Process Flow Chart is a Work Procedure or a Work Guide, or a Work Instruction
Ettore
#11
Re: Process Flow Chart is a Work Procedure?
.....................................................................................................................................................................................................................................................logically be a WI.
This morning I got up early and now here is too late so that is difficult finish to read yours thread.
I would like just say that twenty year ago :mg: I've seen at Klöckner steel plant in Bremen a wonderfull collection of procedures that was writed using only Flow charts
:bigwave:
#12
Thanks for the information.
I therefore conclude that process flow chart is regarded as under statement letter e. But again, work procedures and work instruction is both described on letter e as one, does it mean that work instructions and work procedures can be used interchangebly? They dont differ on either way?
WI = WP?
A process flowchart is a process flowchart. It's also a document. Those are the only two descriptions you need. Concern yourself with the contents, not the container.
jm1231
#13
Now it is crystal clear to me! A process flow chart is a work procedure while a manufacturing manual is a work instructions. Thanks a lot.
John Martinez
#14
Don't call it too late for dinner....:biglaugh:
ISO 9000:2005
3.4.5 procedure specified way to carry out an activity or a process
JaneB
#15
I hate to pop your bubble, but I would not agree that a process flowchart and a work procedure are synonymous terms. They aren't.
Generally speaking, a flowchart of a process shows the proces (from end to end). It may have one or more procedures that support it or are referenced by it.
It may be more correct for you to say that a process flow chart is what you are calling a work procedure, rather than that it is one. Similarly manufacturing manual and work instructions.
Seriously, there's a lot of discussion and debate about what a 'process flowchart is' and what a 'procedure' is vs a 'work instruction'. And different people may (and do!) use the terms differently.
I think these terms were far more rigidly understood and used a while ago (meaning, some years) than nowadays.
Hence the sound advice from others (with which I agree) that it's more useful to focus on what the purpose and use of a document is, rather than trying to fit it into a predetermined set of categories like 'procedure', work instruction' and the like.
Paul Simpson
#16
That sound you can hear in the background is my grandmother sucking eggs. :D
Hardly there's any harm in calling both the documents as procedures but at some point we need to differentiate the two. 'Procedures' are normally defined at the 'Process or 'activity level' (largely at the functional/ department level) but certainly the work instructions come into way at the 'task level’. The task level is at the level of the individual. A process is not a ‘work’ (task) but a set of activities or tasks and hence the two cannot be considered as one and the same thing.
I'm aware of the distinction but was merely making the point that whatever the document is called it is still a documented procedure. You can call it Ethel (not my Grandma's name :D) but, if it is a
specified way to carry out an activity or a process ( )
then it is, (in ISO terms) a procedure.
Procedures are infact documents (let's assume we are discussing in terms of written down documents) ... <snip>
Let's be clear (again). You can have procedures and you can have documented procedures. Not all procedures have to be documented. Full stop, period, point.
<snip>...with detailed process descriptions which may have:
- Process objectives
- Process inputs and outputs
- Process standards
- Operating conditions and methods
- How this process interact with other processes
- Reference to required Records, specifications, guidelines, work instructions etc.
- Resources required
- KPIs
- Methods of measuring the process performance
- Troubleshooting guidelines etc. etc.
No argument with what you think might go into a documented procedure.
We can differentiate the two by looking at the big picture of the organization:
Hold on a second while I give granny a few more eggs. :)
1. The organization is a system which comprises of business processes that mainly create and fulfill customer demands. Key documents required at this level are mission statements and policies (organizational or unit level).
2. In order to fulfill the ‘demands’ an organization sets up some work processes which ISO 9001 defines as ‘Product Realization process’ (planning to post delivery activities/ processes). At this level, the organization defines its processes and ‘process descriptions’ which among other elements as mentioned above, do have standards (acceptance levels/ process specifications), plans, process/ deptt. level policies and Operating Procedures (process or activity level documents).
3. Finally we arrive at the TASK level where an individual needs ‘instructions’ on how to work /do (operate, use, handle, control, manipulate, run: (Oxford meaning)) a specific task in a specified way in order to achieve consistent results and the documents that describe ‘step-by-step’ instructions for carrying out a task, are normally known as ‘Work Instructions’.
