Process Interaction - ISO 9001:2015
Q
qcstar
Hello Members
Glad I came across this forum. As a quality consultant, I'm currently engaged in transition activities from ISO 9001:2008 to ISO 9001:2015. There are certain queries which requires clarifications. Appreciate your quick responses.
1. Will the Process interaction diagram differ in the 2015 standard from what we prepared in 9008 standard ?
2. Are there any tools available for calculating the number of days it would require for preparing just the transition documentation ? (One of my client requires just the document transition in accordance with 2015 revision. Any tool for calculation effort require for documentation phase).
Thanks in Advance Everyone.
dsanabria
Hello Members
Glad I came across this forum. As a quality consultant, I'm currently engaged in transition activities from ISO 9001:2008 to ISP 9001:2015. There are certain queries which requires clarifications. Appreciate your quick responses.
in your statement you make a reference to ISP 9001 - typo?
Anyway - the processes of the company does not change. What is required is that you need to define the KPI, measure and determine if they meet requirements.
2. there are tools and standards for audit time but for preparation? Not sure what you are looking for... can you give us an example.
Q
qcstar
@dsanabria, Thanks for bringing the error to my notice. Yeah its ISO and not ISP.
I agree the processes dont change so I'm planning ti retain interaction of processes from existing version to the ISO 9001:2015 version.
My 2nd query was one was my client requires only documents to be modifies in accordance with current ISO 9001 standard. Implementation and other related activities will be taken care by client itself.How can I calculate the number of days required for making document changes according to the latest standard
Thanks in Advance.
dsanabria
Thanks in Advance.
First - Do a GAP analysis of what needs to change - this could take 1 or 2 days or more.- depends on the complexity of the company and complexity of documentation.
go to: IAQG: Requirements for a GAP analysis worksheet and additional information.
howste
Thaumaturge
I agree with dsanabria. There is no way to know what level of effort is needed until you know what they already have and what needs to be changed.
Golfman25
Thanks in Advance.
Depends on how fast you can type. :)
Q
qcstar
Thanks everyone for your inputs.
This is a small company with 20-50 employees,already have 9001:2008 in place.scope includes design and development.How many days document effort would take for changing to new version 2015. I estimated about 3 weeks. Not sure if its less or more.
Any suggestion,inputs are welcome...Thanks in advance.
Golfman25
Like others said, it depends on where you are starting from. We are changing standards and much of what IS0 9001:2015 requires was contained in our old standard. For example, we still had the old QS Business Plan requirement in our system. Well that blended perfectly with the context of the organization stuff. So we had almost no time required to develop new procedures and such. Our time was spent cleaning out old remnants that where no longer applicable. Everybody's journey will be different. Good luck.
howste
Thaumaturge
I'm not sure either.
When I was doing QMS consulting I would ask to do a one to two day gap analysis first. The output of this would be a report that would identify the scope of everything that needed to be done at a high level. This would be used to determine how much time was necessary to implement the changes. I could then prepare a reasonable quote.
