Process Validation on Vision Inspection System
Nancylove
I have a question about validation vs. calibration of measuring equipment for a medical device company. A recent internal audit reported that we haven?t performed OQ/PQ on our vision inspection system for inspecting mechanical parts. This confuses me. This equipment is calibrated. I didn?t understand why measuring equipment that is calibrated also needs to have process validation. If process validation is required for measuring equipment such as a vision inspection system, is it required for all measurement equipment? Looking at 2 extremes: the vision inspection system and a digital caliper: Would process validation be required for both pieces of equipment after calibration has been performed?
Thank you much.
somashekar
Nancy ~~~
Welcome to the COVE.
Does your Vision inspection system gives out a measurement or it decides the Pass / Fail status of a part based on what you learn into the system.
Nancylove
Nancy ~~~
If you create a part program, part of the process is to enter the dimensions and tolerances. Then, when inspecting a part, the system will give you all of the measurement results and indicate all passing and failing characteristics.
Kales Veggie
People: The Vital Few
The simple question is:
How do you know the results are valid? How do you know the equipment is set-up correctly? Has the equipment been maintained properly? How do you know the software is correct and/or recently updated without effecting the results? Programmer made a change to the program, are the results still valid?
A calibration, maybe every 6 months, will not tell you this.
You need to validate the equipment before use.
(Caliper vs. Optical system: complexity, a lot more variables that can effect the final results).
somashekar
So it is a contactless optical (Vision) measuring equipment.
This is calibrated.
So if you have measures that safeguard the equipment from adjustments without authorization, protected from damage during use, maintenance and storage...
and the required equipment installation is done per the recommended guidelines aka IQ., you must be good.
The software used is not for a specified requirement, but the software that runs the equipment is the company provided equipment firmware that is necessary to use the measuring system.
I guess you are good and your internal audit just needs better process validation understanding.
bobdoering
Stop X-bar/R Madness!!
OQ/PQ has always been a painful concept to me, even when I was in medical (see posts on frustration with people tring to OQ/PQ bagging machines.)
But, let me put the issue in the simplest terms. There is gage error and measurement error. Two vastly different things. Gage error is the intrinsic error of the gage - it simply can't do any better. Measurement error is taking a perfectly good gage and using it incorrectly. You need to ensure they are both statistically insignificant for your requirements.
Nancylove
Kees, Someshekar, Bob Doering,
Thank you much for your responses. I think you all had input that validated my thoughts.
In my opinion, the equipment itself does not require OQ/PQ like Someshekar mentioned, but it does require IQ and PM. However, a test program and test setup should be validated. A vision inspection system is prone to measurement variations due to variations in part reflectiveness, part roughness, features related to or near the feature of interest, and anything else that can affect the lighting and imagery. This can affect the effectiveness of a program/setup validation.
Do you agree with my thinking?
Best regards,
Nancylove
sowmya
Involved - Posts
Hello Nancy
I agree, for each lot there may be a variation due to reflection, part roughness and features related to that. we use optical character verification as a tool for programming. what you are talking is a true call or false call.
how do you ensure that your programming is correct? the tolerances given while programming is within the boundary of screening good and bad parts?
what we do is, after each program, we do 100 % Visual inspection after AOI for first 100 parts. we also mix process indicators and confirm whether the programming is done correctly. This is for program qualification. for all batch productions, you have to fine tune the program for parameters like reflection, brightness...etc to reduce the false call. first 5 boards of each lot will be sent five times through AOI to confirm that it is producing same results every time.
The above process is developed in line with our own requirements. hope it helps
bobdoering
This is true, and the set-up of the lighting is a huge impact on the repeatability of teh measureemnt. Vision systems prefer lighting a bit darker than a visual observer. So, the technique for both locating points and features, and the setting and control of the lighting will be critical to its effectiveness.
