Product Audit - Explanation and samples of the report - TS 16949
mazura
Registered Visitor
Can anyone give some explanation and samples of the report for conducting product audit. Meaning how do I go about it? Our company is the manufacturer of automotive battery. In TS we need to do product audit. from where shall we start the product audit.
please advice.
thanks
D.Scott
There is no specific report for a product audit. You can use whatever form you like. An audit should look at one specific job or product and follow it from start to finish. Choose one job, get the work instruction and follow it through every step of your system to determine if the planned process is being followed and the requirements/expectations of the process are being met. the audit should cover all steps of the process from receiving raw material through delivery to the customer.
Another variation is to start from the other end (reverse product audit). Get the documented paperwork for a specific lot and work backwards through the system to determine everything had been done and all requirements had been met and documented.
Hope this helps get you started.
Dave
SilverHawk
Under TS Internal (product) audit - who should conduct this audit??
The QA guys or a separate internal auditors????
H
Hisar - 2009
To complete the explanation above, I add some other points. Please prepare the procedure to conduct product audit to explain at which production and delivery stages product audit should be done and their frequency. Establish annual Audit plan and appoint qualified auditor (independent personnel) to do the audit. Ensure what requirements sould be the product fulfilled by each process.
Hisar
D.Scott
Good points for your internal audit plan but I wouldn't limit product audits to the planned internal audit program. I would consider these audits to be supplemental to the normal audit schedule. They can be done by the plant/function/department who is in charge of the product to confirm the process is still robust and delivering the expected results. I also wouldn't limit the auditors to "independent" auditors. True, they shouldn't audit their OWN work but people who work in the department certainly understand the process and have a good understanding of the normal product flow.
Product audits are often done in addition to the annual internal audits and are scheduled at the discretion of the department or by need established through customer complaints or C/I. These audits are often a part of a "layered audit" program.
Dave
antoine.dias
please advice.
thanks
A good guidance can be found in VDA 6.5 - Product audit
Best regards and success,
Antoine
V
Valeri
For a product audit, we walk the control plan. My preference is to walk it backwards starting with a couple of containers on the shipping dock and tracing through the process back to incoming material used in production.
Just out of curiousity, why the preference for backwards?
D.Scott
One reason some people prefer the backwards audit is time limitations. When doing a reverse audit, the test documentation and inspection results are already there so you don't have to wait. I would also be interested in why it is Valeri's preference.
IMO, the forward audit allows a better look at how the process actually works because you follow the part through.
Dave
V
Valeri
Yes, the records (including gages, PMs, operator instructions/reactions, testing, set-ups, maintenance issues, etc.) are there (usually) and the operators explain their process. When auditing the system, I don't have the luxury of waiting for parts to be produced; I use the control plan identified in the planning/process design audit and walk it backwards.
Additionally, all plants perform layered audits on every process to make sure it actually works the way it's supposed to. This is where we find the majority of issues - some are systemic - most are not.
When I'm called into a plant to do a product audit, I audit the control plan forward after reviewing the process flow, FMEA, customer requirements and drawings. The longest (worst?) product audit I performed lasted 2 days for each audit. :( You can imagine the results.
