Process Capability Study which involves MMC (Maximum Material Condition)
D Moore
Hello.
I have been asked to carry out a capability study which involves MMC.
We are manufacturing Flywheels for Ford motor company and a significant characteristic required by them is the position of a timing slot. The spec is 0.2 relative to a flat datum but also to to the flywheel bore and another datum hole.
Can a study be carried out as my UTL will be different for every component, dependent upon the measured size of the two datum holes?
If it is possible how do i go about it?
Stijloor
Hello.
Is it possible to attach a sketch? Does Ford refer to ASME or the ISO GD&T standard? For our Members: what does UTL mean?
Stijloor.
Duke Okes
Why will USL be different? Isn't it relative to the center of the hole rather than to the edge?
If not, then I would guess you might need to record your values as +/- from nominal, or from the UTL.
Rand T
I have struggled with this as well. The problem is that with bonus tolerance, the tolerance is increased depending upon the feature size. Therefore it may change with each and every part. It would appear that it may be necessary to perform the capability without consideration of the MMC bonus and hope it is capable and that the bonus will just act as a comfort factor.
W
world quality
I agree with Randy, and sense there was not a drawing or sketch provide and to sense this is a flywheel, It has to be heat treated, what is the GDT, before HT and after HT. Each part will be different in dimensional size.
Stijloor
Hello.
A capability study that include the MMC principle is a quite a challenging issue.
This thread provides excellent insights.
As well as this thread.
BTW, we would like to see your drawing though...;)
Stijloor.
Paul F. Jackson
D. Moore
If the MMC modifiers are designated only on the secondary and tertiary datum features…
then no “coordinate system mobility” shift allowance would be permitted to verify any one feature individually. The rules concerning simultaneous requirements provide that the “coordinate system mobility” shift allowance be applied to all identically datum referenced feature controls simultaneously.
Even though with some CMM software it is possible to apply this allowance independently when assessing individual feature displacements it is wrong. I used to counsel all of the CMM programmers to disable the datum feature bonus option. There are some gage simulation packages however that can perform the calculation correctly but care has to be taken that all affected feature tolerances are included in the simulation.
On the flex plate or flywheel the pilot diameter mating with the crankshaft generally is a very tight fit designed to prevent datum shift thereby preventing circumstantial imbalance. Even though one of the flywheel to crank fastener holes in the pattern is offset a few degrees from equal spacing to prevent the part from being assembled backwards… the bolt clearances in the pattern are generally identical and therefore would contribute to the functional variability of the timing mark to the crank rotation. That is a problem that would only be exacerbated by allowing increased rotational tolerance of the mark to the clearance hole pattern. Chances are the MMC modifiers are not designated with regard to function.
If the MMC modifiers are designated on the timing mark size itself
Typically the variable portion of location tolerance is ignored in capability prediction equations because variable limit geometric tolerances are not generally recognized or understood by statistical types.
To add to that...
MMC is often used on engineering drawings and applied to a "feature of size" simply because it is a "feature of size". That mentality has propogated itself throughout industry to serve those that want to have "GO attribute Gages" for "in-process" inspection.
Can the capability be predicted using the variability of the variable portion of tolerance? Yes... Read on in the threads that Stijloor referenced and find the thread that has my spreadsheets and powerpoint presentation in it.
Should the capability be predicted using the variability of the variable portion of tolerance? Sometimes Yes and Sometimes NO… In this case I would say NO!
You can easily determine if a material condition modifier (applied to the feature tolerance) is functionally appropriate by answering a simple question. "Does the feature's ideal function worsen as its location and/or orientation tolerance is permitted to increase with size" If the answer to that is No then the MMC capability is appropriate. If the answer to that is yes (as I suspect it is with the timing mark) then it is not!
The timing mark should be oriented to the datum features as good as possible all the time without respect to size.
In summary if the MMC modifiers are applied only to the datum features, they shouldn’t be functionally (my opinion) furthermore it is wrong to use the allowance in your timing mark location capability prediction independent of other identically referenced tolerances.
If the modifier is applied to the mark location then technically you have the right to use the variable portion of tolerance in the prediction even though it is non-functional application.
Tell your Ford STA person to look for Variable Limit Tolerance Capability Analysis on the Ford Powertrain Quality website then they might understand what they are asking for… I put it there before I left. When the modifiers are applied functionally then feature sizes can be targeted to optimize the capability of the variable limit tolerances and their associated sizes simultaneously i.e. Ppk of “zero at MMC” specifications.
