Process changes
Martin
I had a question: I have difficulty with the fact what exactly a process change (4.9.5.) is. I will give an example. If our operators change the setting of the machinery I think it's a process change, but if we have to register every time that happens the paperwork isn't "funny" anymore. Can somebody give me a good explanation of process change?
Thanks in advance,
Martin
Marc
Fully vaccinated are you?
Is this in regard to resubmission of PPAP to address an 'official' process change?
Martin
It isn´t regard to resubmission, because I get that, but it´s regard to point 4.9.5. Which states the following:
The supplier shall maintain records of process change effective dates. (see 4.5.3.)
Note: Changes to promote continuous improvement are encouraged. Consult the customer for guidance on approval requirements for such changes.
And I don´t know how I must see the process changes in this case. The same as with the PPAP submission. Maybe you could tell me...
Thanx anyway,
Martin
Marc
If you change a stated process parameter it is a process change. If you change a set-up procedure, a control plan (one or more items) or other process particular, you are changing the process. Typically this is a non-issue as the documents are controlled and as such a history of changes is found in the documents themselves. Most companies look to their Engineering Change System as the repository of a history of process changes and their implementation dates/times. An important factor is looking at this with regard to traceability as well.
What requires resubmission of PPAP is variable and has been discussed in a number of threads here. Do a Search here (maybe for 'resubmit' or PPAP). If you don't find anything, come back to this thread and let me know. I'll help out from there. OK?
Martin
OK.. I get it, so I don´t have to document every change that my operators make when the change the parameters am I right? Because the way I see it now is that you have a total process change (changing set up instructions, process flow, etc.) or part process change (changing parameters)....
Thanx, Martin
Marc
You have a lathe operation. You notice that you are getting a 'trail' on your piece. Your inspection shows that although this 'trail' is visible, the part passes your surface roughness requirement. You slow down feed rate 10% from set-up and the problem worsens. The operator increases the feed rate 20% from set-up and the problem goes away. The responsible engineer changes the CNC set-up program to reflect this 20% increase. Is this a process change? I wouldn't classify it as such but you can get an arguement that it is. It really has no effect on the product - it was passing (technically) prior to the change and the change of a feed rate is not (opinion on word choice) significant.
You have to make some decisions on a case by case basis what is 'significant' to your process.
Where operators can make adjustments they are typically 'minor' - you want an engineer involved if a 'major' problem arises. Where the operators are 'tuning', they are not really changing the process. In the lathe example operators are allowed to adjust feed rate +/- 30% from set-up. They do not have to get authorization to do this. However - it is expected that the responsible engineer (or other 'authority') be (in general) monitoring what is going on so that s/he knows if every operator on every shift is always setting the feed rate up 20%. The operators are not, however, required to record the change unless it is in response to an out-of-control condition where it is recorded on the control chart.
However, if you change the set-up instruction it technically becomes a process change, but is it significant? Not in my opinion. I don't believe 4.9.5 is meant to control this type of minor process change. I see 4.9.5 as important in more 'significant' process changes such as a change from a grind to a hone, a large process parameter change (such as mold temperature or hold time in injection molding) or a sequence change.
[This message has been edited by Marc Smith (edited 23 May 2000).]
R Changes vs CMO - How can we simplify this process? Supplier Quality Assurance and other Supplier Issues 3
L Process changes and biocompatibility (ISO 10993-1) Other Medical Device Related Standards 1
K Changes in process dispersion, and location hypotheses tests Using Minitab Software 3
V IATF 16949 9.2.2.1 Internal Audit Program - "Process Changes" IATF 16949 - Automotive Quality Systems Standard 11
M Informational New Zealand – Changes to Medical Device Adverse Event Reporting process Medical Device and FDA Regulations and Standards News 0
S Qualification Builds & Process Changes (AS9102 - First Article Inspection) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
O PFMEA - Reducing Severity (S) Ranking - Manufacturing Process Design Changes FMEA and Control Plans 4
A Process Changes, but Work Instructions/Process Maps are not updated ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Q Form for Managing Coating Process Parameter Changes during Production Document Control Systems, Procedures, Forms and Templates 2
J Process Changes - Customer Notification Requirements APQP and PPAP 12
R Verification of Process Changes (AS9100 clause 7.5.1.2) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
AnaMariaVR2 FDA, Suppliers, & Process Changes [article] Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M AS 9100 4.2.4 Process for making changes to records is not fully effective Quality Manager and Management Related Issues 4
V ECR/DCR Process Flow - What changes require an ECR vs. a DCR Document Control Systems, Procedures, Forms and Templates 2
L Changes to Manufacturing Process or Device with CE Marking CE Marking (Conformité Européene) / CB Scheme 2
M Changes Assessment as per AS9100 Clause 7.5.1.2 Control of Production Process Changes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T How to link Process Design Changes in Serial Production to Design & Development? Design and Development of Products and Processes 6
M Document Changes not affecting the process - Adding Logos, etc. Document Control Systems, Procedures, Forms and Templates 8
5 Changes to Control Plans or PFMEA's (Process FMEA) FMEA and Control Plans 6
M Process changes related to Components APQP and PPAP 4
R Informing Customers of Process Changes - Is this considered a process change? Manufacturing and Related Processes 19
R Preventative Action - Organizational ideas - Process or Work Instruction Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S PPAP for my tier 3 suppliers - Sub-Supplier Process Changes APQP and PPAP 16
M Looking for Best Way to Communicate Process Changes to Production Employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G Defining Process Changes and Customer Notification Requirements IATF 16949 - Automotive Quality Systems Standard 33
R Manufacturing Process Changes (7.1.4) IATF 16949 - Automotive Quality Systems Standard 3
J Process Control / Changes QS-9000 - American Automotive Manufacturers Standard 13
K APQP - Is the APQP process supposed to include process changes? APQP and PPAP 2
S Consolidated Analysis Report for Moulding Process Manufacturing and Related Processes 1
P ISO 11607-2 Process Specification Other Medical Device Related Standards 1
Q Best off presentation of process flows Process Maps, Process Mapping and Turtle Diagrams 10
Q Logistics process flow ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Process FMEA for Laser Cutting/Press Brake/Welding FMEA and Control Plans 2
H Control of Change i.e. process and WI IATF 16949 - Automotive Quality Systems Standard 9
F Is this misuse of the MRB process? Manufacturing and Related Processes 7
L Product and process Deviation procedure Manufacturing and Related Processes 1
Ch00Ch00 How to evaluate a process ? Document Control Systems, Procedures, Forms and Templates 3
M Implants made by Additive Manufacturing process approved by USFDA Other Medical Device and Orthopedic Related Topics 1
Q Process Key figures and reporting ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Ch00Ch00 Evaluate a process - Issue number Lean in Manufacturing and Service Industries 7
F Rules of process outsourcing in China China Medical Device Regulations 1
B Process / Procedure - Radiographic (X-Ray) Non-Film Document Control Systems, Procedures, Forms and Templates 0
P Certification process for registered device China Medical Device Regulations 12
J NCR- Failure of contract review process - NADCAP audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Melissa Process Validation of Rotary Heat Sealer Speeds Design and Development of Products and Processes 4
C Validation of process for releasing the UDI EU Medical Device Regulations 4
Melissa Risk Management Process, How far do I need to go? ISO 14971 - Medical Device Risk Management 10
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 9
Z IA Construction Procurement Process Internal Auditing 3
H Risk Management Plan in agile process ISO 14971 - Medical Device Risk Management 14
