Process FMEA - Help in deciding "detection ranking" of a failure mode
alokb
While doing a PFMEA for a six sigma project "To improve silver purity of a Pyro refining operation " I do need some help in deciding "detection ranking" of a failure mode .
The Potential Cause(s)/ Mechanism(s) of Failure : Due to small capacity of Bottom blowing oxygen cupel of smaller size it is difficult to control temperature because of small thermal capacity.
Since We know that our furnace is having a limitation with regard to size .
Result :- Occurrence rating =10
What about Detection rating ????
We are almost certain about this fact.
At present no design control exist.
A case study would also help in this regard.
Alok
Wes Bucey
Alok
How do you go about detecting "failure?" What is "failure?" Does the non-silver part of the mix not absorbed into the cupel? What happens if the temperature is too hot? too cold?
OK. You have to help me out here. I do not know about the commercial side of refining silver. I remember from college chemistry more than 40 years ago (using very small quantities) that a porous dish called a cupel ("kew pull") holds the mixture. Everything is heated to about 1500 degrees in the presence of air. The non-silver stuff oxidizes somehow and is absorbed into the cupel, leaving the silver (and gold, if any is present.) We could dissolve the silver out with acid, leaving the gold. We further refined the silver by electrolytic action.
What is the exact failure? Is non-silver, non-gold residue left with the silver when the temperature isn't right? Is some of the silver destroyed? How do you detect the failure mode? The method used to detect whether the silver is sufficiently pure is what you are looking at, not the detection rate of the temperature variance. (i.e. how do you detect non-silver residue?)
What's the base ore you start with (lead? zinc?)
cncmarine
Occurence = 10 with no design controls = normally the DFMEA Detection Rating would be 10.
But the question is can you detect when the NC condition occurs ?
BSpitler
How do you detect the failure? What is the evaluation method? Measurement error? Sampling plan? Error/mistake proofing?
Though I do not know the details of the process, I would not be concerned at all with detection at this point since you already know the failure almost certain to occur. Improvement efforts should be focused on reducing occurrence.
alokb
:thanx: Dear all,
Thanks for reply.
I am sorry that question led every one in technicality of the process.
Let me frame a general question about detectability.
Suppose we are studying the process of safe traffic management from a particular Traffic Circle .
One of the potential cause of failure mode is " The traffic signal system not available/not in place'
Here since we know it very well that the system does not exist .what about the detetection ranking ?
(As far as this process is concern I am going to post the complete PFMAE for perusal and suggestion shortly)
Alok
cncmarine
The question is the same:
What type of controls do you have in place to detect the " The traffic signal system not available/not in place'
Is there some type of inspection that occurs to detect the nonconfoming condition ?????
Once that is established then you can assign a ranking.
P PFMEA (Process FMEA) Recommended Actions help FMEA and Control Plans 9
Q Process FMEA - Need help to clarify O (Occurrence) and D (Detection) rankings FMEA and Control Plans 26
I Need Help with Process FMEA Basics - Feasibility Analysis Outputs are Inputs to FMEA? FMEA and Control Plans 25
J Process FMEA Template with examples - Cold and Hot Forged components FMEA and Control Plans 4
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
Jimmy123 Example of a P-Diagram for Process FMEA - Uncontrollable noises FMEA and Control Plans 39
eule del ayre Merging FMEA and Quality Control Process Flow FMEA and Control Plans 0
K AIAG/VDA FMEA & Process Control Plans FMEA and Control Plans 0
S New AIAG FMEA Process - How to complete the new format FMEA and Control Plans 32
D Where does FMEA fit in your ISO 14971 Risk Management process? ISO 14971 - Medical Device Risk Management 13
N Process FMEA Occurrence Ranking for New Process FMEA and Control Plans 3
G AIAG FMEA - Major customers of the FMEA process FMEA and Control Plans 3
E How do I create a FMEA for the Internal Audit process? Internal Auditing 11
D How to fill a Process FMEA - Three columns - Severity, occurrence and Detection FMEA and Control Plans 16
L Injection & Extrusion Process FMEA FMEA and Control Plans 1
S Pilot Process FMEA Occurence Rankings FMEA and Control Plans 4
K Process FMEA Ranking Table for for Landing Door of an Elevator FMEA and Control Plans 7
G Severity in Process FMEA for Rework Process FMEA and Control Plans 1
R Is PFMEA (Process FMEA) for OEM sufficient to address Risk? ISO 13485:2016 - Medical Device Quality Management Systems 7
H FMEA sample for complete CNC machining process FMEA and Control Plans 1
T Software for linking Process Flow Diagram, Process FMEA and Control Plan APQP and PPAP 9
V Process FMEA for Stamping Process FMEA and Control Plans 5
G FMEA for Steel Tube Process for Automotive FMEA and Control Plans 4
L Most appropriate Auditor to check the FMEA & PCP of a Manufacturing Process IATF 16949 - Automotive Quality Systems Standard 5
C List Error Proofing in the Process FMEA or the Control Plan FMEA and Control Plans 2
J Process FMEA w/ Contracted Manufacturing ISO 14971 - Medical Device Risk Management 2
B FMEA example for Cokemaking Process at a integrated Iron and Steelmaking Plant IATF 16949 - Automotive Quality Systems Standard 3
S FMEA Process Step or Current Control FMEA and Control Plans 3
Z Pass-Though Characteristics in PFMEA (Process FMEA) FMEA and Control Plans 2
Q Chrysler required FMEA and Control Plan Document Audit Forms and Process Audit Check FMEA and Control Plans 7
V Examples of Design and Process FMEA for Pharmaceutical Product Development ISO 14971 - Medical Device Risk Management 7
S Galvanize and Chrome Plating Process FMEA wanted FMEA and Control Plans 2
S Product FMEA vs. Process FMEA - Aerospace Industry Machine Shop FMEA and Control Plans 5
R PFMEA (process FMEA) for Incoming Material stage FMEA and Control Plans 7
J What is Incorporation in Assembly/Manufacturing Process in FMEA? FMEA and Control Plans 4
A Will Inspection Process need an FMEA? FMEA and Control Plans 7
F Process FMEA for Welding and Laser Cutting FMEA and Control Plans 3
G Very Basic PFMEA (Process FMEA) Guidelines FMEA and Control Plans 17
R Process to use Special Characteristics as FMEA Inputs IATF 16949 - Automotive Quality Systems Standard 3
M PFMEA (Process FMEA) - What is the best approach? FMEA and Control Plans 14
F FMEA Optimization for our Die Setup Process FMEA and Control Plans 2
M PFMEA (Process FMEA) for Attribute Data Inspection Process FMEA and Control Plans 2
A Current Control Periodic Document Reviews - Process Updates in the FMEA FMEA and Control Plans 3
T PFMEA (Process FMEA) Recommended Actions Column FMEA and Control Plans 10
B Process FMEA (PFMEA) Same Multiple Causes for Different Effects FMEA and Control Plans 6
M Changing PFMEA (Process FMEA) RPN Values based on a Rejection FMEA and Control Plans 5
Chennaiite FMEA for Business Process Imported Legacy Blogs 6
K Does FMEA include Inspection Process? FMEA and Control Plans 11
