Process Mapping for a BPMS (Business Process Management System) vs ISO
rogerpenna
Hello all.
We are in the verge of implanting a BPM System on my company.
I do not know if anyone has experience with BPMS software, but basically, you use BPM 2.0 Notation, creates digital forms, rules of flow, some javascript here and there, and then insert those forms, rules, etc, in activies, gateways, etc.
My question is regarding the ISO mapping of the process.
The process mapping for automation of the process must respect some computer as well as specific parameters of the BPM system being used for the automation.
That may involve making some important changes to the process mapping.
Let me describe an example... a process about identifying, analyzing and controlling risks.
If I mapped it on Bizagi Modeller, it would probably have an activity for "discovering risks", then "analyze risk" (some description to use a form where you identify the Risk Probability and Impact, and the result is how grave is the risk and thus how you should treat it), then deciding the next analysis (with return flow due to time decided earlier)...etc
Now... on a BPMS... the whole calculation of the Risk Graveness must be done through a process flow, where it gets the Impact and Probability of the risk input by the user and copies values to the form using XOR gateways, one for each IF (like a concatenated Excel IF).
Impact input: 3 - Moderate
Possibility input: 4 - High
Form itself calculates 3+4 and stores in a field. 7
XOR Gateway: if 0 or 1, follow this path to Script activity that inserts GRAVENESS - VERY LOW to Risk Accessment field...
if not, XOR Gateway: if 2 - 3, follow this path to Script activity that inserts GRAVENESS - LOW... etc, etc
I wrote all this to show how the mapping for a BPMS can be different from a normal process map made only for employees to auditors to analyze and understand the workflow.
Question is... would you use the BPMS mapped process for ISO documentation? Or it should not even be included there?
John Broomfield
Roger,
Eventually your organization’s BPM System combined with its leadership should exceed the requirements of ISO 9001.
I’d recommend not creating more than one system but you may consider your BPM System as a much more detailed (deeper) layer within your organization’s higher level Management System that conforms to ISO 9001.
John
K Process Mapping - Inputs/Outputs/Detail Activities/Control points/Measurement? Process Maps, Process Mapping and Turtle Diagrams 4
M PDCA cycle - Process mapping - Environmental ISO 14001 ISO 14001:2015 Specific Discussions 1
R Process Mapping a Civil Infrastructure Construction company Process Maps, Process Mapping and Turtle Diagrams 4
L Mapping the loan lending bank process Process Maps, Process Mapping and Turtle Diagrams 9
R PPM, Pictorial Process Mapping, Templates Manufacturing and Related Processes 5
S ISO14001:2015 Factory Process Mapping ISO 14001:2015 Specific Discussions 7
O Process Mapping prior to Validation and Software to use to Map Process Maps, Process Mapping and Turtle Diagrams 12
B Macro Process Mapping (pre-GAP analysis) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Process Mapping Electronic Document Control Software Recommendations Quality Tools, Improvement and Analysis 5
D Is Process Mapping an ISO 13485 Requirement? Process Maps, Process Mapping and Turtle Diagrams 4
S Business Case for Process Mapping Process Maps, Process Mapping and Turtle Diagrams 4
A Information Technology Process Mapping per ISO 13485 - example wanted Process Maps, Process Mapping and Turtle Diagrams 1
F Updating a Quality Manual from ISO 9001 to ISO TS 16949 - Process Mapping IATF 16949 - Automotive Quality Systems Standard 2
L Qualiware Software & Process Mapping Process Maps, Process Mapping and Turtle Diagrams 7
F How does Process Mapping help to make a process more Transparent to the Customer? Process Maps, Process Mapping and Turtle Diagrams 2
M SIPOC (Suppliers Inputs Process Outputs Customers) Process Mapping Tool example Process Maps, Process Mapping and Turtle Diagrams 11
N Process Mapping a Private Company that deals with Insurance Process Maps, Process Mapping and Turtle Diagrams 8
J Definition Activity vs. Task - Definitions in Process Mapping and Projects Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
R Process VSM (Value Stream Mapping) help needed Lean in Manufacturing and Service Industries 5
H Process Mapping related to EMS for ISO 14001:2004 ISO 14001:2015 Specific Discussions 5
L Definition Poka Yoke, Process Mapping, MSA - What are these terms please? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
Q Change Management Process Mapping Process Maps, Process Mapping and Turtle Diagrams 7
R PPAP & Value Stream Mapping - How to eliminate waste in PPAP process APQP and PPAP 10
S Do you consider 'unintended' process output(s) while mapping a process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M ISO/TS 16949 Process Mapping (need examples) Process Maps, Process Mapping and Turtle Diagrams 5
A Process Mapping - for "Audits" - Detailed process map + macro map + FMEA Process Maps, Process Mapping and Turtle Diagrams 10
R Procedure for internal process mapping requests Process Maps, Process Mapping and Turtle Diagrams 9
V Process Mapping for a retailing chain Process Maps, Process Mapping and Turtle Diagrams 1
A Business Process Mapping help needed Process Maps, Process Mapping and Turtle Diagrams 2
1 Process Mapping for NonConforming Material Process Maps, Process Mapping and Turtle Diagrams 14
P Trend analysis - Common Mistakes of Sales Process Mapping Software Quality Assurance 2
Z Process Mapping Documentation Location and Control Process Maps, Process Mapping and Turtle Diagrams 5
J Insights on Graham (and other) Process Mapping software Process Maps, Process Mapping and Turtle Diagrams 5
M Business Process Mapping to comply with TS 16949 - Please review my Process Map Process Maps, Process Mapping and Turtle Diagrams 4
M Business Process Map - Kindly review my process mapping of my company Process Maps, Process Mapping and Turtle Diagrams 5
S Quality manual, Procedures, WI & process mapping for oil field chemical & Eqpt.trader Process Maps, Process Mapping and Turtle Diagrams 1
Q Business Process Mapping training that integrates Visio 2003 Process Maps, Process Mapping and Turtle Diagrams 5
M Process Mapping Approach - Please comment on my process map Process Maps, Process Mapping and Turtle Diagrams 10
H Process Mapping - I would like your opinions and advice on my process map Process Maps, Process Mapping and Turtle Diagrams 12
L How to start process mapping? Any sample please? Process Maps, Process Mapping and Turtle Diagrams 5
D Flow Chart and Process Mapping Software - Visio vs. Smartdraw Process Maps, Process Mapping and Turtle Diagrams 19
Z Looking for some examples of TS16949 process mapping Process Maps, Process Mapping and Turtle Diagrams 1
M Process Mapping - Process Flow and Interactions of Processes - ISO 9001 Process Maps, Process Mapping and Turtle Diagrams 126
Marc Business Process Mapping - A simple powerpoint .ppt presentation Process Maps, Process Mapping and Turtle Diagrams 0
P Criticize my Company wide Process Interaction Mapping IATF 16949 - Automotive Quality Systems Standard 4
Marc Flow charts - Show Me Yours! Systems Approach - Process Mapping Process Maps, Process Mapping and Turtle Diagrams 28
S Mapping ISO 9001 and CMM 2 (KPAs) - SEPG (Software Engineering Process Group) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
V Process Mapping - Is there anyone using process maps to meet 4.1 requirements? Process Maps, Process Mapping and Turtle Diagrams 3
