11
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
S Process Capability on Basic Dimensions Capability, Accuracy and Stability - Processes, Machines, etc. 10
D Process Capability Study which involves MMC (Maximum Material Condition) Capability, Accuracy and Stability - Processes, Machines, etc. 8
E Process Capability Analytical Tools Statistical Analysis Tools, Techniques and SPC 1