If that is your way of distinguishing between different types of Ethels, sorry procedures, then fine.
Since 'purchasing' fits well into the definition of a 'process', I know it as a 'process' but in the big picture (Product Realization), it can also be termed as a 'sub-process' (undefined). There's no fine line where we stop calling an 'activity' a 'process'. If you further go up, Product Realization Process may look like a sub-process of the 'Demand Fulfillment Process' which again is a subset of the higher level Business processes. It all depends on the way one looks at the things.
I have already explained that I feel purchasing is part of a bigger process but am not going to reopen that argument here. I do have a problem with your
comment. Any process that captures customer requirements and fulfils them is, IMHO, at the highest level.
Now I appreciate you haven't had a chance to react to my request to be careful with quoting my posts so will simply discuss this as I see it:
Now I recognize that I am probably alone in this but feel that purchasing is not a process on its own but is an activity that supports a lot of the 'product realization' processes. A flow chart can also describe a process. As soon as it prescribes the way of doing things then it becomes a procedure.
I've put your added highlights back in here because your next point takes it up.
By your own reasoning, it can also be tagged as a Work Instruction (the way of doing things). 'things' is a confusing word - if you replace it with 'process or activity', then it's a procedure but if you replace it with 'work' or 'task', then it should logically be a WI.
A couple of things:
  1. Whenever I talk about a process I only ever mean at the high level and any process flow chart would therefore be at a documented procedure level (using your distinction above)
  2. I accept in ISO definition terms an activity is also a process and therefore could require a work instruction but you won't hear me using the terms process and work instruction in the same sentence.
  3. The point in my original post that you missed or ignored is that a procedure (whether documented or not) is a prescribed way of carrying out a process or activity (see ISO definition above). So if the MD tells people that all customer orders have to be handed to the sales department and they must then be tied in pink ribbon then that is the procedure that must be followed. S / he may then decide that it is so important this procedure is followed that the procedure must be documented, people trained in its use and signed off by the HR department as competent to tie the ribbons.
(It is a silly example but I think it makes my point. :)
samsung
#17
I do have a problem with your comment. Any process that captures customer requirements and fulfils them is, IMHO, at the highest level.
And so do I with yours. Please read carefully what I quoted:
In my opinion, the 'Demand fulfillment process' receives input from 'Demand Creation Process' which among others, includes capturing customer requirements. That's the reason I used the word 'higher', not 'highest' as you did by supporting it with 'customer requirements' which I never quoted.:notme:
And by the way Boris, I disagree with all other things you submitted in your post but you may have reasons to believe that you are right.
jm1231
#18
Wow Document Gurus are clashing! But that's great, a novice like me is learning a lot. Thank you all for actively participating on this topic, or shall I say debate.
Anyways, I regarded my Production Process Flow, Incoming Materials process Flow, and Customer Order Process Flow into Work Procedures which is supported by a much defined step by step Work Instructions.
Regards to all....
samsung
#19
You got the point and this is what you should be doing. It's often nice to call spade a spade.
Thanks for the feedback.
JaneB
#20
Debates and different points of view are part of any healthy profession. We just aim for it to remain courteous. ;) and avoid dictating egg-sucking parameters.
