Process capability or Process control - Which comes first?
ranvir.jaryal
Hi all,
I would like to understand that in case of new process , what comes first , process control or process capability?
:rolleyes:
jrubio
Re: Process capability or Process control,what comes first?
ranvir.jaryal said:
Hi all,
:rolleyes:
You have mentioned difference concept:
process control. You have an index wich measure the efficiency of the process. i.e Number of G8D send within Time.
process capability. You have a charasterist witch control your process and this charasterist have a constrains Limit and therefore must be under these Limits.Sometimes the charasterist of the process is not in the process itself alythough is in the part.
Therefore are complementary.
i.e: Process: Stamping
process control: Oil Temperature less than 15ºC
Process Capability: width of stell within Tolerence and Cp Cpk of 3.
When the process Control Charasterist is not attribute is continual and it could be fix up Tolerance Limits the Contol process and process capability would be the same.
Tim Folkerts
I have to disagree with Javier.
Control means that you produce a product consistently. That there are no "special causes" of variation. This is typically determined by a control chart, like x-bar or p chart.
Capability means that you product a product consistenly within the specifications. This is typically determined by calculating various capability indices, like Cp or Ppk.
First you should determine that the process is in control. Then you can calculate the appropriate capabilty indices. If the process is out of control, then the capability will be changing. There is no point in calculating and reporting a value for Cpk if you expect the value will changing unpredictably.
Tim F
CarolX
Maybe I am wrong here, but this is how I see it
Capability - does the process have the ability to make the part.
Control - what checks are in place to keep the process capable of producing part.
W
wmarhel
Al Rosen said:
You need to have a stable process before you can ascertain its capability.
I agree with Al. If you reference Measuring Process Capability by Davis R. Bothe, he even states as much. I can't quote the exact excerpt as I don't have my copy handy, but I would be willing to reference the page and paragraph when I get home later.
Wayne
jrubio
Tim:
Tell me what do you think about my comments in red
Do you mean Statical Process Control?
Ppk (Un-stable) Cpk (Stable)
First you should determine that the process is under Statical control. (That menas that fits a statical distribution known) Then you can calculate the appropriate capabilty indices. If the process is out of control, then the capability will be changing. There is no point in calculating and reporting a value for Cpk if you expect the value will changing unpredictably.
Tim F
Tim Folkerts
I was thinking specifically about statistical process control when I was saying "control". As you note, it can also be used to mean the checks that are in place, as in "document control" or "control of non-conforming products".
For "capabilty", I would explicitly add "ability to make the part to the customer's specifications." It is almost implied that if you are making something, that you are making it to satisfy a particular expectation, but it never hurts to be overly clear.
I have a feeling that Cpk and Ppk are among the most abused and confused terms in quality engineering. And I can't say that I am the best authority on the proper use and meaning of the terms.
In my understanding, Ppk and Cpk are two different measures of capability that tell you two similar but not identical things about a process. Both should only be calculated when the process is reasonably stable and "in control".
Tim F
jrubio
:agree1:
Generally I agree but if you have a none stable process you can calculate the capability index also the problem is that this capability is named ppk instead of Cpk
jrubio
Tim F
Tim I disagree
Ppk is the capability when the process is not stable. Please Refer to
PPAP Manual page 7 Third Edition.
When the process becomes stable the index must be Cpk.
Please read page 7
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Proving Process Capability of a Packing Machine Capability, Accuracy and Stability - Processes, Machines, etc. 6
N Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
S Regression Control Chart - Process Capability Statistical Analysis Tools, Techniques and SPC 18
M How to determine Process Capability using Minitab 17 Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Long Term Process Capability from miltiple Machines and Fixtures Capability, Accuracy and Stability - Processes, Machines, etc. 3
E What Data do we need for Welding and Repair Process Capability? Six Sigma 1
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
S What is the difference between Process Capability and Machine Capabilty Capability, Accuracy and Stability - Processes, Machines, etc. 13
V How to Assess Process Capability at the Development or Optimization Phase Capability, Accuracy and Stability - Processes, Machines, etc. 6
C Minitab Binomial Process Capability Analysis Chart Explanation Using Minitab Software 1
kedarg6500 Sample Size for Short Term & Long Term Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Is it the same process capability or performance in 8.2.3.1 and SPC? IATF 16949 - Automotive Quality Systems Standard 1
E Binomial Process Capability Sample Size - Variables Data Capability, Accuracy and Stability - Processes, Machines, etc. 4
M On Subgroups in Control Charts and Process Capability Statistical Analysis Tools, Techniques and SPC 3
N SPC and Process Capability Using a Romer Arm Statistical Analysis Tools, Techniques and SPC 6
J Interpreting Process Capability results and ratios Capability, Accuracy and Stability - Processes, Machines, etc. 1
J Go or No-Go Process Capability Quality Tools, Improvement and Analysis 8
S Process Capability with Negative Exponential Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
C Process Capability - Attribute Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
C Process Capability - Variables Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
A Cnpk (Non-Parametric Capability Analysis) to assess whether the Process is Stable Capability, Accuracy and Stability - Processes, Machines, etc. 7
V Process Capability to reconfirm the Inspection Frequency Manufacturing and Related Processes 3
B Sample Size based on Process Capability Indices (Pp/Ppk)? Capability, Accuracy and Stability - Processes, Machines, etc. 20
P Calculating Process Capability from Data of attached spreadsheet Statistical Analysis Tools, Techniques and SPC 4
D How to measure Process Capability for Homogeneous Batch Manufacturing Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Burrs affecting measurements and Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 7
G Assessing Process Capability on Variation (Hardware Adjustment Mean Shift) Capability, Accuracy and Stability - Processes, Machines, etc. 4
D Calculating Upper-CL/Lower-CL and Process Capability Statistical Analysis Tools, Techniques and SPC 8
V Defining Subgroups and Importance of Subgroups in SPC and Process Capability Statistical Analysis Tools, Techniques and SPC 6
T Process Capability - Understanding what Process Capability Indices mean Capability, Accuracy and Stability - Processes, Machines, etc. 17
Q TS 16949 Process Capability Requirements - Cpk ≥ 1.67 on All Key Parameters? IATF 16949 - Automotive Quality Systems Standard 8
S Process Capability questions - Calculating Cpu using Minitab Six Sigma 6
C Sample Size Calculation Formula for Process Capability Statistical Analysis Tools, Techniques and SPC 25
D Capability Analysis for Packing Process in Food Manufacturing Capability, Accuracy and Stability - Processes, Machines, etc. 11
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
S Process Capability on Basic Dimensions Capability, Accuracy and Stability - Processes, Machines, etc. 10
D Process Capability Study which involves MMC (Maximum Material Condition) Capability, Accuracy and Stability - Processes, Machines, etc. 8
E Process Capability Analytical Tools Statistical Analysis Tools, Techniques and SPC 1
