Process Capability for parameters with non-normal distribution.
#11
I have attached two approaches - assuming the data is homogeneous.
The data isn't homogenous...most statistical calculations are based on the assumption/requirement of homogeneity. This is why we must ALWAYS plot our data in time series FIRST before any calculations.
bobdoering
Stop X-bar/R Madness!!
#12
It could very well be that over time this process has natural shifts - perhaps even cyclical with environmental changes. However, capability is a high level overview concept with an extremely low sampling compared to the life of the process. In this case it would indicate that so little of the tolerance is used by whatever variety of variances (from that process' total variance equation) that further process changes may have no economic value. That is, it is an appropriate process with acceptable variation.
Because total variance is the sum of all of many variances in a process, each of which can be at a different level at any time, most process output is not truly homogeneous. You have a very unique process to get all of your variations to be statistically insignificant - except one - to bear true homogeneity over time. But, agreed, plotting is surely important to understanding the types and degrees of effect of the variances in the process.
#13
...now, given the background, and based on your comment, is it reasonable to assess the (nearest) distribution based on visual/techno_functional assessment and evaluate the cpk/ppk ?
You COULD calculate a rough estimate of your capability. However, the problem with doing this, is that the process, being unstable, is also UNPREDICTABLE. This means that your estimate is only valid for the batches in the study, and may not be valid for the future batches.
#14
if you are not required to calculate Cpk/Ppk by your Customer my recommendation is to NOT do it. While it can give a high level estimate of process performance it's not precise nor is it actionable. It is not a requirement of an "SPC program". it was a misguided bolt-on in the eighties by people who were enamored of providing a "bright line" of acceptable performance: Managers who wanted a simple 'goal line' to tell them if they were 'good enough'. I have attached a paper I've written (still in progress) concerning the Perils of Process Capability Indices. It is attached. If you really want a precise, actionable quantification of your process capability, calculate and plot the actual defect rate. I know it's "old-fashioned" but that's what you are really interested in. No need to go around the proverbial barn to get to the outhouse...
Please note that even if you are bent on calculating the index, the FIRST step is an MSA. Then you plot your data in time series (read about multi-vari charts*) and look at stability. (read about rational subgrouping and the effects of non-homogeneity on statistical analysis**.) Only after these steps will you be able to understand process capability. Remember that your goal is to understand, improve and control your processes - not to calculate a Cpk index.
* multi-vari articles
If you are an ASQ member these are free:
Robert D Zaciewski and Lou Nemeth, “The Multi-Vari Chart: An Underutilized Quality Tool”, Quality Progress, October 1995, pp. 81-83
Snee, Ronald, D., “My Process is Too Variable – Now What?”, Quality Progress, December 2001
If you are an ASQ member these are available at the knowledge center fro $5, $10 if you are not. well worth the cost:
Leonard A. Seder, “Diagnosis With Diagrams – Part I”, Industrial Quality Control, January 1950, pp. 11-19
Leonard A. Seder, “Diagnosis With Diagrams – Part II”, Industrial Quality Control, March 1950, pp. 7-11
** These are available for free at Quality Digest
Wheeler, Donald, “What is a Rational Subgroup?”, Quality Digest, October, 1997 http://www.qualitydigest.com/oct97/html/spctool.html
Wheeler, Donald, “Rational Subgrouping”, Quality Digest, June 2015 http://www.qualitydigest.com/inside/quality-insidercolumn/060115-rational-subgrouping.html
Wheeler, Donald, “Probability Models do not Generate Your Data”, Quality Digest, March, 2009 http://www.qualitydigest.com/magazi...bability-models-don-t-generate-your-data.html
Wheeler, Donald, “Why We Keep Having Hundred Year Floods”, Quality Digest, June 2013, http://www.qualitydigest.com/inside/quality-insider-column/why-we-keep-having-100-year-floods.html
Wheeler, Donald, “The Secret Foundation of Statistical Analysis”, Quality Digest, December 2015 Source http://www.qualitydigest.com/inside...-secret-foundation-statistical-inference.html
Wheeler, Donald, “Statistics 101 and Data Analysis”, Quality Digest, March 2016 http://www.qualitydigest.com/inside...statistics-101-and-data-analysis-example.html
#16
How would you like your attachment, "The Perils of Process Capability Indices" cited? I would like to add it as a reference in an article I have been working on.