N Sterilization Protocol Change in Validation Process and further impacts ISO 13485:2016 - Medical Device Quality Management Systems 1
R PCBA process validation Qualification and Validation (including 21 CFR Part 11) 2
S Sterilization validation after changing sterilization process provider Qualification and Validation (including 21 CFR Part 11) 3
D Questions regarding process validation ISO 13485:2016 - Medical Device Quality Management Systems 6
A Validation of Forced Aeration Process ISO 13485:2016 - Medical Device Quality Management Systems 3
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
G Devices from IQ, OQ or PQ process to be used for verification, validation and summative? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
E Equipment Qualification - IQ/OQ per ISO 13485:2016 section 7.5.6 Process validation ISO 13485:2016 - Medical Device Quality Management Systems 7
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
N Validation procedure, Major NC CAP - Equipment Validation process is not effective ISO 13485:2016 - Medical Device Quality Management Systems 5
D ISO13485:2016 7.5.6 Process Validation Responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 1
Z Who is responsible for writing the validation of a new process? Manufacturing and Related Processes 7
M Requirement for manufacturing process validation in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 8
E Sampling plan for orthopedic implant - Process Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Z Class 2 medical device - Process Validation - Test sterile or non-sterile units? Qualification and Validation (including 21 CFR Part 11) 4
T ISO 13485:2016 - Processes exempt from process validation ISO 13485:2016 - Medical Device Quality Management Systems 12
L Injection Moulding Process (Special Process) Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
K Is Mold qualification / process validation always required? Manufacturing and Related Processes 7
R Process Validation on CNC Lathe and Milling machining process Design and Development of Products and Processes 1
Q Release of the first batch of a cleared product before process validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Process Validation sample size selection Statistical Analysis Tools, Techniques and SPC 0
P Auditing "process validation" process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
E Cleaning Validation Process of Non-Sterile Implants and Instruments Other Medical Device Related Standards 2
W Design and Process Validation - Different? ISO 13485:2016 - Medical Device Quality Management Systems 6
A Supplier - Process Validation Manufacturing and Related Processes 3
M Medical Device Process validation, Validation of excel spreadsheets used for process Other Medical Device and Orthopedic Related Topics 4
V Tyvek packaging for Medical device process validation Qualification and Validation (including 21 CFR Part 11) 2
L Process Definition and Process Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Can we sell units that were chosen for process validation? ISO 13485:2016 - Medical Device Quality Management Systems 6
S How do I do a Process Validation for soldering process Manufacturing and Related Processes 5
S Process validation when changing location ISO 13485:2016 - Medical Device Quality Management Systems 10
A Process Validation of QMS Software ISO 13485: 2016 Cl. 4.1.6 ISO 13485:2016 - Medical Device Quality Management Systems 26
P Root Cause for a Process Validation Batch Failure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
GoSpeedRacer Validation of Processes 7.5.6 - Do cosmetic welds need process validation? ISO 13485:2016 - Medical Device Quality Management Systems 3
A Is Aeration Process in ETO Sterilization Validation Required? Manufacturing and Related Processes 7
C Does Japan accept the Bracketing Approach for Process Validation Japan Medical Device Regulations 1
A Robotic Sanding and Painting Process Validation Manufacturing and Related Processes 5
alonFAI Gamma Irradiation Process Validation Help Other Medical Device Related Standards 2
J Where does process validation fit within design & development? Design and Development of Products and Processes 7
O Process Mapping prior to Validation and Software to use to Map Process Maps, Process Mapping and Turtle Diagrams 12
M Justification for Not Having a Validation Plan for a Critical Process ISO 13485:2016 - Medical Device Quality Management Systems 4
alonFAI PCBAs Process Validation Help (Regulations FDA) Manufacturing and Related Processes 2
M Is Validation an ongoing process? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
K What are the minimum requirements for Process Validation (Software)? ISO 13485:2016 - Medical Device Quality Management Systems 5
P Process Validation of inherited tooling by Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 4
L GHTF/SG3/N15R8 - Process Validation and Risk Analysis ISO 13485:2016 - Medical Device Quality Management Systems 4
