Process Mapping and Quality Procedures Examples
M Greenaway
#11
In a small company I reckon you could have reasonable process maps within a week, however it may take you a little while to understand the technique of process mapping - time is very tight for you im afraid.
You could start by trying to map the current design process at your company, then do a gap analysis between what you have seen and the design requirements in ISO9001:2000 (clause 7.4 at a guess).
Important things to consider are how the company tackles the main sub clauses, such as design planning, design review, design verification and design validation.
Key performance indicators for the design process may well be things like project completion to planned date, expense to budget, engineering changes required.
#12
ralphsulser said:
Here is an example of a Standard procedure, and a work instruction we have here. Hope this helps
ralphsulser,
Are all your procedures that long? It almost seems like a work instruction to me, given the detail. IMHO it's way too long for most people to use, but then maybe it suits your business.
Cari Spears
#13
Steve Pring said:
:I am a student doing a six week project to help improve a medical manufacturers Quality System, they have 35 employees, so any help would be greatly appreciated. I have only three weeks left so what do you suggest I can do?
Hi Steve -
I'm curious, what is the class you are taking? And I was wondering what the main objective of the assignment is, given that you only have 6 weeks.
Try a search of the forums using the words "process mapping". There are alot of samples of manuals and maps all over.
Keep us posted how you're doing. :)
Steve Pring
#14
Reply for Cari
HI CARI
:bigwave:
The initial aim of the project was to "computerise" the quality system, this meant placing all relevant documents on to a web-based programme so that employees could use a computer to find the relevant work instruction for their job. A lot of the work is repetitive and requires alot of quality checking since they make implantable medical devices. Management felt that staff weren't using the documentation since it was inaccessible(physically) however it seems to me that the work instructions have been written in a very confusing fashion and this was the reason why they didn't bother to look at it.
The project has changed its objectives and the aim now is to come up with a "plan of action" to improve their quality management system. Hopefully when I will leave in a few weeks the directors will be clearer about what they want and how to go about doing it. The problem I faced at the beginning of the project was that management didn't know what they wanted from me and what they were aiming towards.
I am currently studying Mathematics and the project was meant to be purely IT, so I have had to learn quickly about ISO and FDA standards etc...
I'm getting interested in it, but have no experience of this type of work at all!!!
Hopefully will do some process mapping for them on design and development because this is an area where they would like to improve efficiency.
Thanks for your help
Steve :)
#15
Steve,
I would seem that you are moving in the right direction. It is utterly useless to computerize a poor system. Realizing that and moving the focus to improvement of the system must clearly be the correct path.
The advice to map the processes is spot on too: I think it's a fair bet that the written procedures won't match the processes you come up with. Then you'll know what to scrap and what to improve. Three weeks though... At least you will have time to get started.
Good luck, and do tell us what happens...:agree:
/Claes
G
Groo3
#16
We add another layer to the standard document pyramid which Mike mentions above. Craig has part of it in his reply... For my organization, the Top layer of our pyramid is composed of the Quality Policy and our Goals and Objectives. Also, as my site is just one manufacturing uint of a larger whole, our headquarters has another series of documents which also fall into the top layer = we have a corporate Quality Policy with supporting principles as well as a corporate ethics policy (which is also part of the top level documentation).
As for the original topic regarding procedures, we believe in setting some common outline requirements and then suggest optional additions to be included as necessary. Also, it's helpful to have the individuals who own the process either write the procedures themselves, or at least serve as a reviewer of the documents.
Our common procedure requirements are to have a unique Title and Identification #, a Department who owns the document, the Area(s) to which the document applies, the type of document (training, calibration, preventive maintenance, test method, process control, etc.), and the following:
(1) a Purpose
(2) a Scope or Application
(3) Safety (for safety concerns specific to the document, sometimes this is N/A)
(4) Procedure
Some of our optional categories (to be used when appropriate):
(5) Definitions specific to the procedure or unique to our organization
(6) Associated Documents (when one document refers to another)
(7) Roles and Responsibilities (when not specified in the body of the Procedure, a separate section may be used... sometimes, this would also be where employee competency requirements are discussed)
(8) Distribution and Notifications List (who needs to know about the document?)
(9) Equipment
(10) References (Journals, books, regulations, etc.)
Flowchart when you can. This can help describe the process and help keep the document to a reasonable size. I typically try to use at least one flowchart, two at most to provide guidance in the process. If more than two flowcharts are needed to describe the process, then perhaps the procedure may be trying to cover too much ground?
In my organization, we have been through the extreme ends of the spectrum when it comes to documenting our system (from overdocumenting our systems [the old 40 to 50 page procedures] to not enough documentation to understand the process [the one page procedure that does not tell you much]). Over the years, we have fluctuated back and forth a little, gradually finding ourselves somewhere near the equilibrium state between the extremes. Procedure sizes now run around a 4 to 5 page average size. We do have one or two documents which exceed 40 pages, but they are justified in our eyes(vendor safety manuals and such).
Hope this helps? E :rolleyes:
ralphsulser
#17
Russ
Russ said:
ralphsulser,
Not all are that long. I picked one of the longest "Non-Conforming Material Control" because it covers incoming, in-process, finished materials, plus customer issues. We actuall have a work instruction for this subject too.
So far has worked for our operations.
Randy Stewart
#19
Steve,
Here is a sample of what we are doing. This is a typical process flow, each box has 3 parts, top - responsibility, middle - function, bottom - link to forms, etc.
It has made process mapping a lot easier and process auditing a lot easier.
We are trying to eleminate all "procedures" and operate on process maps alone. Can't always do it but we are trying.
M Greenaway
#20
Again we appear, in my opinion, to be confusing the requirements to define sequence and interaction of processes with simply converting text based procedures into flowcharted procedures.
