Process Map and defining KPIs
silver ring
I have two questions. I know something, but what I know, needs improvement.
1) How to define key QMS processes and establish a process map ?
2) How to define key process indicators both for effectivity and productivity? Is there a nice software to track KPIs and enter data?
Steve Prevette
Deming Disciple
Re: Process Map and KPIs
On establishing KPI's, there are some ideas in a presentation I wrote at http :// www. efcog .org /wg/esh_es/Statistical_Process_Control/docs/Choosing_performance_indicators_Day_One.pdf DEAD LINK UNLINKED (404)
As far as software, there are many commerical products out there, but I find that a savvy user of Microsoft Excel will be able to do what the products do, with more flexibility, and without the expense.
tony wardle
Registered Visitor
Here is my take on this - and it worked for me.
Process mapping - use a protocol and stick to it. Example - an oval is a start and end point. A block is a process without any decisions. A diamond is a decision point. Make sure the loop is closed. With this, even if the verbage is wrong, the flow concept can be understood and followed. Keep the verbage to minimum, and where a database, document or anything else is referenced, make this clear, so that you are all looking at the same data. There must be no guess work.
Start with the big picture and little detail, and as problems dictate, move to make the detail more descriptive.
Rather call the process map a Value Stream Map. Look at the process and determine what adds value and what does not. You would be surprised at the work we do for no good reason, and how much defect can be introduced, by doing redundant steps.
Of utmost importance - say what you do, and do what you say. Most people write up process maps in a way that they hope things will work. Fairy tales belong at school, not in business. The key processes you are looking for will come out of two things - 1. Your big picture overview, and 2. The areas where things go wrong. Things go wrong where either we allow them to (ie insufficient checking or attention) or where there are grey areas for undertanding or decision making. The "QMS processes" belong to the whole plant - accounts and sales included. The Quality Manager is only a scorekeeper. He or she doesnt make quality, but measures it and reports where deficiencies exist - and of course the CR will demand that these are fixed via ARs - CARs or PARs.
As for KPIs, I did the following. I had each department submit a KPI. What was on it didnt matter. What mattered was that they got in the habit of scoring themselves. Then I looked at the things that added value. Example - we used to measure efficiency - how long a mahine ran without stopping. I changed this to effectiveness. The KPI now had three measurements - Up time, scrap value and effectiveness as a ratio of up time vs scrap. This was converted from hours and percentages to dollars and cents.
As the KPIs progressed, certain things never changed, they were always good. I dropped these Certain things were never measured, but were out of control - example - waste. I added these. Then, I took the measurements and played around with ratios to exhibit dependancies. I invited maintenance, RandD, finance, sales etc. to comment on production and vice versa. Soon - each department had a KPI that meant something to everyone, and had value to everyone. Amazing how, - when finance realise their impact on production, and sales on finance and so on - the team starts to come together to find solutions and how the blame game stops.
We now discuss these KPIs weekly, - for an hour or so - with each area having their turn each week on a rotational basis. Has this added value? - absolutely. We use Xcel for the KPIs and deposit these as attachments into a intranet. Interestingly, we can tie up abseentism trends with quality and with productivity etc.
Last word on KPIs - these are living things - some measurents should be done everymonth - every year. Others will change from year to year, dependant on your business, economic factors etc. And dont do this for the auditor or for looks good value - do this to add value to your business.
Marc
Is the .pdf available somewhere now by chance?
rogerpenna
Should ALL macro processes, processes, sub-processes, have performance measurement indicators?
In theory, all processes should be monitored as part of the PDCA (or DMAIC) cycle.
And Turtle Diagrams or SIPOC all will have areas to show how to measure proccess performance.
But that is all fine and dandy, but in reality, Process Measurement can be near impossible to measure without adequate machines or software, or a LOT of work (creating records) which will be an enormour bureaucracy which may in fact, itself DECREASE process performance, as Process Owners will need to stop workflow all the time to record stuff, and then dedicate extra time to put those records into a spreadsheet (or a KPI system) to get graphs, and such.
So... can a company just decide to not measure a process performance? Not even tell in the Process documentation how it's measured?
optomist1
A Sea of Statistics
regardless of software chosen...(given its many features...my favorite is Visio), in its simplest form establishing KPIs, is a collaborative, team effort, frequently based upon much statistical data and analysis...
