Process revalidation periodic criteria
Vinu Raghav
Hi Experts,
Is there any packaging validation criteria for periodic revalidation?
According to ISO 11607-1;2019 section 9.3, 4 & 5, revalidation required only when the changes in existing process / validation
Is there any recommended timeline for revalidation, if there is no changes has been made in original process / validation?
Thanks in advance.
Tidge
The nature of the validation(*1) and the process(*2) ought to inform periodic assessments and if necessary re-validation.
(*1) for example, if the validation was "retrospective", that is probably a good candidate. If the validation resulted in the establishment of control charts, a review of the output parameters may indicate that a re-validation may be in order (e.g. as tools wear).
(*2) some processes may be particularly "critical" in some sense, other processes may have "too much" variability in outputs that have been historically tolerated. If the resources exist to revalidate, I wouldn't keep with processes where improvement can be introduced.
Vinu Raghav
Thank you for your detailed information.
We recently gone through notified body audit, where the auditor were asking for packaging revalidation frequency.
Can we choose 5 years to revalidate again if there is no changes in packaging process/material.
Tidge
I don't know the details of what's being packaged, so I can't provide a definitive answer. If there are no concerns about sterility or contamination, and there are no customer issues deriving from packing... I'd be unlikely to ever considering revalidating packaging... in the absence of some sort of design change.
planB
Quote from ISO 11607:2019, section 9.4:
The need for revalidation shall be evaluated and recorded. If the situation does not require that all aspects of the original validation be repeated, this revalidation does not have to be as extensive as the initial validation.
This seems to be copied from the respective GHTF guidance on process validation, section 6.4, with the rationale given in section 6.3:
Various changes may occur in raw materials and/or processes, which are undetected, or considered at the time to be inconsequencial. (An example of this type of process is sterilization.) These changes may cumulatively affect the validation status of the process. Periodic revalidation should be considered for these types of processes.
Thus, a stringent change control system that detects and catches these "various changes" might serve as a rationale why you would not have to perform periodic packaging re-validations on e.g. an unchanged sealing process. Packaging stability and performance are typically only re-validated in case of changes to packaging characteristics that might adversely affect the initial validation.
Experimental periodic process re-validation is typically mandatory for sterilisation only.
@Vinu Raghav: you might ask your auditor for the specific requirement for periodic packaging re-validation.
HTH,
B SPECIAL PROCESS VALIDATION & REVALIDATION Qualification and Validation (including 21 CFR Part 11) 5
C Revalidation of Process Equipment for Equipment Transfered to New Facility. ISO 13485:2016 - Medical Device Quality Management Systems 5
V Plating Supplier PPAP Revalidation Requirements - A-Coat GM 9984132 Plating Process APQP and PPAP 1
Sidney Vianna IAQG News IAQG 9401-1:2022 Changes & Organization Certification Analysis Process - OCAP Demo AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
E Process capability in a single batch Capability, Accuracy and Stability - Processes, Machines, etc. 3
Ashland78 IATF Process Control Plans not including customer name Manufacturing and Related Processes 13
S Sample size considerations in medical process qualification Reliability Analysis - Predictions, Testing and Standards 10
M Process flowcharts ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Small Company Implementing ISO 13485 Timeline/Process/Steps Advice ISO 13485:2016 - Medical Device Quality Management Systems 5
G Help Needed: Quality Control / Assurance process Quality Manager and Management Related Issues 3
T AS9100 Process Sequence and Interaction Map Example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Seeking help in validating a cleaning process. Manufacturing and Related Processes 5
R CNC process validation Manufacturing and Related Processes 1
T Process Sequence and Interaction Map AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
C Product compliance process REACH and RoHS Conversations 10
M Clinical evaluation process of FDA and MDR Medical Device and FDA Regulations and Standards News 2
V Countries without Formal Regulatory Approval Process Other Medical Device Regulations World-Wide 0
J Crimp inspection and process verification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Crimpshrine13 Bulk Process (Electroplating), Control Plan, and Process Change IATF 16949 - Automotive Quality Systems Standard 1
S Process Owner IATF 16949 - Automotive Quality Systems Standard 10
Bev D Development Process: FMEA, Critical Characteristics, Spec Setting and Controls Misc. Quality Assurance and Business Systems Related Topics 0
T Document Review Process Map AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Validation Plastic Injection Molding Process protocol ISO 13485:2016 - Medical Device Quality Management Systems 5
M Use of statistical techniques for Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 9
A Question regarding new VDA_AIAG fmea approach for process FMEA FMEA and Control Plans 0
S 9001 + 14001 Internal Auditing Process checklist, flowchart or questionnaire ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
L CQI-30 Special Process: Rubber Processing System Assessment - Mixing & Molding IATF 16949 - Automotive Quality Systems Standard 4
O Process Flow Diagram, DFMEA, PFMEA, Control Plan integrated softwares FMEA and Control Plans 7
C. Tejeda Process validation of rework assembly methods (medical devices) Medical Device and FDA Regulations and Standards News 3
L Looking for feedback on Nonconformity Process Flowmap ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Process Flow of ECN Product User and Service Guides Process Maps, Process Mapping and Turtle Diagrams 1
R Process Maps for ISO 17025 ISO 17025 related Discussions 2
L APQP Process Flow with CFT Roles and responsibilities APQP and PPAP 4
M Having Trouble Identifying KPI for Process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E Please help! ! I AM FRASTRATED SO MUCH! Should inactive ingredient be included in the unit formula if it is removed during the manufacturing process? US Food and Drug Administration (FDA) 0
I Supplier Evaluation Process ISO 13485:2016 - Medical Device Quality Management Systems 4
B A template for a injection molding process sheet with upper/lower- mean value tolerances Manufacturing and Related Processes 0
P ISO 9001: Quality Management as a process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
R How many process maps are adequate for a company for IATF 16949? Process Maps, Process Mapping and Turtle Diagrams 17
Q Process matrix 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Evaluate a process audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
J Best Practices for Choosing In-process Inspection Dimensions & SPC Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
T FDA PMA review process - advisory panel timing? Other Medical Device and Orthopedic Related Topics 0
K Process FMEA responsible For "Make to Design Parts" (Inhouse or Suppliers ?) FMEA and Control Plans 3
M Passivation Process Manufacturing and Related Processes 2
G Mfr. Process Validation BEFORE Design Transfer? Other Medical Device and Orthopedic Related Topics 1
M Clinical evaluation interface with the risk management process EU Medical Device Regulations 9
D Integrated Management System (IMS) - Process Vs Clause Based Audits ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
D IATF NC Interaction of process diagram - Missing contingency plan Process Maps, Process Mapping and Turtle Diagrams 9
J Cleaning Process for Delicate Parts Manufacturing and Related Processes 4
