Process Effectiveness and Efficiency (IATF 16949)
Blaest
#21
IATF 16949:2016
9.2.2.2 Quality management system audit
"The organization shall audit all quality management system processes.. ..using the process approach.."
Would it be correct to state we would need to differentiate between exactly 3 type of processes?
  • 9.2.2.2: “..quality management system processes”
  • 5.1.1.2: “..product realization processes”
  • 5.1.1.2: “..support processes”
If so, how would I define/differentiate between the processes?
jfriess
#22
I agree we have 5 main processes but the IATF 16949 standard states that you must have a "process" for 23 (I think) items with in the standard. Examples are 4.4.1.2product safety, 8.4.1.2 external provider selection, 8.4.2.4 external provider monitoring, 8.4.2.1 type and extent of control (external provider), 8.4.2.2 statutory and regulatory requirement (external provider), 7.1.5.2.1 calibration and verification, 7.1.5.3.1 internal laboratory, 7.2.1 competency, 7.2.3 internal auditor competency, 7.3.2 employee motivation and empowerment, 7.5.3.2.2 engineering specifications, 8.3.1.1 design and development, 8.3.3.2 manufacturing process design input, 8.3.5.2 manufacturing process design output, 8.5.1.5 total productive maintenance, 8.5.6.1 control of changes, 8.7.1.4 control of reworked product, 8.7.1.5 control of repaired product, 8.7.1.7 nonconforming product disposition, 9.2.2.1 internal audit, 10.2.3 problem solving, 10.2.4 error proofing, 10.3.1continual improvement.
My question is how is everyone monitoring these for effectiveness and efficiency? If not, how are they not? I am changing auditors so hopefully this will help me, but has anyone that has gotten certified to the new standard ran into this issue and how did they handle it.
I know I answered your question with a questions, but I am still unsure.
I agree with the people that have supported that this is not needed, but just want to make sure that i am covered in the event that another auditor "interprets" the standard the same was...
Golfman25
#23
We combine them. For example you cite several processes which have to do with suppliers and purchasing. Those are all part of our purchasing process. We keep our metrics on that main process. Your auditor is out of his mind.
jfriess
#24
I was hoping someone would say to combine them. That is what I have been doing!! Thanks!!
Just glad that I have the opportunity to change auditors:) That is not always the case
David J Quality
#25
Re: Process effectiveness and efficiency
Howste,
what is the difference of effectiveness and efficiency or is there a difference? Should there be some sort of separate measurement for each for each process?
Thank you!
Sidney Vianna
Post Responsibly
#26
Sorry, I linked a wrong definition. The correct ones are from ISO 9000:2015.
3.7.10 efficiency
relationship between the result achieved and the resources used
3.7.11 effectiveness
extent to which planned activities are realized and planned results are achieved
Note 1 to entry: This constitutes one of the common terms and core definitions for ISO management system standards given in Annex SL of the Consolidated ISO Supplement to the ISO/IEC Directives, Part 1. The original definition has been modified by adding “are” before “achieved”.
Golfman25
#27
Howste,
Thank you!
For IATF you'll need an effectiveness and an efficiency measurement for each process. For many processes it is silliness. Try to combine as many as possible to keep your numbers down.
#28
Look at the Main Processes (we have ours listed in our Quality Manual). For example, we measure the effectiveness of our Production Order Fulfillment process by on time shipments and customer complaint volume. We measure the efficiency of it by our scrap percentage and premium freight costs. Hope this might help you.
howste
Thaumaturge
#29
Howste,
Thank you!
Sidney gave you the right definitions. In layman's terms effectiveness is getting the right result. Efficiency is determining what it costs you (time, $, resources) to get the result.
Generally they aren't measured in the same way.
AMIT BALLAL
#30
Effectiveness:
Whether you are getting desired result. This is generally referred as quality (Of output of the process).
Eg. 1. If you go to a restaurant, if the quality of food / service is good, then you can say its effective.
2. For maintenance processes, output required is less breakdowns of machines (Machines should be in good condition). You can measure no. of breakdowns / breakdown hours for this, which will become measure of effectiveness.
Efficiency:
Extent to which cost, effort, time are well utilized.
Eg. 1. If the price of the food is too much, then it is not efficient.
2. For maintenance process, if the cost of spares is high, then is not efficient.
For efficiency measurement, you can use various measurements such as following(Other than examples stated above):
Eg. For time: Time taken to deliver food / Mean Time To Repair (MTTR)- related to maintenance
For effort: Plan Vs actual adherence to Maintenance plan (Whether your efforts are in right direction/ relevant)
For cost: Cost of Poor quality
You require both effectiveness and efficiency. And measuring only one thing is not helpful.