If a client insisted on getting a full quote before a gap analysis (which happened frequently) then I would give a quote including a gap analysis and then a not-to-exceed range of days to do the work. If I guessed well in the quote then I would get the work done somewhere in the range of days quoted. If I underestimated then I still got it done by the max days quoted, but the actual working days tended to be a little longer and I asked their process owners to do more... :notme:
K Process Interaction Model in ISO 9001 Standard Document Control Systems, Procedures, Forms and Templates 6
D Process Interaction Examples for ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Process Interaction Map for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 10
H Process Interaction Chart example as required by ISO 13485 2003 ISO 13485:2016 - Medical Device Quality Management Systems 11
L Process Interaction push back during Stage 1 IATF 16949 - Automotive Quality Systems Standard 7
T AS9100 Process Sequence and Interaction Map Example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T Process Sequence and Interaction Map AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
D IATF NC Interaction of process diagram - Missing contingency plan Process Maps, Process Mapping and Turtle Diagrams 9
K Turtle diagram or process interaction chart - Making it easier for an auditor Process Maps, Process Mapping and Turtle Diagrams 23
A Sequence and Interaction of the Processes - Please review my Process Map ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
K The Process Interaction Matrix from Quality Works Process Maps, Process Mapping and Turtle Diagrams 9
M Do I need a Procedure for Each Process? And the Interaction of Processes - TS16949 IATF 16949 - Automotive Quality Systems Standard 20
S Example of EMS Process Flow with interaction of core elements - Chemical industry Miscellaneous Environmental Standards and EMS Related Discussions 8
P Criticize my Company wide Process Interaction Mapping IATF 16949 - Automotive Quality Systems Standard 4
A Seeking: Process Interaction Example ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Process Interaction Chart - Graphical representation of top level business processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
M RFQ Process Manufacturing and Related Processes 3
D Way to stream line in-process nonconformance? Nonconformance and Corrective Action 2
P Process Validation - OQ & PQ Other Medical Device and Orthopedic Related Topics 2
D Process FMEA Owner, Designer or Manufacturer ? APQP and PPAP 9
adztesla Design change and Process change Class 3 medical device Medical Device and FDA Regulations and Standards News 2
T IVD Self-Test Notified Body Conformity Assessment Process EU Medical Device Regulations 0
H Regarding UL Certification process CE Marking (Conformité Européene) / CB Scheme 12
T Guiding document or resource to process AS9100 audit findings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
R ILAC G24 - defining process control measures, ISO 17025 related Discussions 2
L CQI-9 Special Process: Heat Treat System for Sinter parts IATF 16949 - Automotive Quality Systems Standard 0
L Cpk in relation to individual process parameters. Reliability Analysis - Predictions, Testing and Standards 1
was named killer PROCESS OWNERSHIP (QUICK QUESTION) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
T What does "fully verify" mean exactly in process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Feedback process ISO 13485:2016 clause 8.2.1 ISO 13485:2016 - Medical Device Quality Management Systems 2
T New process capability analysis required when changing a product on the same line? IATF 16949 - Automotive Quality Systems Standard 6
P Supplier Development Process description Process Maps, Process Mapping and Turtle Diagrams 1
S Customer Defective Part Return Process Process Maps, Process Mapping and Turtle Diagrams 2
DuncanGibbons How to determine process stability for a process whose outputs should be steadily increasing? Capability, Accuracy and Stability - Processes, Machines, etc. 4
J Document hierarchy for Process mapping for ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 7
A Cosmetic product registration process EU Medical Device Regulations 0
A Sample size selection for process validation - continuous data Reliability Analysis - Predictions, Testing and Standards 9
Q Failure mode, Process Excursion and Failure mode cause ISO 14971 - Medical Device Risk Management 3
Sidney Vianna IAQG News IAQG 9401-1:2022 Changes & Organization Certification Analysis Process - OCAP Demo AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
E Process capability in a single batch Capability, Accuracy and Stability - Processes, Machines, etc. 3
Ashland78 IATF Process Control Plans not including customer name Manufacturing and Related Processes 13
S Sample size considerations in medical process qualification Reliability Analysis - Predictions, Testing and Standards 11
M Process flowcharts ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
A Small Company Implementing ISO 13485 Timeline/Process/Steps Advice ISO 13485:2016 - Medical Device Quality Management Systems 5
G Help Needed: Quality Control / Assurance process Quality Manager and Management Related Issues 3
D Seeking help in validating a cleaning process. Manufacturing and Related Processes 5
R CNC process validation Manufacturing and Related Processes 1
C Product compliance process REACH and RoHS Conversations 10
M Clinical evaluation process of FDA and MDR Medical Device and FDA Regulations and Standards News 2
V Countries without Formal Regulatory Approval Process Other Medical Device Regulations World-Wide 0
