Product Audit Checklist according to ISO/TS 16949
dbzman
#11
Wouldn’t a product audit look at the inspection system itself? While the inspection functions job is to verify a product against a specification or some criteria the product audits job is to verify that the product is being made and inspected correctly.
The inspection function would use a spec to verify that the product is correct.
The product audit would verify that the specification is the correct one.
Is this right?
:bonk:
K
kp24982
#12
Can we perform Product & Process audit simultaneously? If yes then how? Please specify the format for filling the same.
KP
qusys
#13
KP
It could be better to plan product audit within annual internal audit program as an item apart. This because you can soon demonstrate that you are accomplishing the related clause of the standard.
:bigwave:
qusys
#14
:bigwave:
Remember that product audit has under the scope only automotive parts you are producing. In the process audit you should also internally audit processes that do not produce automotive parts as well...:bigwave:
suresh-k
#18
Product audit is a requirement of ISO TS and shall be included in the audit plan. The inspection that you are dealing with are related to the normal operations activities as per internal procedures.
Personnel that perform audit shall be independent and cannot audit their own job. Based upon this, I would suggest not to consider product audit the inspection you mentioned. Product audit shall be conducted along all the process flow, from incoming to shipping through production, taking a sample, and go backwards, checking also to raw material usage ,for example, as well as the control set on control plan.:bigwave:
dear sir,
my self suresh,
I'm for wiring harness industry.
I want product audit check sheet as per TS 16949.
if you share your product audit form as a example it is most helpful.
regards,
suresh.k
#19
Hello Suresh. Welcome!
We cannot provide you with a checklist, since we have no idea what your product is. The best person to create a checklist is to do it within your own organization. You know your product, the requirements, the quality issues etc better than anyone.
suresh-k
#20
Dear Sir,
Thanks for your reply
Our product is wiring harnesses for buses , trucks,
we are automotive and non automotive supplier.
What exactly my question is "is product audit to conducted in each stages of product? for an example our first stage is wire cutting , crimping, then sub-assembly, continuity test and final inspection.
in the mentioned above each process 'should I take only one part or irrespective of part we have to audit in each stage?
Regards,
Suresh.K
D What are the important things to keep track of in product audit checklist? Software Quality Assurance 3
K Please share a Product Audit Checklist for a Wafer Fab Document Control Systems, Procedures, Forms and Templates 3
L EN 45011 (European Standard for Product Certification) Audit Checklist needed Other ISO and International Standards and European Regulations 3
harrysons Product Audit Checklist - Please give some advice or share your opinions Software Quality Assurance 10
D Process and Product Audit Checklist - Product Realization, Effectiveness of Process General Auditing Discussions 8
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
F Product audit sampling plans IATF 16949 - Automotive Quality Systems Standard 3
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
B Is it necessary to conduct product audit of entire product which is manufactured in the company as per IATF IATF 16949 - Automotive Quality Systems Standard 4
Q IATF 16949 - Product audit - Must each product be audited? IATF 16949 - Automotive Quality Systems Standard 6
U Dock Audits - Isn't waiting to do an audit when the product is "supposed" to ship a little late? Manufacturing and Related Processes 12
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Manufacturing and Product Audit Approach IATF 16949 - Automotive Quality Systems Standard 19
B TS16949 Section 8.2.2.3 Product Audit - Requirements for various Customers IATF 16949 - Automotive Quality Systems Standard 10
Q Internal Audit of Product Quality Complaint System (21 CFR Part 820) Customer Complaints 9
C TS16949: Product Audit vs. "Regular Checks" Internal Auditing 1
P May I combine the Process Audit and Product Audit into Delphi's LSR? Customer and Company Specific Requirements 3
J Questionable Audit Finding about Revision Levels of Product Manual CD's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Requirement for NB audit with Discontinued Product EU Medical Device Regulations 3
J Product and Process Audit according to ISO/TS 16949:2009 Process Audits and Layered Process Audits 9
S Supplier Audit Questionnaire for aerospace product suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C Anvisa Manufacturer Audit - Product produced at two different Sites Other Medical Device Regulations World-Wide 3
W Definition Product Audit - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
O Product Audit for Rubber Parts for Automotive Industry IATF 16949 - Automotive Quality Systems Standard 3
Q How to Audit the Client Quality System - Product Failure caused by no Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Non-Conforming Product vs. Supplier Audit Finding Supplier Quality Assurance and other Supplier Issues 8
Q Product Audit Check List according to VDA VDA Standards - Germany's Automotive Standards 1
A Seeking: documentation for intrinsically safe product audit General Auditing Discussions 6
A How to calculate the Effectiveness of the Process and Product Audit System Internal Auditing 10
michellemmm Software Product Development Quality Assurance (PDQA) Audit Checklists Software Quality Assurance 12
Q Product Characterization Audit - What is "Characterization" IATF 16949 - Automotive Quality Systems Standard 7
D Dock Audit (Product Audits and Process Audits) database wanted Quality Assurance and Compliance Software Tools and Solutions 20
Q What should be Audited in a Product Audit IATF 16949 - Automotive Quality Systems Standard 14
A Product Audit - Traceability of Sand used Internal Auditing 8
B What is in a Product Audit? TS 16949 Clause 8.2.2.3 Process Audits and Layered Process Audits 21
K Help in meeting the requirements in 8.2.2.3 Product Audit of TS 16949 IATF 16949 - Automotive Quality Systems Standard 5
I Definition Product Audit vs. Dock Audit vs. Layout Audit - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 29
V Is Product Audit Mandatory as per ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 19
somashekar Product audit for using the safety mark (ETL) on label Other Medical Device and Orthopedic Related Topics 2
Ajit Basrur Process and Product Audit format needed Process Audits and Layered Process Audits 1
R Product Audit Summary Form needed IATF 16949 - Automotive Quality Systems Standard 5
B What is the full name of QKZ in product audit? IATF 16949 - Automotive Quality Systems Standard 8
H Product Audit - TS 16949 Clause 8.2.2.3 IATF 16949 - Automotive Quality Systems Standard 18
K Mock Audit Log Form Template for Product Recall/Return at Food Plant Document Control Systems, Procedures, Forms and Templates 8
P Product Audit looking at Conformity, not Effectiveness General Auditing Discussions 6
C Audit NonConformance - Evidence of Post Market Vigilance and Product Recall. ISO 13485:2016 - Medical Device Quality Management Systems 6
J AS9100 Clause 7.4.3 Verification of Purchased Product (audit Finding) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 30
Q Dock Audit - Reasons to do dimensional checks during product dock audit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Icy Mountain Product Audit Process Requirements - Clause 8.2.2.3 IATF 16949 - Automotive Quality Systems Standard 35
H Specification Description - Product audit on the production floor IATF 16949 - Automotive Quality Systems Standard 4
