Process to use Special Characteristics as FMEA Inputs
riversince83
Special Characteristic would be got from Customer, Regulation, and similar part FMEA. When we start to use FMEA, the special characteristic as above will be a base as well as an input to FMEA. The FMEA will also identify some new special characteristic by severity and occurrence. My question is that the input special characteristic will definitely to be defined as a high severity one that will link to our internal criteria (like severity : 9 -10) and be the same way to marked SC or CC? Should we use another symbol to identify it?
If the special characteristic from customer is been solved by Actions of FMEA, should it still to be put in the control plan?:thanx:
the process is as attachment.
qusys
Re: Process to use Special Characteristic as a input of FMEA
With regards to your second question , you shall insert the controls you put in place ( derived from P-FMEA for the specific potential failures you have identified) in your control plan. P-FMEA outputs feed the control plan. It could be unproper to say that actions of P-FMEA solve the identified risks: they shall be translated into controls used in control plan. For a right approach, you shall start from the process flow ( from incoming to shipping through production ) and identify/evaluate the potential failures. So, thake into consideration all the process flow, not partially including only production.
For the first question , consider that special characteristics can also be identified by the organization itself. In my opinion , it is unproper to say that special characteristic have a high severity, this shall be said for the the potential failure.
As to the identification with marks of the special characteristics, you shall confrom to the customer requirements for this clause (7.2.1.1). So, check this with your customer.
I think that at the end you will sign off a PPAP and in these documentation you can report all .
Hope this helps:bigwave:
E
erichau
Re: Process to use Special Characteristics as a FMEA Inputs
Please try to understand the definition of the special charateristic,
on the TS technical specification, it states that product characteristic or manufacturing process parameter which can affect safty compliance with regulations,fit,function,performance or subsequent processing product.
So when you develop the PFMEA, you may find some way to prevent it from happening frequently,but you can never change its importance, they still affect regulation,fit,function,performance or subsequent processing product. So the SC should be remained.
J 1.11 Preliminary Identification of Special Product and Process Characteristics APQP and PPAP 4
C How to define Process Special Characteristics (SC) FMEA and Control Plans 4
M How to identify Special Process Characteristics in FMEA FMEA and Control Plans 7
D QS-9000 Clause 4.2.3.2 - Special Characteristics on process flow diagrams APQP and PPAP 4
N Riveting - special process Manufacturing and Related Processes 11
qualprod ISO 9001:2015 8.5.1 f - Scope with customer special process requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L Injection Moulding Process (Special Process) Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
F CQI-23 Special Process Molding - Controls IATF 16949 - Automotive Quality Systems Standard 7
B AS9100 - Are special process suppliers required to be NADCAP accredited? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
x-files [Thermal powerplant] Why "Generation of electricity" is a special process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T "Special Process" Validation Requirements (21 CFR Part 820) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
P Customer Validated Special Process Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Z299 Special Process Supplement Document Manufacturing and Related Processes 1
J Is painting considered a Special Process as defined by ISO 9001 7.5.2? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Is Computer Helpdesk a Special Process ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J AS9100 C - Is Molding of Rubber Parts a Special Process (7.5.2)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A Is Quarry Blasting a Special Process according to 7.5.2? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
A Explanation of AS/EN 9100 Clause 7.4.1 Special Process Sources AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
R Specific Special Process requirements in TS 16949 for MIG Welding IATF 16949 - Automotive Quality Systems Standard 1
M Application of Special Process - Validation and FAI in Wind Tunnel Testing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
C Any CQI-Special Process related to Printed Circuit Boards (PCB)? IATF 16949 - Automotive Quality Systems Standard 1
sonflowerinwales Is there a Process Equivalent to NASA Special NDI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
R AS9100C Special Process Procedure - Work Instruction for AS9100 Clause 7.5.2 wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Seeking advice on how to handle a Special Process Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
R Special Process Checklists for Plating, Phosphate Coating, Welding and NDT AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S No Process Defined to Capture the Special Requirements of Customers Problem Solving, Root Cause Fault and Failure Analysis 10
S Anyone had a requirement for Conventional Machining as a Special Process? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Supplier Special Process System Assessments - CSR Requirements Customer and Company Specific Requirements 2
H AS9102A - What is meant by 5.2.5, "... approved Special Process sources..." AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Process Approach - Special Focus? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Seeking CQI-11 (Special Process Plating Assessment) Training Training - Internal, External, Online and Distance Learning 4
R CQI-15 Welding System Assess. & CQI-17 Special Process: Soldering Various Other Specifications, Standards, and related Requirements 6
B Is Design of Molds and Dies a Special Process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Is Heat Treatment for Metal a Special Process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 87
S Special Process Validation - ISO9001 Clause 7.5.2 - How do I go about it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
eternal_atlas Is cable jointing process is a special process like welding? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Stijloor Special Process Training from AIAG Training - Internal, External, Online and Distance Learning 0
D "Special Production Process" Validation and TS16949 Clause 7.5.2.1 IATF 16949 - Automotive Quality Systems Standard 5
Manix Definition Special Process Scope - CQI-11 & CQI-12 - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
C Laboratory Testing as a "Special Process" - element 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Stijloor New Special Process Guidelines are now available from AIAG IATF 16949 - Automotive Quality Systems Standard 18
S Welding - Is welding always a special process per ISO9001:2000 Clause 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
S Special Process definition - Clause 7.4.1 part d AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
C Special Process Validation - Electroplate - 7.5.2 of AS9100B AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
I Validation of Special Process - Soldering ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
N How to identify Special Cause(s) in a process? IATF 16949 - Automotive Quality Systems Standard 30
S I need help about Dyeing process - Is dying process a special process? IATF 16949 - Automotive Quality Systems Standard 9
A Process audit - Is it necessary to audit the special processes like plating? Process Audits and Layered Process Audits 2
A Removing the effect of special causes on Xbar-R chart - Centerless grinding process Statistical Analysis Tools, Techniques and SPC 6
Marc Definition Statistical Control - A stable process free of special causes Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
