Producing IATF 16949 compliant calibration certificates
#11
So a couple of things: Firstly terminology - it's accredited to ISO/IEC 17025. Not certified - an important difference.
Secondly, as the manufacturer, YOU aren't responsible for the calibration of the wrench, the buyer organization is. If you don't provide an accredited 17025 certificate, then the buy must go elsewhere and get their calibration done. Simples!
Golfman25
#12
The outside calibrator is the manufacturer of the test unit and they are certified to the 17025 lab standard. Their software actually produces page two and three of the certificate package, but page one, the actual cert, needs to be dressed up to Name the calibration lab and place the serials and cal data as I see it.
But other than that we should be OK, right?
Idk, but lets break it down.
You make a wrench.
You calibrate the wrench during assembly based on calibrated testing equipment which is done by a 17025 lab.
You issue a calibration certificate that the wrench is "good" based on your testing.
Your customers complain because your certificate doesn't show you are 17025 accredited, because you are not.
They don't like it because now they have to explain something to "the auditor."
Well in order to meet the equipment manufacturer "exception" your customer has to ensure you meet the 7.1.5.3.1 requirements. Basically 5:
a) adequacy of procedures
b) competency of personnel
c) testing of the product
d) capability to perform correctly and traceability
e) customer requirements
f) review of related records.
I don't know if naming the calibration lab "works" because they are not calibrating the wrench. You're showing traceability which is on part. It sounds to me like you will have to show the balance of the requirements as well.
You may need to sit with your customer and figure out what they need. My guess is they haven't really thought about it.
Golfman25
#13
Actually most buyers would not want to do this as it is probably not necessary. After some use, then certainly they are on their own.
mlee97
#14
You make a wrench.
From my point of view I consider the externally contracted lab to be the defacto calibrator as the testing is robotic and set up by them. We don't touch it. It could be considered the same as if it were magically shipped to their location, calibrated, and zapped back. Their procedures, conformance and their calibration records would be by their control and on their accreditation. The only action by our people is to place the wrench on the unit and press go.
If we set up the certification by the contractor's name, with their blessing of course, wouldn't this meet the IATF requirements without an exception?
Golfman25
#15
I wouldn't think that your provider would allow you to "use their name" to issue certificates. From your customers perspective, I think you would still have to meet 7.1.5.3.1 -- such as competency of personnel to place the wrench on the test unit. It's a grey area and will depend on what your customer needs. Realize this is probably driven by someone getting ready for an audit, or maybe in an audit, who realizes your cert doesn't have the magic 17025 on it. At the end of the day, it might be easier for them to send it out to an accredited lab for calibration.
mlee97
#16
The calibration provider would have to like it or they would cease getting paid of course. We would have no use for them if they refused to provide a useful service. Our requirements that the system provider pass their MSA using our personnel loading should cover the placing of the wrench on the unit fixture. Again, I don't see how having an on-site calibration provider makes any difference to having the wrench sent out to them for calibration. Why would the physical location of the service matter in any way and how would the IATF separate the two? Why do you insist that physical location at the time of calibration matters?
Remember, the calibration equipment provider and calibration company are one and the same and they are under contract to provide a TS worthy (before IATF change) calibration certificate as I understand it.
Golfman25
#17
The calibration provider would have to like it or they would cease getting paid of course. We would have no use for them if they refused to provide a useful service. Our requirements that the system pass their MSA using our personnel loading should cover the placing of the wrench on the unit fixture. Again, I don't see how having an on-site calibration provider makes any difference to having the wrench sent out to them for calibration. Why would the physical location of the service matter in any way and how would the IATF separate the two? Why do you insist that physical location at the time of calibration matters?
They are calibrating your equipment and providing you with a certificate. If you where seeking IATF certification you would be good.
But now you are sending the wrench to your customer. It's calibrated off your calibrated equipment. Your certificate is the issue. Your customer needs something that will pass an audit. It's really their problem, not yours. You can help if they tell you what to do. But I don't think you'll get your calibration house to let you issue their certificate to your customers. You just have to figure out the easiest work around.
It's no different than when we have our scales calibrated by the manufacturer. Problems always arise because they don't have 17025. It's easier to have the guy that does our cmm do our scales as well.
mlee97
#18
No, I think it is different because the certificate is generated off contracted equipment, maintained and monitored by that contractor, from the equipment manufacturer and that contractor/manufacturer is ISO/IEC 17025 accredited.