Flowcharting a procedure, as shown in the previous example, does not define a process, and its sequence and interaction.
In my opinion there must be a top level process map which shows all the major processes of the business. These processes can then be broken down into lower level sub-processes if required. You must show the processes, i.e. the things that convert inputs to outputs, you must show what the inputs and outputs actually are, and you must show where they come from and where they go to.
The example in the previous post is a procedure.
F Updating a Quality Manual from ISO 9001 to ISO TS 16949 - Process Mapping IATF 16949 - Automotive Quality Systems Standard 2
S Quality manual, Procedures, WI & process mapping for oil field chemical & Eqpt.trader Process Maps, Process Mapping and Turtle Diagrams 1
K Process Mapping - Inputs/Outputs/Detail Activities/Control points/Measurement? Process Maps, Process Mapping and Turtle Diagrams 4
R Process Mapping for a BPMS (Business Process Management System) vs ISO Process Maps, Process Mapping and Turtle Diagrams 1
M PDCA cycle - Process mapping - Environmental ISO 14001 ISO 14001:2015 Specific Discussions 1
R Process Mapping a Civil Infrastructure Construction company Process Maps, Process Mapping and Turtle Diagrams 4
L Mapping the loan lending bank process Process Maps, Process Mapping and Turtle Diagrams 7
R PPM, Pictorial Process Mapping, Templates Manufacturing and Related Processes 5
S ISO14001:2015 Factory Process Mapping ISO 14001:2015 Specific Discussions 7
O Process Mapping prior to Validation and Software to use to Map Process Maps, Process Mapping and Turtle Diagrams 12
B Macro Process Mapping (pre-GAP analysis) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Process Mapping Electronic Document Control Software Recommendations Quality Tools, Improvement and Analysis 5
D Is Process Mapping an ISO 13485 Requirement? Process Maps, Process Mapping and Turtle Diagrams 4
S Business Case for Process Mapping Process Maps, Process Mapping and Turtle Diagrams 4
A Information Technology Process Mapping per ISO 13485 - example wanted Process Maps, Process Mapping and Turtle Diagrams 1
L Qualiware Software & Process Mapping Process Maps, Process Mapping and Turtle Diagrams 7
F How does Process Mapping help to make a process more Transparent to the Customer? Process Maps, Process Mapping and Turtle Diagrams 2
M SIPOC (Suppliers Inputs Process Outputs Customers) Process Mapping Tool example Process Maps, Process Mapping and Turtle Diagrams 11
N Process Mapping a Private Company that deals with Insurance Process Maps, Process Mapping and Turtle Diagrams 8
J Definition Activity vs. Task - Definitions in Process Mapping and Projects Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
R Process VSM (Value Stream Mapping) help needed Lean in Manufacturing and Service Industries 5
H Process Mapping related to EMS for ISO 14001:2004 ISO 14001:2015 Specific Discussions 5
L Definition Poka Yoke, Process Mapping, MSA - What are these terms please? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
Q Change Management Process Mapping Process Maps, Process Mapping and Turtle Diagrams 7
R PPAP & Value Stream Mapping - How to eliminate waste in PPAP process APQP and PPAP 10
S Do you consider 'unintended' process output(s) while mapping a process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M ISO/TS 16949 Process Mapping (need examples) Process Maps, Process Mapping and Turtle Diagrams 5
A Process Mapping - for "Audits" - Detailed process map + macro map + FMEA Process Maps, Process Mapping and Turtle Diagrams 10
R Procedure for internal process mapping requests Process Maps, Process Mapping and Turtle Diagrams 9
V Process Mapping for a retailing chain Process Maps, Process Mapping and Turtle Diagrams 1
A Business Process Mapping help needed Process Maps, Process Mapping and Turtle Diagrams 2
1 Process Mapping for NonConforming Material Process Maps, Process Mapping and Turtle Diagrams 14
P Trend analysis - Common Mistakes of Sales Process Mapping Software Quality Assurance 2
Z Process Mapping Documentation Location and Control Process Maps, Process Mapping and Turtle Diagrams 5
J Insights on Graham (and other) Process Mapping software Process Maps, Process Mapping and Turtle Diagrams 5
M Business Process Mapping to comply with TS 16949 - Please review my Process Map Process Maps, Process Mapping and Turtle Diagrams 4
M Business Process Map - Kindly review my process mapping of my company Process Maps, Process Mapping and Turtle Diagrams 5
Q Business Process Mapping training that integrates Visio 2003 Process Maps, Process Mapping and Turtle Diagrams 5
M Process Mapping Approach - Please comment on my process map Process Maps, Process Mapping and Turtle Diagrams 10
H Process Mapping - I would like your opinions and advice on my process map Process Maps, Process Mapping and Turtle Diagrams 12
L How to start process mapping? Any sample please? Process Maps, Process Mapping and Turtle Diagrams 5
D Flow Chart and Process Mapping Software - Visio vs. Smartdraw Process Maps, Process Mapping and Turtle Diagrams 19
Z Looking for some examples of TS16949 process mapping Process Maps, Process Mapping and Turtle Diagrams 1
M Process Mapping - Process Flow and Interactions of Processes - ISO 9001 Process Maps, Process Mapping and Turtle Diagrams 124
Marc Business Process Mapping - A simple powerpoint .ppt presentation Process Maps, Process Mapping and Turtle Diagrams 0
P Criticize my Company wide Process Interaction Mapping IATF 16949 - Automotive Quality Systems Standard 4
Marc Flow charts - Show Me Yours! Systems Approach - Process Mapping Process Maps, Process Mapping and Turtle Diagrams 28
S Mapping ISO 9001 and CMM 2 (KPAs) - SEPG (Software Engineering Process Group) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