#17
Simply state the title, my name and that it was posted here and the date. A link to the post is most helpful.
Q TS 16949 Process Capability Requirements - Cpk ≥ 1.67 on All Key Parameters? IATF 16949 - Automotive Quality Systems Standard 8
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 10
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Proving Process Capability of a Packing Machine Capability, Accuracy and Stability - Processes, Machines, etc. 6
ncwalker Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
S Regression Control Chart - Process Capability Statistical Analysis Tools, Techniques and SPC 18
M How to determine Process Capability using Minitab 17 Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Long Term Process Capability from miltiple Machines and Fixtures Capability, Accuracy and Stability - Processes, Machines, etc. 3
E What Data do we need for Welding and Repair Process Capability? Six Sigma 1
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
S What is the difference between Process Capability and Machine Capabilty Capability, Accuracy and Stability - Processes, Machines, etc. 13
V How to Assess Process Capability at the Development or Optimization Phase Capability, Accuracy and Stability - Processes, Machines, etc. 6
C Minitab Binomial Process Capability Analysis Chart Explanation Using Minitab Software 1
kedarg6500 Sample Size for Short Term & Long Term Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Is it the same process capability or performance in 8.2.3.1 and SPC? IATF 16949 - Automotive Quality Systems Standard 1
E Binomial Process Capability Sample Size - Variables Data Capability, Accuracy and Stability - Processes, Machines, etc. 4
M On Subgroups in Control Charts and Process Capability Statistical Analysis Tools, Techniques and SPC 3
N SPC and Process Capability Using a Romer Arm Statistical Analysis Tools, Techniques and SPC 6
J Interpreting Process Capability results and ratios Capability, Accuracy and Stability - Processes, Machines, etc. 1
J Go or No-Go Process Capability Quality Tools, Improvement and Analysis 8
S Process Capability with Negative Exponential Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
C Process Capability - Attribute Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
C Process Capability - Variables Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
A Cnpk (Non-Parametric Capability Analysis) to assess whether the Process is Stable Capability, Accuracy and Stability - Processes, Machines, etc. 7
V Process Capability to reconfirm the Inspection Frequency Manufacturing and Related Processes 3
B Sample Size based on Process Capability Indices (Pp/Ppk)? Capability, Accuracy and Stability - Processes, Machines, etc. 20
P Calculating Process Capability from Data of attached spreadsheet Statistical Analysis Tools, Techniques and SPC 4
D How to measure Process Capability for Homogeneous Batch Manufacturing Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Burrs affecting measurements and Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 7
G Assessing Process Capability on Variation (Hardware Adjustment Mean Shift) Capability, Accuracy and Stability - Processes, Machines, etc. 4
D Calculating Upper-CL/Lower-CL and Process Capability Statistical Analysis Tools, Techniques and SPC 8
V Defining Subgroups and Importance of Subgroups in SPC and Process Capability Statistical Analysis Tools, Techniques and SPC 6
T Process Capability - Understanding what Process Capability Indices mean Capability, Accuracy and Stability - Processes, Machines, etc. 17
S Process Capability questions - Calculating Cpu using Minitab Six Sigma 6
C Sample Size Calculation Formula for Process Capability Statistical Analysis Tools, Techniques and SPC 25
D Capability Analysis for Packing Process in Food Manufacturing Capability, Accuracy and Stability - Processes, Machines, etc. 11
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
S Process Capability on Basic Dimensions Capability, Accuracy and Stability - Processes, Machines, etc. 10
D Process Capability Study which involves MMC (Maximum Material Condition) Capability, Accuracy and Stability - Processes, Machines, etc. 8
E Process Capability Analytical Tools Statistical Analysis Tools, Techniques and SPC 1
J Process Capability - Interview Case Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
B Overall Process Capability - Simple question if you know how to answer it! Statistical Analysis Tools, Techniques and SPC 3
