Product Audit Planning / Frequency /Scope - Is anyone aware of preferred methods?
Boro Col
Is anyone aware of preferred methods of planning product audits (i.e. how many product types/ customers per annum)?
Currently working with company that has over 30 product types spread across several automotive customers. Batch sizes are relatively small and infrequent.
Can anyone offer practical guidance on this matter?
Am considering scheduling one product audit per month with the aim of covering spectrum of generic parts manufactured - would this be acceptable to a TS16949 3rd party assessment body?
Marc
Is anyone aware of any related TS 16949 requirements? I'm not off hand.
Myriam
We are a QS9000 certified company (still), and TS16494 audit is scheduled for March this year. Therefore I am not completely sure this will be accepted by a 3th party audit; but for QS9000 it was accepted and we will not change it for the TS.
We base our product audit frequency on the customer complaint evaluation results and other audit results. At first we had a frequency of once per month. Actually 12 per year, because if we skip one month for whatever reason we can perform two in the next month.
We specified 12 per year because the number of complaints has improved (decreased) drastically, and also the impact of the compaint-product to the customer improved quite a lot, and therefore we were confident that the process is under control.
During last year as a result of the product audits and a serious customer complaint we decided to perform extra product audits on one production item.
So, in my opinion you can decide to perform product audits at some frequency your self, if you are confident that for your company once per month is OK, you should do so; and if concidered necessary you can allways change the frequency.
Myriam
V
vanputten
8.2.2.3 Product Audit
I beleive Boro Col is asking for help in meeting the requirements in 8.2.2.3 Product Audit of TS 16949.
We have always used our inprocess inspections and final inspections performed by the quality department which is independent to the inprocess and final inspections performed by product realization employees.
We don't do a formal "Product Audit." We decided not to do this becasue the internal auditors did not know all of the product dimensions, functionality, etc. The internal auditors would have had to ask for help from those that perform the product inspections anyway. We decided that a Product Audit performed by the internal auditors was not a value added activity.
Regards,
Dirk
Myriam
Dirk, I understand your reply. With our company it is also the case that internal auditors do not know all product dimensions etc, and tests are performed by independend inspectors.
Nevertheless we perform product audits, and amongst other items a sample taken by the internal auditor is tested by the laboratory.
A product audit for us is verifying conformity to all (customer) requirements, so we take the original order/ contract and we audit if the customer specific requirements are implemented correctly in the organisation for this product. e.g. are the dimensions etc the inspectors are working with the correct ones, do they have the last revision adn are they working according to these requirements. We also include the packaging, processconditions etc into the product audit.
Myriam
Naturlijk............
Myriam. That's great advice.:agree1:
Use customer issues (complaints and such like) first as a priority and then use internal indicators of past 'caught' problems and after that, new products. Use 'risk' as the main driver. I had no issues over at least two 3rd party audits and a couple of 'corporate' audits. And performance improved too!
Andy
MONIA
I have question concerning manufacturing audit plan? Szhould it be done like each step of the process once a week. So for example molding, trimming, packing each once a week? Should incoming control and despatch be a part of that? Maybe someone has an example of manufacturing process form (sheet) and plan?
xfngrs
Confusion. We are currently being audited and being told that product audits are by nature redundant. That we would maybe take a part out of somewhere on the assembly line and have someone measure it, recording the measurements. You label the part and set it aside and later someone else takes the exact same measurements.
If we add it as a normal measurement to a checklist, it is no longer a product audit as it is a regular thing. It would have to be for a limited time.
Is this everyone else's understanding? I've never heard this before.
:thanx:
Stijloor
:thanx:
Yep! The famous "double-check" performed preferably by persons independent from the process. Does not add a lick of value, but the automotive customers have been badly burned quite a few times with nonconforming product including serious labeling issues; hence this requirement. The product audit frequency should depend on the confidence you have in the preceding inspection and test activities.
Stijloor.
