Process Capability for Non-Normal Data - Philosophical Questions
Y
yerasij
I am trying to answer some philosophical questions that came up in my discussions with my management. I am trying to find some answers to these questions on the Internet and my reference books. But, I have not been able to find one. Hoping that some one here might be able to help:
Background: We work with contract manufacturers (CM's) who make Injection molding parts for us. Historically, we used to collect 32Pcs. (not sure where that came from) data and calculate CpK (without understanding if the process is stable or if the distribution meets normality assumption). In the last year or two, we have been working with all our CM's to establish proper control charts and understand the stability and reduce "special causes". We overcame many challenges (trying to understand the root cause and eliminating them or adding the "causes" if it helps reduce variation etc.,) and now we are at a step where we want to improve how we understand and report out capability.
There are many CTQ's identified on the drawing (some are safety critical and some are critical to cosmetics). Now were are trying to understand the "real" capability of the process and understand # of defects shipped out.
The questions I have are:
Question 1: Lets assume an injection molded part (PC) has 5 characteristics (SPC A,B,C,D and E), and 4 of them (SPC A,B,C and D) are "non-normal". When I try to do best fit method (JMP or Minitab)- all the 4 curves have different distributions. Is it okay to pick different distributions for every characteristic ? (same parts coming from same cavities) or do I need to pick one distribution that has an "Okay" fit for all the characteristics.
Please note that I am only trying to understand the process capability (DPPM) and not trying to compare the characteristics.
The same SPC's follow a different distribution on the next set of tools (which has the same tool structured and similar process parameters). I did not see any statistical difference between the tools or cavities in means or variation.
Question 2: Why aren't the dimensions of a simple injection molded part always follow normal distribution ? I looked at the tool structure and wasn't able to find a "physical limit". Why are they not following normal distribution as expected ? Is that bad ?
Please let me know if you need any more information to help answer these questions.
It is certainly possible that different dimensions have different distributions. For example, a fixed dimension might have a different distribution than a closure dimension. Or a feature size versus a distance between features.
However, I would not expect the same dimension to vary its distribution from tool to tool unless you are including cavity to cavity variation. If this is the case, you are mixing process streams and fitting a distribution is a waste of time.
There are a number of things that cause a feature to follow a distribution other than normal. For example, take a fixed dimension such as outer diameter. The part cannot be larger than the diameter of the mold cavity, but may be smaller due to shrinkage. This would result in a skewed distribution. GD&T can artificially cause skewness by taking absolute values or using polar versus Cartesian coordinates.
If you attach data, we can better assess what you are seeing. I have Minitab, but Excel would ensure others could also assist.
Proud Liberal
I would be careful about fitting data to a distribution based on a correlation calculation (ie R square). The correct distribution should be determined by the physics of the process not the mathematics of the dataset. If the correlation to that distribution defined by the process isn't acceptable there are other factors at work that need to be identified and addressed.
(and to Miner's point, mixing process streams can only lead to false conclusions)
Statistical Steven
Statistician
I assume the 32 pieces come from the number of cavities in the mold (4,8,16 or 32).
If you combine data across cavities for any feature, your data is not normal, it is multinomial. You have to look at Cpk by cavity, then combine the Cpks in order to understand that data. I will assume (might be wrong) that each cavity on its own is normally distributed.
Let me know if this helps.
Mike S.
Happy to be Alive
How much data do you have? Thousands of parts or hundreds of thousands? Should you really be calculating PPM?
Maybe look up Dr. Wheeler's column "The Parts Per Million Problem".
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
A Cnpk (Non-Parametric Capability Analysis) to assess whether the Process is Stable Capability, Accuracy and Stability - Processes, Machines, etc. 7
F Process Capability for Non-Normal Process Statistical Analysis Tools, Techniques and SPC 5
J Capability of Inherently Non-Normal Process - Plating Process Thickness Distribution Statistical Analysis Tools, Techniques and SPC 9
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Proving Process Capability of a Packing Machine Capability, Accuracy and Stability - Processes, Machines, etc. 6
N Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
S Regression Control Chart - Process Capability Statistical Analysis Tools, Techniques and SPC 18
M How to determine Process Capability using Minitab 17 Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Long Term Process Capability from miltiple Machines and Fixtures Capability, Accuracy and Stability - Processes, Machines, etc. 3
E What Data do we need for Welding and Repair Process Capability? Six Sigma 1
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
S What is the difference between Process Capability and Machine Capabilty Capability, Accuracy and Stability - Processes, Machines, etc. 13
V How to Assess Process Capability at the Development or Optimization Phase Capability, Accuracy and Stability - Processes, Machines, etc. 6
C Minitab Binomial Process Capability Analysis Chart Explanation Using Minitab Software 1
kedarg6500 Sample Size for Short Term & Long Term Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Is it the same process capability or performance in 8.2.3.1 and SPC? IATF 16949 - Automotive Quality Systems Standard 1
E Binomial Process Capability Sample Size - Variables Data Capability, Accuracy and Stability - Processes, Machines, etc. 4
M On Subgroups in Control Charts and Process Capability Statistical Analysis Tools, Techniques and SPC 3
N SPC and Process Capability Using a Romer Arm Statistical Analysis Tools, Techniques and SPC 6
J Interpreting Process Capability results and ratios Capability, Accuracy and Stability - Processes, Machines, etc. 1
J Go or No-Go Process Capability Quality Tools, Improvement and Analysis 8
S Process Capability with Negative Exponential Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
C Process Capability - Attribute Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
C Process Capability - Variables Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
V Process Capability to reconfirm the Inspection Frequency Manufacturing and Related Processes 3
B Sample Size based on Process Capability Indices (Pp/Ppk)? Capability, Accuracy and Stability - Processes, Machines, etc. 20
P Calculating Process Capability from Data of attached spreadsheet Statistical Analysis Tools, Techniques and SPC 4
D How to measure Process Capability for Homogeneous Batch Manufacturing Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Burrs affecting measurements and Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 7
G Assessing Process Capability on Variation (Hardware Adjustment Mean Shift) Capability, Accuracy and Stability - Processes, Machines, etc. 4
D Calculating Upper-CL/Lower-CL and Process Capability Statistical Analysis Tools, Techniques and SPC 8
V Defining Subgroups and Importance of Subgroups in SPC and Process Capability Statistical Analysis Tools, Techniques and SPC 6
T Process Capability - Understanding what Process Capability Indices mean Capability, Accuracy and Stability - Processes, Machines, etc. 17
Q TS 16949 Process Capability Requirements - Cpk ≥ 1.67 on All Key Parameters? IATF 16949 - Automotive Quality Systems Standard 8
S Process Capability questions - Calculating Cpu using Minitab Six Sigma 6
C Sample Size Calculation Formula for Process Capability Statistical Analysis Tools, Techniques and SPC 25
D Capability Analysis for Packing Process in Food Manufacturing Capability, Accuracy and Stability - Processes, Machines, etc. 11
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
S Process Capability on Basic Dimensions Capability, Accuracy and Stability - Processes, Machines, etc. 10
D Process Capability Study which involves MMC (Maximum Material Condition) Capability, Accuracy and Stability - Processes, Machines, etc. 8