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
F Product audit sampling plans IATF 16949 - Automotive Quality Systems Standard 3
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
D What are the important things to keep track of in product audit checklist? Software Quality Assurance 3
B Is it necessary to conduct product audit of entire product which is manufactured in the company as per IATF IATF 16949 - Automotive Quality Systems Standard 4
Q IATF 16949 - Product audit - Must each product be audited? IATF 16949 - Automotive Quality Systems Standard 6
U Dock Audits - Isn't waiting to do an audit when the product is "supposed" to ship a little late? Manufacturing and Related Processes 12
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Manufacturing and Product Audit Approach IATF 16949 - Automotive Quality Systems Standard 19
B TS16949 Section 8.2.2.3 Product Audit - Requirements for various Customers IATF 16949 - Automotive Quality Systems Standard 10
K Please share a Product Audit Checklist for a Wafer Fab Document Control Systems, Procedures, Forms and Templates 3
Q Internal Audit of Product Quality Complaint System (21 CFR Part 820) Customer Complaints 9
C TS16949: Product Audit vs. "Regular Checks" Internal Auditing 1
P May I combine the Process Audit and Product Audit into Delphi's LSR? Customer and Company Specific Requirements 3
J Questionable Audit Finding about Revision Levels of Product Manual CD's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Requirement for NB audit with Discontinued Product EU Medical Device Regulations 3
J Product and Process Audit according to ISO/TS 16949:2009 Process Audits and Layered Process Audits 9
S Supplier Audit Questionnaire for aerospace product suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C Anvisa Manufacturer Audit - Product produced at two different Sites Other Medical Device Regulations World-Wide 3
W Definition Product Audit - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
O Product Audit for Rubber Parts for Automotive Industry IATF 16949 - Automotive Quality Systems Standard 3
Q How to Audit the Client Quality System - Product Failure caused by no Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L EN 45011 (European Standard for Product Certification) Audit Checklist needed Other ISO and International Standards and European Regulations 3
A Non-Conforming Product vs. Supplier Audit Finding Supplier Quality Assurance and other Supplier Issues 8
Q Product Audit Check List according to VDA VDA Standards - Germany's Automotive Standards 1
A Seeking: documentation for intrinsically safe product audit General Auditing Discussions 6
A How to calculate the Effectiveness of the Process and Product Audit System Internal Auditing 10
michellemmm Software Product Development Quality Assurance (PDQA) Audit Checklists Software Quality Assurance 12
Q Product Characterization Audit - What is "Characterization" IATF 16949 - Automotive Quality Systems Standard 7
R Product Audit Checklist according to ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 24
D Dock Audit (Product Audits and Process Audits) database wanted Quality Assurance and Compliance Software Tools and Solutions 20
Q What should be Audited in a Product Audit IATF 16949 - Automotive Quality Systems Standard 14
harrysons Product Audit Checklist - Please give some advice or share your opinions Software Quality Assurance 10
A Product Audit - Traceability of Sand used Internal Auditing 8
B What is in a Product Audit? TS 16949 Clause 8.2.2.3 Process Audits and Layered Process Audits 21
K Help in meeting the requirements in 8.2.2.3 Product Audit of TS 16949 IATF 16949 - Automotive Quality Systems Standard 5
I Definition Product Audit vs. Dock Audit vs. Layout Audit - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 29
V Is Product Audit Mandatory as per ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 19
somashekar Product audit for using the safety mark (ETL) on label Other Medical Device and Orthopedic Related Topics 2
Ajit Basrur Process and Product Audit format needed Process Audits and Layered Process Audits 1
R Product Audit Summary Form needed IATF 16949 - Automotive Quality Systems Standard 5
B What is the full name of QKZ in product audit? IATF 16949 - Automotive Quality Systems Standard 8
H Product Audit - TS 16949 Clause 8.2.2.3 IATF 16949 - Automotive Quality Systems Standard 18
K Mock Audit Log Form Template for Product Recall/Return at Food Plant Document Control Systems, Procedures, Forms and Templates 8
P Product Audit looking at Conformity, not Effectiveness General Auditing Discussions 6
C Audit NonConformance - Evidence of Post Market Vigilance and Product Recall. ISO 13485:2016 - Medical Device Quality Management Systems 6
J AS9100 Clause 7.4.3 Verification of Purchased Product (audit Finding) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 30
Q Dock Audit - Reasons to do dimensional checks during product dock audit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Icy Mountain Product Audit Process Requirements - Clause 8.2.2.3 IATF 16949 - Automotive Quality Systems Standard 35
H Specification Description - Product audit on the production floor IATF 16949 - Automotive Quality Systems Standard 4