D Calibration Process Flow Map Example Wanted General Measurement Device and Calibration Topics 3
S Process Map for Supplier Process Maps, Process Mapping and Turtle Diagrams 5
T Operational setup of how FIFO / Process Map on Lithium Batteries is done Manufacturing and Related Processes 1
M AS9100D Process Map Requirements - PEAR Forms AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
Q To include Context and Interested Parties in Process Map? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
C Process Map Transition from ISO9001:2008 to ISO9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
O Process Mapping prior to Validation and Software to use to Map Process Maps, Process Mapping and Turtle Diagrams 12
S Process Map for an Engineering Consulting Firm Process Maps, Process Mapping and Turtle Diagrams 6
M Does a process map satisfy 21 CFR 820.20(d) (Quality Plan)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
A Sequence and Interaction of the Processes - Please review my Process Map ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Depicting Communication Flow Gaps between Departments/Process Steps on a Process Map Process Maps, Process Mapping and Turtle Diagrams 1
Q Process Maps: Sales, different products, more boxes - Critique my map? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Product Realisation Process Map - Need some help, please review and comment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Include Suppliers in my Process Map? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K AS9100 rev c Process Map examples wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Z Process Map or Turtle Diagram - Which tool to use in my TS-16949 system IATF 16949 - Automotive Quality Systems Standard 5
P PDP (Product Development Process) and APQP Process Map APQP and PPAP 3
S Purchasing Process Map for ISO 9001 and ISO 13485 - Example wanted Process Maps, Process Mapping and Turtle Diagrams 5
M Process Map for a Consulting Firm Service Industry Specific Topics 2
S Process Map of Document Control - Review wanted (Visio) Document Control Systems, Procedures, Forms and Templates 7
S Process Map - Turtle Diagram for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
5 What are your thoughts on my NPD (New Product Development) process map? Process Maps, Process Mapping and Turtle Diagrams 17
H Beautiful, Graphic, Process Map examples wanted - Graphic design is important Process Maps, Process Mapping and Turtle Diagrams 7
Q Unsupported ISO areas in Process map? Finance and Accounting ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Software Life Cycle Process Map? Template or example wanted IEC 62304 - Medical Device Software Life Cycle Processes 3
B Quality Planning process map - Struggling to define all the inputs and outputs Process Maps, Process Mapping and Turtle Diagrams 17
A Process Mapping - for "Audits" - Detailed process map + macro map + FMEA Process Maps, Process Mapping and Turtle Diagrams 10
M Process Interaction Map for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 10
M Process Map: Accounting Journal Entries (accrual process) Process Maps, Process Mapping and Turtle Diagrams 9
K Purchasing Process Map example wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M High-level process map for a leasing service company Service Industry Specific Topics 2
J What IS a Process Map? Process Maps, Process Mapping and Turtle Diagrams 59
A Review My Process Map - Services Company Process Maps, Process Mapping and Turtle Diagrams 15
P Process Map vs. User Guide - Documenting business procedures Process Maps, Process Mapping and Turtle Diagrams 3
P Process Map for Offset Printing Process Maps, Process Mapping and Turtle Diagrams 2
R Please review my process map Process Maps, Process Mapping and Turtle Diagrams 5
O I need a process map for ISO 9001 important processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
H Combining a Process Map and Written Procedure Process Maps, Process Mapping and Turtle Diagrams 44
S Process Map Format and Content - Correct or Incorrect Process Maps, Process Mapping and Turtle Diagrams 15
H Please Review my High Level QM (Quality Management) Process Map Process Maps, Process Mapping and Turtle Diagrams 57
J Main Map and Major Process Maps or Turtle Diagrams Process Maps, Process Mapping and Turtle Diagrams 5
R Business Process Map Guide - Help Needed Process Maps, Process Mapping and Turtle Diagrams 1
Anerol C Please Critique my process map - Metal-Mechanic Industry Process Maps, Process Mapping and Turtle Diagrams 4
J Quality System Process Map - Is this too detailed or not enough detail? Process Maps, Process Mapping and Turtle Diagrams 77
G Process Map for Highway Design & Construction needed Process Maps, Process Mapping and Turtle Diagrams 1
N Should a Process Map have all the Core Processes? Process Maps, Process Mapping and Turtle Diagrams 12
N Linking Business Process Map with Sub-Process Process Map Process Maps, Process Mapping and Turtle Diagrams 39
D Examples of Process Map for a Transactional Process like Order Entry Process Maps, Process Mapping and Turtle Diagrams 3
D Using a Value Stream Map as High Level Process Map Process Maps, Process Mapping and Turtle Diagrams 5