Paul
Sathyanarayanan
I seem to be getting into this quite late and may be the interested parties are already clear on the issue. My recommendation would be to calculate the percentage of tolerance with bonus used on every reading and use the variance in percentages compared to 100% allowed as tolerance for calculating the Cpk. This method has some shortcomings but is the closest to what I would look for and the easiest to handle in the shop floor
Paul F. Jackson
Sathyanarayanan,
There are several methods that people have used to predict conformance of "variable limit specifications" and you are correct that the "percent of tolerance" method (first used a long time ago in GM's fuel handling department and documented by Marty Ambrose) is probably the easiest to understand and apply... but I would say that it is the least accurate of the methods for making the conformance prediction.
It is that way because each instance of size and geometric deviation is converted to a ratio... so a large "bonus tolerance" and a large deviation can produce an identical ratio to a small "bonus tolerance" and a small deviation. The problem is that the underlying separate sources of variation are masked in the surrogate ratio.
This topic has been addressed in numerous other threads on this site for further reading.
Best regards,
Paul
N Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
J Process Capability - Interview Case Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
A Process Capability Study using Variables Data (weight of the product) Statistical Analysis Tools, Techniques and SPC 9
M Capability Study on a New Machining Process - Issues Capability, Accuracy and Stability - Processes, Machines, etc. 40
A Process Capability study of CNC Machining Process Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Process Capability Study for Electrostatic Powder Coating Statistical Analysis Tools, Techniques and SPC 6
J Process Capability Sheet for a short term 30 piece study needed Statistical Analysis Tools, Techniques and SPC 1
B CNC test pieces for milling and turning - I need to run a process capability study General Measurement Device and Calibration Topics 2
E Minumim number of parts to conduct the Process Capability Study APQP and PPAP 18
D Where can I find Process & Machine Capability study software? Statistical Analysis Tools, Techniques and SPC 3
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Proving Process Capability of a Packing Machine Capability, Accuracy and Stability - Processes, Machines, etc. 6
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
S Regression Control Chart - Process Capability Statistical Analysis Tools, Techniques and SPC 18
M How to determine Process Capability using Minitab 17 Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Long Term Process Capability from miltiple Machines and Fixtures Capability, Accuracy and Stability - Processes, Machines, etc. 3
E What Data do we need for Welding and Repair Process Capability? Six Sigma 1
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
S What is the difference between Process Capability and Machine Capabilty Capability, Accuracy and Stability - Processes, Machines, etc. 13
V How to Assess Process Capability at the Development or Optimization Phase Capability, Accuracy and Stability - Processes, Machines, etc. 6
C Minitab Binomial Process Capability Analysis Chart Explanation Using Minitab Software 1
kedarg6500 Sample Size for Short Term & Long Term Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Is it the same process capability or performance in 8.2.3.1 and SPC? IATF 16949 - Automotive Quality Systems Standard 1
E Binomial Process Capability Sample Size - Variables Data Capability, Accuracy and Stability - Processes, Machines, etc. 4
M On Subgroups in Control Charts and Process Capability Statistical Analysis Tools, Techniques and SPC 3
N SPC and Process Capability Using a Romer Arm Statistical Analysis Tools, Techniques and SPC 6
J Interpreting Process Capability results and ratios Capability, Accuracy and Stability - Processes, Machines, etc. 1
J Go or No-Go Process Capability Quality Tools, Improvement and Analysis 8
S Process Capability with Negative Exponential Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
C Process Capability - Attribute Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
C Process Capability - Variables Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
A Cnpk (Non-Parametric Capability Analysis) to assess whether the Process is Stable Capability, Accuracy and Stability - Processes, Machines, etc. 7
V Process Capability to reconfirm the Inspection Frequency Manufacturing and Related Processes 3
B Sample Size based on Process Capability Indices (Pp/Ppk)? Capability, Accuracy and Stability - Processes, Machines, etc. 20
P Calculating Process Capability from Data of attached spreadsheet Statistical Analysis Tools, Techniques and SPC 4
D How to measure Process Capability for Homogeneous Batch Manufacturing Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Burrs affecting measurements and Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 7
G Assessing Process Capability on Variation (Hardware Adjustment Mean Shift) Capability, Accuracy and Stability - Processes, Machines, etc. 4
D Calculating Upper-CL/Lower-CL and Process Capability Statistical Analysis Tools, Techniques and SPC 8
