Process FMEA with the effect "brakes are broken" - Is it nonconformity?
Peters
Problem during the TS audit.
Process FMEA team found some technical requirements with the effect "brakes are broken". They gave severity 9 or 10. They didn't identified special characteristics because the design documentation for these requirements didn't contain special characteristics. Would you write NC Report?
Re: Is it nonconformity?
If there's a requirement for everything with a severity rating of 9 or 10 to be identified as an SC, it's a customer-specific requirement (or a requirement of your company). In order for a nonconformity to be identified, a specific requirement has to be unfulfilled. What's the requirement in your case?
Peters
Well...
Usually FMEA is main tool for special characteristics identification.
If problem connected with effect with severity 9/10 is not special characteristic - what effect could indicate special characteristic? What can be more dangerous?
PS. In Ford FMEA Handbook there is table with special characteristics "The following table contains the possible characteristic designations for both Design and Process FMEAs"
In this table:
Process -∇ - A Critical Characteristic - Severity = 9, 10 - Special Control
Required
Well...
What could be more dangerous is a high severity rating coupled with high occurrence and/or detection ratings.
In this table:
Process -∇ - A Critical Characteristic - Severity = 9, 10 - Special Control Required
That's a requirement only if Ford is your customer. Personally, I think it's a mistake to get overly excited about high severity numbers if the risk is reasonably low.
Duke Okes
Whether it is a special characteristic would be decided by design engineers as part of design FMEA. Then that designation would be carried into the process FMEA. Severity rankings in process FMEA should come from design FMEA.
Chennaiite
Never-say-die
If designating characteristics with Severity 9 or 10 as Special is neither the requirement of your Customer nor of internal guidelines/Product design outputs, the answer to your question is - No.
Nevertheless, if you get a feeling that, it is supposed to be considered Special (Standards apart), you can only end up to the extent of giving feedback to the concerned.
It is not appropriate for the auditors, internal or external, to challenge the adequacy of the Design.
tbsiva
No standard says that Failure mode having a severity of 9 and 10 needs to be designated as special characteristic. Only based on this, an auditor cannot write a NCR.
But you need to demonstrate the logic on defining special charateristic.. For ex : a failure mode having a severity of 4 or 5 is designated as special charateristic whereas in other case a failure mode of 9 or 10 severity ranking has not been classified as special characteristic... The logic has to be justified
This is generally true but many, if not most, automotive suppliers have no access to DFMEAs and must go by the drawing as far as design intent goes. It's possible that a supplier could have a different strategy in developing PFMEAs, one that's based on "the organization's" own risks, exclusive of end-use risks. The rationale might be that if you make the product to the specifications, design intent is taken care of, and what's left is risk for the supplier.
K Process FMEA responsible For "Make to Design Parts" (Inhouse or Suppliers ?) FMEA and Control Plans 3
M Process FMEA for Laser Cutting/Press Brake/Welding FMEA and Control Plans 2
L Looking for Control Plan and FMEA Stamping process FMEA and Control Plans 2
J Process FMEA Template with examples - Cold and Hot Forged components FMEA and Control Plans 4
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
Jimmy123 Example of a P-Diagram for Process FMEA - Uncontrollable noises FMEA and Control Plans 39
eule del ayre Merging FMEA and Quality Control Process Flow FMEA and Control Plans 0
K AIAG/VDA FMEA & Process Control Plans FMEA and Control Plans 0
S New AIAG FMEA Process - How to complete the new format FMEA and Control Plans 32
D Where does FMEA fit in your ISO 14971 Risk Management process? ISO 14971 - Medical Device Risk Management 13
N Process FMEA Occurrence Ranking for New Process FMEA and Control Plans 3
G AIAG FMEA - Major customers of the FMEA process FMEA and Control Plans 3
E How do I create a FMEA for the Internal Audit process? Internal Auditing 11
D How to fill a Process FMEA - Three columns - Severity, occurrence and Detection FMEA and Control Plans 16
L Injection & Extrusion Process FMEA FMEA and Control Plans 1
S Pilot Process FMEA Occurence Rankings FMEA and Control Plans 4
K Process FMEA Ranking Table for for Landing Door of an Elevator FMEA and Control Plans 7
G Severity in Process FMEA for Rework Process FMEA and Control Plans 1
R Is PFMEA (Process FMEA) for OEM sufficient to address Risk? ISO 13485:2016 - Medical Device Quality Management Systems 7
H FMEA sample for complete CNC machining process FMEA and Control Plans 1
T Software for linking Process Flow Diagram, Process FMEA and Control Plan APQP and PPAP 9
V Process FMEA for Stamping Process FMEA and Control Plans 5
G FMEA for Steel Tube Process for Automotive FMEA and Control Plans 4
L Most appropriate Auditor to check the FMEA & PCP of a Manufacturing Process IATF 16949 - Automotive Quality Systems Standard 5
C List Error Proofing in the Process FMEA or the Control Plan FMEA and Control Plans 2
J Process FMEA w/ Contracted Manufacturing ISO 14971 - Medical Device Risk Management 2
B FMEA example for Cokemaking Process at a integrated Iron and Steelmaking Plant IATF 16949 - Automotive Quality Systems Standard 3
S FMEA Process Step or Current Control FMEA and Control Plans 3
Z Pass-Though Characteristics in PFMEA (Process FMEA) FMEA and Control Plans 2
Q Chrysler required FMEA and Control Plan Document Audit Forms and Process Audit Check FMEA and Control Plans 7
V Examples of Design and Process FMEA for Pharmaceutical Product Development ISO 14971 - Medical Device Risk Management 7
S Galvanize and Chrome Plating Process FMEA wanted FMEA and Control Plans 2
S Product FMEA vs. Process FMEA - Aerospace Industry Machine Shop FMEA and Control Plans 5
R PFMEA (process FMEA) for Incoming Material stage FMEA and Control Plans 7
P PFMEA (Process FMEA) Recommended Actions help FMEA and Control Plans 9
J What is Incorporation in Assembly/Manufacturing Process in FMEA? FMEA and Control Plans 4
A Will Inspection Process need an FMEA? FMEA and Control Plans 7
F Process FMEA for Welding and Laser Cutting FMEA and Control Plans 3
G Very Basic PFMEA (Process FMEA) Guidelines FMEA and Control Plans 17
R Process to use Special Characteristics as FMEA Inputs IATF 16949 - Automotive Quality Systems Standard 3
M PFMEA (Process FMEA) - What is the best approach? FMEA and Control Plans 14
F FMEA Optimization for our Die Setup Process FMEA and Control Plans 2
M PFMEA (Process FMEA) for Attribute Data Inspection Process FMEA and Control Plans 2
A Current Control Periodic Document Reviews - Process Updates in the FMEA FMEA and Control Plans 3
T PFMEA (Process FMEA) Recommended Actions Column FMEA and Control Plans 10
B Process FMEA (PFMEA) Same Multiple Causes for Different Effects FMEA and Control Plans 6
M Changing PFMEA (Process FMEA) RPN Values based on a Rejection FMEA and Control Plans 5
Chennaiite FMEA for Business Process Imported Legacy Blogs 6