Regards,
Amit
A IATF 16949 - Non-conformity on 5.1.1.2 Process effectiveness and efficiency IATF 16949 - Automotive Quality Systems Standard 5
B IATF 16949 Cl. 7.3.2 - Documented Process (Effectiveness & Efficiency) IATF 16949 - Automotive Quality Systems Standard 7
G Reviewing Process Effectiveness and Efficiency IATF 16949 - Automotive Quality Systems Standard 5
M Effectiveness and Efficiency - Process Objective Determination IATF 16949 - Automotive Quality Systems Standard 7
G Process Efficiency vs. Process Effectiveness for TS 16949 IATF 16949 - Automotive Quality Systems Standard 3
B Process Performance Parameters for efficiency and effectiveness Manufacturing and Related Processes 1
L Measureables: Efficiency - Effectiveness of COP (Customer Oriented Process) and KSP ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T Hot dogs and process operation and control effectiveness? 4.1.3 a) ISO 13485:2016 - Medical Device Quality Management Systems 2
S ISO 9001:2015 4.4.1 (c) Process Effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
D Do people read PEARS (Process Effectiveness Assessment Report)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
B IATF 16949 Cl. 9.3.2.1 - Management Review Inputs - Process Effectiveness and Efficie IATF 16949 - Automotive Quality Systems Standard 14
S AS9100C 8.2.2 - Selected Tools & Effectiveness of IA Process and Performance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Buckyb Are KPIs a requirement to determine Process Effectiveness? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
R The Value and Effectiveness of In Process Inspection Quality Manager and Management Related Issues 17
Q PEAR (Process Effectiveness Assessment Report) Requirements for AS9100 Registration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J What Practices Undermine the Effectiveness of the A3 Process? Lean in Manufacturing and Service Industries 2
J How to measure effectiveness of the Metrology Process General Measurement Device and Calibration Topics 5
Chennaiite How to Measure Effectiveness of the Design Validation Process? Design and Development of Products and Processes 7
P Measuring Process Effectiveness - Measures of Effectiveness (MOE's) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 29
W Process Effectiveness NCR's (Nonconformance Reports) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna AS9101 Process Effectiveness Assessment Report/Nonconformance Record Review Modules AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
D AS9100C PEAR (Process Effectiveness Assessment Report) for Design and Development AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Q How do you determine Process Effectiveness for AS9100C Process Maps, Process Mapping and Turtle Diagrams 11
B AS9120A Process Effectiveness Assessment Report Forms AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 23
A How to calculate the Effectiveness of the Process and Product Audit System Internal Auditing 10
E Measuring Receiving Inspection Process Effectiveness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P AS9100:C PEARs (Process Effectiveness Assessment Report) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 171
A What is the difference between Process Objectives & Criteria for Effectiveness? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M How to increase survey response rate? - Process Effectiveness metric Six Sigma 5
P Audit of the Manufacturing Process Effectiveness - 8.2.2.2 IATF 16949 - Automotive Quality Systems Standard 10
H LPA's (Layered Process Audits) - Evaluation of Effectiveness Process Audits and Layered Process Audits 22
S How to Evaluate the Effectiveness of a Work Instruction during the Approval Process? Document Control Systems, Procedures, Forms and Templates 13
M Showing the Effectiveness of the Internal Audit Process System - AS9100B Clause 8.2.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
G Process Effectiveness Metric for the process ?Internal Audit? Internal Auditing 25
C Evaluating the Effectiveness of Internal Audit Process Internal Auditing 16
P Effectiveness of a manufacturing process? General Auditing Discussions 8
J Determining effectiveness of APQP Process throughout our entire organization Preventive Action and Continuous Improvement 4
E Difficulties with Process Approach - Defining 'Effectiveness' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 59
D Process and Product Audit Checklist - Product Realization, Effectiveness of Process General Auditing Discussions 8
A Complaint review as part of the complaint handling process? ISO 13485:2016 - Medical Device Quality Management Systems 2
mustomutlu Process Validation Final Report Other Medical Device and Orthopedic Related Topics 2
Q Process Matrix_Audit Matrix Quality Management System (QMS) Manuals 4
Q Process description for outsourced processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Process matrix examples of ISO 9001 & 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A When someone refuses to follow a process.... Misc. Quality Assurance and Business Systems Related Topics 21
