Processes required for the Quality Management System (QMS)
L
Lorenzo36
We are registered to ISO 9001:2008, and during a recent QMS audit, our company was issued a finding related to 4.1(a) – determine the processes needed for the QMS. Accordingly to the auditor, some of our SUPPORT PROCESSES, i.e. Human Resources, were not clearly defined within our QMS. We corrected this by implementing a new diagram (or chart) identifying KEY PRODUCTION PROCESSES, SUPPORT PROCESSES and MANAGEMENT PROCESSES. This will suffice to correct the finding.
However, it raised other questions from our Management Team. For example, now that we’ve identified the support process, such as HR, Information Technology, Accounting – do we need to have procedures/instructions for each of those processes? Another example, for management processes, we included our annual Management Review – do we need a procedure for this as well? For the examples I mention we currently do not have procedures and instruction. Do we need procedures for each and every process identified in the new chart we’ve created?
Any thoughts / comments are greatly appreciated.
Chance
Re: Processes need for the Quality Management System
There is no requirement written in the ISO 9001 standard that requires you to document HR, IT and Accounting processes. But I am sure you guys have these processes set up and running. It is just not documented. If not, how do you operate then?
For Management review, the standard requires you to have it done in a regular basis. There are inputs required to it. Please read the standard. As long as you document what the inputs are and document the outcome as well, you should be okay. For us, we have created a procedure for clarity of what and who is going to present what during the Management Review meeting.
Hope this helps.
somashekar
Look at your business processes and map them to the ISO9001 standards requirements. Ensure that all the requirements as stated in the standard have a mapping from your business process, as the ISO9001 requirements are the most common sense and PDCA oriented, sequentially placed steps to an organization's operations, management and continued maintenance.
All of your processes will be having a procedure (the way that process is executed)
The only question that you have to answer is....
Are these procedures well understood and performed consistently by all the associated personnel ?
If yes, you have a procedure that stands justified to meet your requirement.
If no, you will have to document it and control it in order to meet your requirement.
Where the standard demands a documented procedure, you will have them.
For the rest you will determine if you want them based on your own levels of maturity.
insect warfare
QA=Question Authority
The answer to your question is posed by another - does your management team think that having a procedure for Management Review will add value somehow (please note that ISO 9001 paragraph 5.6.1 does require Management Review records...)?
If so, document accordingly...but don't complicate things just for the heck of it, and certainly don't do it for the auditor's sake...:nope:. There are many documentation horror stories out there that laughably resemble snowballs coming down the mountain, and for them it usually started with an innocent assumption that non-value added documents are somehow necessary.
The documentation requirements for ISO 9001:2008 are clearly defined in section 4.2.1 (they are just expanded on in the rest of section 4). Read it again, free the clutter from your mind, and you will see the forest for the trees...believe it.
Hope I've Helped...:rolleyes:
Brian
We can't tell you if you need a documented process or procedure - your organization has to decide!
Points to consider are - if a key player (process owner) is not available, how does anyone else know how to do that process? With many organizations facing retirement of their aging workforce, it's a good opportunity to ensure knowledge retention, too.
If a process isn't operated consistently across affected personnel is another reason to document something, too.
Brian: Good points, but often directly asking management isn't a good thing - it could be like asking someone if they need to wear a seat belt while driving in a car! If they look at past performance, they will say NO! If they understand risk/consequences of not doing something. When a question is asked, the answer should come in terms of their understanding of risk. So, just maybe, there's a different question to be asked first.
Chance
Perhaps identify the risks and present to Management and see what their inputs are.
insect warfare
True Andy, very true...
And then I just remembered this from ISO TR 10013 (Guidelines for QMS Documentation) section 4.2:
The purposes and benefits of having quality management system documentation for an organization include, but
are not limited to, the following:
a) describing the quality management system of the organization;
b) providing information for cross-functional groups so that they may better understand interrelationships;
c) communicating to employees managements commitment to quality;
d) helping employees to understand their role within the organization, thus giving them an increased sense of purpose and importance of their work;
e) providing mutual understanding between employees and management;
f) providing a basis for expectations of work performance;
g) stating how things are to be done in order to achieve specified requirements;
h) providing objective evidence that specified requirements have been achieved;
i) providing a clear, efficient framework of operation;
j) providing a basis for training new employees and periodic re-training of current employees;
k) providing a basis for order and balance within the organization;
l) providing consistency in operations based on documented processes;
m) providing a basis for continual improvement;
n) providing customer confidence based on documented systems;
o) demonstrating to interested parties the capabilities within the organization;
p) providing a clear framework of requirements for suppliers;
q) providing a basis for auditing the quality management system;
r) providing a basis for evaluating the effectiveness and continuing suitability of the quality management system.
Any one of these can become a reason to document something...
So, it can basically come down to how it will benefit your organization...
Brian
L
Lorenzo36
First of all, I want to thank all of you for input.
