Process FMEA (PFMEA) Assumptions Regarding Causes Identification
Marcelo - 2008
Dear all,
When listing potential failure modes (PFMs) within a specific process step, we need to consider that expected outcomes of previous steps have fulfilled requirements. However, once we have identified the PFMs - limited to the boundaries of a specific process step - as well as their effects and start listing the causes, my understanding is that we may list any cause regardless of where it is originated, such that one cause may appear for multiple PFMs in different process steps. Am I correct?
Thank you!
Re: Process FMEA Assumptions Regarding Causes Identification
Dear all,
Thank you!
Potential causes should be restricted to the operation under consideration, with the exception of inspection operations, where the state of the incoming material is in question. If operation #1 has been properly addressed, and potential causes of defects have been tabulated, there should be no need to address the same causes in operation #2. The effects of the potential failure modes addressed in operation #1 should include adverse effects on operation #2, or any other operation in any other process, that's a "customer" of operation #1.
David DeLong
I agree with Jim on restricting the potential causes to the current process operation (per AIAG guidelines) although Jim and I do differ on whether process FMEAs are applied to inspection but that is another subject.
Marcelo - 2008
Wouldn't there be an exception when previous operations have been left out of the FMEA? Then, in such case, causes coming from left-out operations could be considered? Even because otherwise they wouldn't appear anywhere else. One example: a process FMEA applied to a chemical mfg process. Let's say the team decides to cover from production planning to product release. Consider we are listing causes of PFMs at the production planning step and that the lack of standardized formulas (that should be made available by the left-out product development step, for instance) is one of the causes. Shouldn't such cause be listed then?
No. The previous PFMEA(s) should be updated to include the new information. If there is no upper-level PFMEA, you've just described why there should be one. If you know about the issue (lack of standardized formulas) downstream, why didn't they know about it in the beginning and account for it?
Marcelo - 2008
Dear Jim, as I don't have a downstream PFMEA - covering the product development step -, would you recommend I add such step prior to the production planning one (first in the example mentioned)?
It's an upstream step that's causing the worry, no? In other words, a process that proceeds (or should proceed) the one for which you're doing the PFMEA? You've identified a potential source of variation that can't be controlled within the process, which means that your own PFMEA is at least partially premature. These things need to work from the top down, not the other way around. This means that you need to take care of those issues, and if that means a higher-level PFMEA, then that's what should be done.
karinca PFMEA (Process FMEA) - Can be common for 3000 products? FMEA and Control Plans 2
R Is PFMEA (Process FMEA) for OEM sufficient to address Risk? ISO 13485:2016 - Medical Device Quality Management Systems 7
Z Pass-Though Characteristics in PFMEA (Process FMEA) FMEA and Control Plans 2
R PFMEA (process FMEA) for Incoming Material stage FMEA and Control Plans 7
P PFMEA (Process FMEA) Recommended Actions help FMEA and Control Plans 9
G Very Basic PFMEA (Process FMEA) Guidelines FMEA and Control Plans 17
M PFMEA (Process FMEA) - What is the best approach? FMEA and Control Plans 14
M PFMEA (Process FMEA) for Attribute Data Inspection Process FMEA and Control Plans 2
T PFMEA (Process FMEA) Recommended Actions Column FMEA and Control Plans 10
B Process FMEA (PFMEA) Same Multiple Causes for Different Effects FMEA and Control Plans 6
M Changing PFMEA (Process FMEA) RPN Values based on a Rejection FMEA and Control Plans 5
Q Using a Custom Process FMEA (PFMEA) Form FMEA and Control Plans 4
D PFMEA (Process FMEA) Process and Rankings (S-O-D) Document Control Systems, Procedures, Forms and Templates 8
A PFMEA (Process FMEA) Detection Rating - Actions to Reduce RPN FMEA and Control Plans 3
L PFMEA (Process FMEA) Forms - Dyadem FMEA Software Products FMEA and Control Plans 5
L Rotational Molding and Machining PFMEA (Process FMEA) - Plastics - example wanted FMEA and Control Plans 6
Chennaiite PFMEA (Process FMEA) for Vehicle Assembly wanted FMEA and Control Plans 4
H How to perform interesting PFMEA (Process FMEA) Training Training - Internal, External, Online and Distance Learning 6
M PFMEA (Process FMEA - Potential Causes and Failure) - Operator's Role FMEA and Control Plans 11
5 Changes to Control Plans or PFMEA's (Process FMEA) FMEA and Control Plans 6
P PFMEA (Process FMEA) Acceptable Effectivity Rate for Reoccurances of Issues FMEA and Control Plans 1
T DFMEA (Design FMEA) - We already have a PFMEA (Process FMEA) FMEA and Control Plans 5
D Laser Welding PFMEA (Process FMEA) - Metal FMEA and Control Plans 15
Casana Detection level in PFMEA (Process FMEA) - Bulk Fluids FMEA and Control Plans 10
P Problem with "failure mode? interpretation in PFMEA (Process FMEA) FMEA and Control Plans 8
R Addressing Inspection in PFMEA (Process FMEA) FMEA and Control Plans 2
S Pfmea (Process FMEA) at Process Audit FMEA and Control Plans 4
J When to Update PFMEA (Process FMEA) - Rejection is found at the customer FMEA and Control Plans 12
V Integrating the FMEA process with problem investigation/RCA process and PFMEA FMEA and Control Plans 11
C DFMEA (Design FMEA) and PFMEA (Process FMEA) - Who should lead? FMEA and Control Plans 14
C PFMEA (Process FMEA) Detection Scale - Aerospace engine components FMEA and Control Plans 4
H How to Make PFMEA (Process FMEA) from the beginning to the end FMEA and Control Plans 4
H Corrective Action: When to update the Process FMEA (PFMEA) FMEA and Control Plans 15
M Process FMEA (PFMEA) for D.C. Welding of Sheet Metal Parts - Electrode Material FMEA and Control Plans 1
N How to Calculate RPN in Design FMEA (DFMEA) vs. Process FMEA (PFMEA) FMEA and Control Plans 9
J When to update a PFMEA (Process FMEA) FMEA and Control Plans 17
S Detection Criteria Examples - PFMEA (Process FMEA) - Emergency Safety Fixtures FMEA and Control Plans 2
E PFMEA (Process FMEA) Class Symbols FMEA and Control Plans 6
Kales Veggie Informational How to develop a Control Plan from a PFMEA (Process FMEA) FMEA and Control Plans 63
kedarg6500 Supplier PFMEA (Process FMEA) Audit Form FMEA and Control Plans 4
Y Process FMEA (PFMEA) vs. Equipment FMEA (EFMEA) Differences FMEA and Control Plans 15
J Updating a PFMEA (Process FMEA) after a Process Failure FMEA and Control Plans 3
J The real Link between a PFMEA (Process FMEA) and the Control Plan FMEA and Control Plans 19
W Actual examples of FMEA (DFMEA, PFMEA) for Car Assembly Process IATF 16949 - Automotive Quality Systems Standard 5
L PFMEA (Process FMEA) issue about lower RPN - AIAG 3rd edition page 55 FMEA and Control Plans 13
M Connections between PFMEA (Process FMEA) and the Control Plan. FMEA and Control Plans 20
M PFMEA Severity - What is Process FMEA Severity estimation based on? FMEA and Control Plans 77
K Change in Occurrence for Low Volume Assembly Process FMEA (PFMEA) FMEA and Control Plans 8
M Include Risk of Rework in a PFMEA (Process FMEA)? FMEA and Control Plans 5
