Process Validation of Rotary Heat Sealer Speeds
Melissa
Hello Everyone,
I am looking for advice on a Validation protocol that I am doing...I am trying to validate the Line speed in correlation to speed dial setting. Its the speed of a Rotary Heat Sealer, any ideas on how to validate the speeds? :)
Thanks in Advance!
William55401
Quick response. Before executing a validation, you need to do the homework to define your process window. Some orgs call these "Engineering Evaluations". These result in technical reports that are an input to your formal OQ and PQ runs for validation. Said differently, before executing validations, figure out the parameters that will work to avoid the pain of explaining a validation failure , and then resolving it, within your QMS.
How would I approach the engineering evaluation? I would think high energy and low energy and center points. DOE is always a good tool at this stage. Your inputs are speed and temperature? Run low temp and high speed. Run high temperature and low speed. Use your planned acceptance criteria. (what makes the seal good) as the test to determine acceptability. The best is to have variable data as a success measure. You may have a couple of iterations of evaluations before you tell management you are confident in the parameters and probability of validation success is high.
Hope this helps. Have fun. Enjoy the ride.
Melissa
I would be using same temperature i need to figure out the speed at 2 specific dial settings. I would use the Peel Strength to determine acceptance. this was actually done backwards as the peel validation was done on temp and 2 speeds and went fine. I was told by the auditor that I need to validate the speeds (which are 6 and 8) and convert how many ft per minute run through the machine. Is this making sense?
William55401
Yes. This helps. The auditor wants to know (as should you) what does 8 (or 6) mean in terms of engineering units of measure. Your process input needs to be verifiable and defined in feet per minute. Think of this as an IQ task. Just like you have a controller that states temperature, how do you know it is correct? Orgs verify controller accuracy by using thermocouples as part of IQ. Apply the same thinking to the speed. How can you measure it to ensure 6 gets you exactly (with a tolerance) XX feet per minute. Periodic checks on the true speed delivered need to be part of your daily process checks. HTH.
Melissa
Thank you. Couldn't this be part of my revalidation later? I don't see the need to do daily checks as we do not use that machine daily.
V Rotary Tumbling Process Validation Manufacturing and Related Processes 5
B SPECIAL PROCESS VALIDATION & REVALIDATION Qualification and Validation (including 21 CFR Part 11) 4
B How to satisfy clause 5.7.1.5 process validation for valve production API 6D Oil and Gas Industry Standards and Regulations 13
C Validation of process for releasing the UDI EU Medical Device Regulations 4
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 9
mustomutlu Process Validation Final Report Other Medical Device and Orthopedic Related Topics 2
N Sterilization Protocol Change in Validation Process and further impacts ISO 13485:2016 - Medical Device Quality Management Systems 1
R PCBA process validation Qualification and Validation (including 21 CFR Part 11) 2
S Sterilization validation after changing sterilization process provider Qualification and Validation (including 21 CFR Part 11) 3
D Questions regarding process validation ISO 13485:2016 - Medical Device Quality Management Systems 15
A Validation of Forced Aeration Process ISO 13485:2016 - Medical Device Quality Management Systems 3
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
G Devices from IQ, OQ or PQ process to be used for verification, validation and summative? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
E Equipment Qualification - IQ/OQ per ISO 13485:2016 section 7.5.6 Process validation ISO 13485:2016 - Medical Device Quality Management Systems 7
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
N Validation procedure, Major NC CAP - Equipment Validation process is not effective ISO 13485:2016 - Medical Device Quality Management Systems 5
D ISO13485:2016 7.5.6 Process Validation Responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 1
Z Who is responsible for writing the validation of a new process? Manufacturing and Related Processes 7
M Requirement for manufacturing process validation in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 8
E Sampling plan for orthopedic implant - Process Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Z Class 2 medical device - Process Validation - Test sterile or non-sterile units? Qualification and Validation (including 21 CFR Part 11) 4
T ISO 13485:2016 - Processes exempt from process validation ISO 13485:2016 - Medical Device Quality Management Systems 12
L Injection Moulding Process (Special Process) Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
K Is Mold qualification / process validation always required? Manufacturing and Related Processes 7
R Process Validation on CNC Lathe and Milling machining process Design and Development of Products and Processes 1
Q Release of the first batch of a cleared product before process validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Process Validation sample size selection Statistical Analysis Tools, Techniques and SPC 0
P Auditing "process validation" process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
E Cleaning Validation Process of Non-Sterile Implants and Instruments Other Medical Device Related Standards 2
W Design and Process Validation - Different? ISO 13485:2016 - Medical Device Quality Management Systems 6
A Supplier - Process Validation Manufacturing and Related Processes 3
M Medical Device Process validation, Validation of excel spreadsheets used for process Other Medical Device and Orthopedic Related Topics 4
V Tyvek packaging for Medical device process validation Qualification and Validation (including 21 CFR Part 11) 2
L Process Definition and Process Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Can we sell units that were chosen for process validation? ISO 13485:2016 - Medical Device Quality Management Systems 6
S How do I do a Process Validation for soldering process Manufacturing and Related Processes 5
S Process validation when changing location ISO 13485:2016 - Medical Device Quality Management Systems 10
A Process Validation of QMS Software ISO 13485: 2016 Cl. 4.1.6 ISO 13485:2016 - Medical Device Quality Management Systems 26
P Root Cause for a Process Validation Batch Failure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
GoSpeedRacer Validation of Processes 7.5.6 - Do cosmetic welds need process validation? ISO 13485:2016 - Medical Device Quality Management Systems 3
A Is Aeration Process in ETO Sterilization Validation Required? Manufacturing and Related Processes 7
C Does Japan accept the Bracketing Approach for Process Validation Japan Medical Device Regulations 1
A Robotic Sanding and Painting Process Validation Manufacturing and Related Processes 5
alonFAI Gamma Irradiation Process Validation Help Other Medical Device Related Standards 2
J Where does process validation fit within design & development? Design and Development of Products and Processes 7
O Process Mapping prior to Validation and Software to use to Map Process Maps, Process Mapping and Turtle Diagrams 12