The management team is not suggesting that we have procedures for every process; the concern is whether it’s an ISO requirement, once we identify QMS processes. We obviously do not want non-value added activities in any of our process, including creating procedures that we may not need. For instance, management doesn’t feel the need to create procedures for HR or Accounting which are support processes; in our assessment we determined that over the years these two have functioned without any issues. We do know, however, that certain procedures are required (6) by ISO, i.e. Control of Doc, Control of Records, etc, etc (all implemented). In addition, we also know we should standardize some of our other Key Processes, which we have (Supplier Management, Receiving, Manufacturing, Design, Contract Review and Shipping – to name a few).
I've read the ISO 9001:2008 standard (and ISO 9000:2005 QMS Fundamental and Vocabulary), and I cannot find any requirements to help us make a well informed decision related to our problem.
So, again, if we identify HR and Accounting as a support process in our diagram (or Chart - QUALITY MANAGMEMT SYSTEM PROCESS), should we have procedures for those two? If yes, then procedures will be created. If no, then great!
Your thoughts?
M Is Validation of Plating Processes required and who is responsible? Qualification and Validation (including 21 CFR Part 11) 11
D How to Identify the Risks and Opportunities required for QMS Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B CQI-15 Welding System Assessment - Required for all of the welding processes we have? IATF 16949 - Automotive Quality Systems Standard 2
H Documented processes required by IATF 16949 section 4.4.1 IATF 16949 - Automotive Quality Systems Standard 1
H New IATF 16949 required Documented Processes IATF 16949 - Automotive Quality Systems Standard 5
S ISO 9001:2015 - Required Processes and required Documented Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Re-validation NCR - In which cases re-validation of processes is required Oil and Gas Industry Standards and Regulations 6
M Informational Is Identification of Risks and Opportunities required for QMS Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 96
M Process Approach: Types & number of processes required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
M Are there any Mandatory Processes required in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J Am I required to have specifications on file of processes done by suppliers? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
M Nadcap for Special Processes required for EDM AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
A Are Risk Analysis Studies required only for devices, or other processes too? ISO 13485:2016 - Medical Device Quality Management Systems 11
M List of Mandatory Processes to be Established and Maintained required by AS9100 rev C AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 13
R Outsourced Processes - Firm examples required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 34
K ISO/TS 16949:2009 Required Processes and Documented Procedure Requirements IATF 16949 - Automotive Quality Systems Standard 11
S Process Required - NC for not including HR and Maintenance in our Processes Sequence IATF 16949 - Automotive Quality Systems Standard 2
S TS 16949 Clause 7.5.1.1 - Control Plan - Control Plans required for ALL processes? IATF 16949 - Automotive Quality Systems Standard 2
T Defining Processes and their Interactions - Are Flowcharts Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Seeking: Ideas for Measuring the Processes as Required by ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
DuncanGibbons Additive Manufacturing Processes Thread Manufacturing and Related Processes 5
B Do you use paper or web-based templates for CAPA processes? ISO 13485:2016 - Medical Device Quality Management Systems 4
L Purge - Injection Molding Processes Manufacturing and Related Processes 5
Stoic Manual soldering processes - 100% verifiable, or always requiring validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
BeaBea How Many Processes should be created for each Department? Process Maps, Process Mapping and Turtle Diagrams 5
S How do you record your Nonconforming product? Batch production of staged processes Nonconformance and Corrective Action 2
J A tale of two processes. Design and Development of Products and Processes 2
GreatNate Where to get a KPI dashboard for QMS processes Quality Tools, Improvement and Analysis 5
U What is the process for making updates to our Processes? Design and Development of Products and Processes 11
G Control Plan - Include the processes for each sub component? APQP and PPAP 2
U Changes to Internal Processes and Risk Evaluation - Mitigations Risk Management Principles and Generic Guidelines 10
L Special Processes - Technical reason concerning torque - Anaerobic compounds Manufacturing and Related Processes 10
Q Shortening processes complying with process approach ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
L AS9100 and Agile development processes AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
S NADCAP approval for Conventional Machining and Chemical processes - need assistance AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 10
M Inputs on definition of very similar processes for multi site audit sample - IAF MD1 2018 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Specific processes - Construction management field Service Industry Specific Topics 2
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
Q Write down same nonconformity in several processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J ISO 9001 8.4.1 - Determining controls applied to externally provided processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T ISO 13485 8.2.5. Monitoring and measurement of quality management system processes ISO 13485:2016 - Medical Device Quality Management Systems 1
G Infrastructure and Environment for the operation of processes (ISO 9001 7.1.3 & 7.1.4) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Linking the Processes of Continual Improvement, Change Management, Risk Management, Action Planning, etc? Preventive Action and Continuous Improvement 5
S Outsourced processes how to interact with projects - We are an governmental department with 2 persons ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D How about another torque discussion? Assembly processes General Measurement Device and Calibration Topics 9
D Yet another torque question... Assembly processes AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
M Informational USFDA Draft Guidance – Review and Update of Device Establishment Inspection Processes and Standards Medical Device and FDA Regulations and Standards News 0
M APQC PCF (Process Classification Framework) and ISO 9001 - Processes Based Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Calculate number of people in processes, considering cycle time/takt time = quantity of people Lean in Manufacturing and Service Industries 9
