Process Capability - Understanding what Process Capability Indices mean
bobdoering
Stop X-bar/R Madness!!
#11
I know this was supposed to be a general overview of Cpk and Cp, but I wanted to point out that even when your Cpk is less than 1 (which means one or both of your upper/lower control limits are outside of the specification limit) that your data values may still be within the specification limits (i.e. - all of your parts still meet engineering conformance).
That is incorrect. Cp and Cpk are functions of the specification, not the control limits.
Cp= (USL-LSL)/6sigma; Cpk is lesser of USL-Xbar/3 sigma; Xbar-LSL/3 sigma
USL=Upper Specification Limit
LSL=Lower Specification Limit
So, a Cp of less than 1 means parts are out of specification, not out of control.
dickgent
#12
the cpk was 26 or something!!!! what am i doing wrong -- You have done nothing wrong. A large Cpk indicates that the process is capable of holding that tolerance. The probability of producing that feature out of tolerance is VERY small. OPTION I -- You can reduce you inspection requirements for that dimension and eventually eliminate it entirely (with random checks now and then). OPTION II - Improve the part by reducing the tolerances ONLY if that will improve your product and adds value to the down line assembly or the end user.
Look for other critical to manufacture features and use your inspection resources to study (CPk) improve them.
I have said it many times Use your Cpk values as tools to identify continuous improvement opportunities.
For the previous posts
CPk = spread
CP = central tendency (centered Mean) indicates a potential nominal shift
1 standard deviation = .33333 Cpk
+-6 standard deviations = 2.0 Cpk
Hope this helps
bobdoering
#13
It may also mean not all of the variation over the life of the process has been captured by the sample, or that there is sampling error. This is quite common with precision machining, die stamping, etc.
F
f1guru
#14
guys thank you for all the posts, its a steep learning curve we are going thru as we have never needed to look at process controls before due to what we manufacture. I think that with the tolerance we have of 0.8Ra max and all our measurements are 0.03 to 0.05 the process is well in control!!!
Thanks again it is much appreciated:bigwave:
dickgent
#15
OK .... now you changed things... :rolleyes: If you are studying Ra then it is a unilateral tolerance (cannot be less than zero). Therefore only 1/2 of the normal curve applies. You can use the Cp and CPk calculations for unilateral tolerances as described elsewhere on this site. Good Luck to you.
http://elsmar.com/Forums/showthread.php?t=6552
bobdoering
#16
"Half of a normal curve" does not apply.
First, it is an inadequate model - as it does not fit the data adequately at all. Weibull or beta generally are a much better model of unilateral tolerance behavior.
Secondly, calculating Cpk based on only one of either Cpu or Cpl is generally meaningless. Cpk is specifically designed to tell if the distribution is centered. So, first, it needs to make sense that it is centered, which it does not make sense with a unilateral tolerance with the target at zero. What it actually describes is the distance the mean is from the tolerance. That is a totally different question than if the mean is centered. So, just because you can calculate it, does not make it meaningful.
I used to use half normal, until I learned more about the applicable statistics. It is a common approach for people trying to meet a customer's rubber stamp request for Cpk on any and every kind of characteristic. Unfortunately, it is incorrect.
bearfan454
#17
You could tighten the spec limits. It would lower the cpk value but it would also show continuous improvement.
bobdoering
#18
Not always. For precision machining, that reduces stability by requiring more operator intervention and more adjusting - so the idea of reducing the control limits is not always "continuous improvement". Continuous improvement for precision machining is decreasing the tool wear slope - either with better tooling or improved process parameters.
And you should never tighten the product spec limits. They are design limits - and their meaning should represent the area under the the Taguchi loss function curve (calculated for that specific characteristic) where the dimension actually works - by design. You can tighten process specification, but never print specs. You will lose extremely valuable data that has a specific meaning.
B Two excellent examples of process capability analysis from Quality Magazine Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Process Capability in a High Precision Environment Capability, Accuracy and Stability - Processes, Machines, etc. 7
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Proving Process Capability of a Packing Machine Capability, Accuracy and Stability - Processes, Machines, etc. 6
N Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
J Process Capability - How much percentage of tolerance? VDA Standards - Germany's Automotive Standards 3
S Regression Control Chart - Process Capability Statistical Analysis Tools, Techniques and SPC 18
M How to determine Process Capability using Minitab 17 Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 6
B Long Term Process Capability from miltiple Machines and Fixtures Capability, Accuracy and Stability - Processes, Machines, etc. 3
E What Data do we need for Welding and Repair Process Capability? Six Sigma 1
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
S What is the difference between Process Capability and Machine Capabilty Capability, Accuracy and Stability - Processes, Machines, etc. 13
V How to Assess Process Capability at the Development or Optimization Phase Capability, Accuracy and Stability - Processes, Machines, etc. 6
C Minitab Binomial Process Capability Analysis Chart Explanation Using Minitab Software 1
kedarg6500 Sample Size for Short Term & Long Term Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Is it the same process capability or performance in 8.2.3.1 and SPC? IATF 16949 - Automotive Quality Systems Standard 1
E Binomial Process Capability Sample Size - Variables Data Capability, Accuracy and Stability - Processes, Machines, etc. 4
M On Subgroups in Control Charts and Process Capability Statistical Analysis Tools, Techniques and SPC 3
N SPC and Process Capability Using a Romer Arm Statistical Analysis Tools, Techniques and SPC 6
J Interpreting Process Capability results and ratios Capability, Accuracy and Stability - Processes, Machines, etc. 1
J Go or No-Go Process Capability Quality Tools, Improvement and Analysis 8
S Process Capability with Negative Exponential Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
C Process Capability - Attribute Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
C Process Capability - Variables Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
A Cnpk (Non-Parametric Capability Analysis) to assess whether the Process is Stable Capability, Accuracy and Stability - Processes, Machines, etc. 7
V Process Capability to reconfirm the Inspection Frequency Manufacturing and Related Processes 3
B Sample Size based on Process Capability Indices (Pp/Ppk)? Capability, Accuracy and Stability - Processes, Machines, etc. 20
P Calculating Process Capability from Data of attached spreadsheet Statistical Analysis Tools, Techniques and SPC 4
D How to measure Process Capability for Homogeneous Batch Manufacturing Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Burrs affecting measurements and Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 7
G Assessing Process Capability on Variation (Hardware Adjustment Mean Shift) Capability, Accuracy and Stability - Processes, Machines, etc. 4
D Calculating Upper-CL/Lower-CL and Process Capability Statistical Analysis Tools, Techniques and SPC 8
V Defining Subgroups and Importance of Subgroups in SPC and Process Capability Statistical Analysis Tools, Techniques and SPC 6
Q TS 16949 Process Capability Requirements - Cpk ≥ 1.67 on All Key Parameters? IATF 16949 - Automotive Quality Systems Standard 8
S Process Capability questions - Calculating Cpu using Minitab Six Sigma 6
C Sample Size Calculation Formula for Process Capability Statistical Analysis Tools, Techniques and SPC 25
D Capability Analysis for Packing Process in Food Manufacturing Capability, Accuracy and Stability - Processes, Machines, etc. 11
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
S Process Capability on Basic Dimensions Capability, Accuracy and Stability - Processes, Machines, etc. 10
D Process Capability Study which involves MMC (Maximum Material Condition) Capability, Accuracy and Stability - Processes, Machines, etc. 8
E Process Capability Analytical Tools Statistical Analysis Tools, Techniques and SPC 1
J Process Capability - Interview Case Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