In your example - Suppose you hired a company to calibrate your gage weights that you make. The company is long term contracted to maintain the robotic scale and equipment at your site as opposed to theirs. They perform a MSA with the operators provided by your company to place the weights on a robotic fixture for loading and measuring with a cert printing out at the end of the line with the recorded values being networked to the manufacturer/contractor. The manufacturer contractor is up to date and accredited ISO/IEC 17025.
Now according to the external lab requirement of IATF, it appears that we only lack having to have the company update their certs with their name and the ISO/IEC 17025 accreditor logo. Do you agree?
Golfman25
#19
Sure. But I think your obstacles will be their cert and what it means to their accreditation to have off site certs generated. What do they say?
mlee97
#20
Well while their C of A does mention a satellite location, it doesn't mention ours. So that is the big hole they'd have to fix. I think corporate will have to decide if they want to spend or fight to get their accreditation updated, or throw in the towel and take over the whole shebang.
I think we have paid way too much to throw in the towel just yet. Perhaps the agency will cut them a break to add the one machine satellite location. Even $20k would be cheaper than shipping the wrenches out at this point. Maybe even cheaper would be to just pay for a recalibration to any company that complained..
Q IATF 16949 Scope - Producing multiple products IATF 16949 - Automotive Quality Systems Standard 5
qualprod What tier number fits in a company producing paper labels stuck on automotive parts? IATF 16949 - Automotive Quality Systems Standard 7
B Quality Plan Template for producing a New Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 8
C X-Ray Producing Product Regulations in Mexico, Central America, and South America Other Medical Device Regulations World-Wide 2
D Retrospective Validation - Producing Product Over 10 Years Qualification and Validation (including 21 CFR Part 11) 7
N AS9102 Internet Service for Producing FAIR's to AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Producing a supplier audit system for my TS 16949 organisation IATF 16949 - Automotive Quality Systems Standard 2
S PPAP on Prototype tooling? Producing components for internal customer (assembly) APQP and PPAP 5
Q Is there an international system standard for producing electrical components? Various Other Specifications, Standards, and related Requirements 1
P SPC in job shop? CNC machine producing a max of 50 pieces per job Statistical Analysis Tools, Techniques and SPC 4
A Audit day - Production Planning - Must we be producing product? General Auditing Discussions 14
S APQP Timetable - The stage to producing a sample - Seeking Advice IATF 16949 - Automotive Quality Systems Standard 5
V Micro Contamination - Emoderivates (producing albumin, etc from human plasma) ISO 13485:2016 - Medical Device Quality Management Systems 1
M New IATF Sanctioned Interpretations April 2021 IATF 16949 - Automotive Quality Systems Standard 2
L Eligible for IATF or eligible for LOC ? IATF 16949 - Automotive Quality Systems Standard 2
N IATF Calibration Lean in Manufacturing and Service Industries 5
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 24
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 0
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
M IATF Icon pack /PNG IATF 16949 - Automotive Quality Systems Standard 0
S Advantages and disadvantages on IATF corporate scheme IATF 16949 - Automotive Quality Systems Standard 2
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
Q Contingency plan - IATF Sanctioned Interpretation 17 IATF 16949 - Automotive Quality Systems Standard 4
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
R IATF Oversight certificates General Auditing Discussions 5
Sidney Vianna IATF 16949 News Update on the IATF CARA Project (“Common Audit Report Application”) - 12/2020 IATF 16949 - Automotive Quality Systems Standard 1
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
Sidney Vianna IATF 16949 News IATF Observer Guideline IATF 16949 - Automotive Quality Systems Standard 5
G IATF Rules for COVID 5th revision - Re-certification audit timing IATF 16949 - Automotive Quality Systems Standard 3
L IATF external audit virtual (remote) IATF 16949 - Automotive Quality Systems Standard 13
T IATF Rules for sharing production space with another company IATF 16949 - Automotive Quality Systems Standard 10
W Allowing our IATF to Expire Due to Relocation. Any Backlash? IATF 16949 - Automotive Quality Systems Standard 3
B Revision 5 to IATF Coronavirus Pandemic (Covid -19) IATF 16949 - Automotive Quality Systems Standard 0
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