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
K Vigilance process flow chart EU Medical Device Regulations 1
D ISO 9001 Design Process Flow Chart ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S US FDA PMA (Pre-Market Approval) Process Flow Chart Example Other US Medical Device Regulations 1
L Process Flow Chart for manufacturing of Light Switch requested Process Maps, Process Mapping and Turtle Diagrams 5
R "Control" as used in 4.1 c) - Process Flow Charts (Process Sequence Chart) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Incoming Source of Variation & Source of Variation in Process Flow Chart IATF 16949 - Automotive Quality Systems Standard 3
S Crisis Management Process and Procedure or Flow Chart example wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
R Sales Order Process Flow Plan (Flow Chart) Steps help ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Requirements for Sequence Diagrams & Process Flow Chart for each Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Process Flow Chart Symbols Quality Tools, Improvement and Analysis 9
M Risk Analysis using FMEA Process Flow Chart - Health Care Information System FMEA and Control Plans 6
R Process Flow Chart Step - Timing between Process Steps Process Maps, Process Mapping and Turtle Diagrams 3
S Example Flow Chart of Qualification of Process wanted APQP and PPAP 3
H Customer Complaint Process Flow Chart example needed IATF 16949 - Automotive Quality Systems Standard 3
A Process Flow Chart vs. Process Flow Diagram? Pages 38-39 in the APQP Manual FMEA and Control Plans 3
R Process Flow Chart Template example Document Control Systems, Procedures, Forms and Templates 20
B Looking for a manufacturing process flow chart example IATF 16949 - Automotive Quality Systems Standard 2
A Need help with the process flow chart on my 4th edition PPAP! APQP and PPAP 5
Z Process Flow Chart - Potential sources of variation included? IATF 16949 - Automotive Quality Systems Standard 3
B ESD Work Instruction or ESD Process Flow Chart - Seeking example Various Other Specifications, Standards, and related Requirements 5
P Flow chart vs. Process map vs. Value stream map - What are the differences? Process Maps, Process Mapping and Turtle Diagrams 4
D Flow Chart and Process Mapping Software - Visio vs. Smartdraw Process Maps, Process Mapping and Turtle Diagrams 19
J Software which links Process FMEA (PFMEA), Control Plan and Flow Chart Quality Assurance and Compliance Software Tools and Solutions 9
D Simple process flow chart for a manufacturing operation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Claes Gefvenberg Internal Audit Process Flow Chart - Please Review Mine and Comment! Internal Auditing 27
J APQP Checklists - Process Flow Chart Checklist, PFMEA Checklist, Floor Plan Checklist APQP and PPAP 11
D Calibration Process Flow Map Example Wanted General Measurement Device and Calibration Topics 3
eule del ayre Merging FMEA and Quality Control Process Flow FMEA and Control Plans 0
S Improving Quality inspection gate in one piece flow manufacturing process Manufacturing and Related Processes 0
M What are the differences between "Process Flowchart form" and "Process Flow Diagram form"? IATF 16949 - Automotive Quality Systems Standard 4
N Process Flow diagram steps for inspection and packaging APQP and PPAP 4
A IATF 16949 Cl. 8.3.5.2 e) - Manufacturing Process Flow Charts & Layout IATF 16949 - Automotive Quality Systems Standard 5
K Which Symbols are used in Process flow diagrams? Manufacturing and Related Processes 2
A Can the BOM in SAP be used in lieu of process flow diagram? APQP and PPAP 7
S How can I make a Process Flow Diagram for APQP process Manufacturing and Related Processes 2
T Software for linking Process Flow Diagram, Process FMEA and Control Plan APQP and PPAP 9
N How Can I Simplify This Process Flow? Lean in Manufacturing and Service Industries 8
A 8D Process Flow IATF 16949 - Automotive Quality Systems Standard 4
M Process Flow Diagram -> PFMEA -> Control Plan Linkage IATF 16949 - Automotive Quality Systems Standard 17
F Please review my Process Flow / PFMEA / Control Plan FMEA and Control Plans 12
T Company Departmental Process Procedures and Flow Diagrams ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
V ECR/DCR Process Flow - What changes require an ECR vs. a DCR Document Control Systems, Procedures, Forms and Templates 2
N Coding System Process Flow for Order Tracker documents (Job Traveller) Document Control Systems, Procedures, Forms and Templates 4
S Depicting Communication Flow Gaps between Departments/Process Steps on a Process Map Process Maps, Process Mapping and Turtle Diagrams 1
T Request for a Design Control Procedure or Process Flow for HVAC Design Document Control Systems, Procedures, Forms and Templates 1
S Complaint Process flow: Need a generic definition which would flag an "MDR" Customer Complaints 7
R Control Plan Flow compared to Process Flow Diagram APQP and PPAP 6
C AS9102 Process Flow Help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Work Instructions versus Process Flow Charts ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