A Audit day - Production Planning - Must we be producing product? General Auditing Discussions 14
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
F Product audit sampling plans IATF 16949 - Automotive Quality Systems Standard 3
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
D What are the important things to keep track of in product audit checklist? Software Quality Assurance 3
B Is it necessary to conduct product audit of entire product which is manufactured in the company as per IATF IATF 16949 - Automotive Quality Systems Standard 4
Q IATF 16949 - Product audit - Must each product be audited? IATF 16949 - Automotive Quality Systems Standard 6
U Dock Audits - Isn't waiting to do an audit when the product is "supposed" to ship a little late? Manufacturing and Related Processes 12
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Manufacturing and Product Audit Approach IATF 16949 - Automotive Quality Systems Standard 19
B TS16949 Section 8.2.2.3 Product Audit - Requirements for various Customers IATF 16949 - Automotive Quality Systems Standard 10
K Please share a Product Audit Checklist for a Wafer Fab Document Control Systems, Procedures, Forms and Templates 3
Q Internal Audit of Product Quality Complaint System (21 CFR Part 820) Customer Complaints 9
C TS16949: Product Audit vs. "Regular Checks" Internal Auditing 1
P May I combine the Process Audit and Product Audit into Delphi's LSR? Customer and Company Specific Requirements 3
J Questionable Audit Finding about Revision Levels of Product Manual CD's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Requirement for NB audit with Discontinued Product EU Medical Device Regulations 3
J Product and Process Audit according to ISO/TS 16949:2009 Process Audits and Layered Process Audits 9
S Supplier Audit Questionnaire for aerospace product suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C Anvisa Manufacturer Audit - Product produced at two different Sites Other Medical Device Regulations World-Wide 3
W Definition Product Audit - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
O Product Audit for Rubber Parts for Automotive Industry IATF 16949 - Automotive Quality Systems Standard 3
Q How to Audit the Client Quality System - Product Failure caused by no Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L EN 45011 (European Standard for Product Certification) Audit Checklist needed Other ISO and International Standards and European Regulations 3
A Non-Conforming Product vs. Supplier Audit Finding Supplier Quality Assurance and other Supplier Issues 8
Q Product Audit Check List according to VDA VDA Standards - Germany's Automotive Standards 1
A Seeking: documentation for intrinsically safe product audit General Auditing Discussions 6
A How to calculate the Effectiveness of the Process and Product Audit System Internal Auditing 10
michellemmm Software Product Development Quality Assurance (PDQA) Audit Checklists Software Quality Assurance 12
Q Product Characterization Audit - What is "Characterization" IATF 16949 - Automotive Quality Systems Standard 7
R Product Audit Checklist according to ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 24
D Dock Audit (Product Audits and Process Audits) database wanted Quality Assurance and Compliance Software Tools and Solutions 20
Q What should be Audited in a Product Audit IATF 16949 - Automotive Quality Systems Standard 14
harrysons Product Audit Checklist - Please give some advice or share your opinions Software Quality Assurance 10
A Product Audit - Traceability of Sand used Internal Auditing 8
B What is in a Product Audit? TS 16949 Clause 8.2.2.3 Process Audits and Layered Process Audits 21
K Help in meeting the requirements in 8.2.2.3 Product Audit of TS 16949 IATF 16949 - Automotive Quality Systems Standard 5
I Definition Product Audit vs. Dock Audit vs. Layout Audit - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 29
V Is Product Audit Mandatory as per ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 19
somashekar Product audit for using the safety mark (ETL) on label Other Medical Device and Orthopedic Related Topics 2
Ajit Basrur Process and Product Audit format needed Process Audits and Layered Process Audits 1
R Product Audit Summary Form needed IATF 16949 - Automotive Quality Systems Standard 5
B What is the full name of QKZ in product audit? IATF 16949 - Automotive Quality Systems Standard 8
H Product Audit - TS 16949 Clause 8.2.2.3 IATF 16949 - Automotive Quality Systems Standard 18
K Mock Audit Log Form Template for Product Recall/Return at Food Plant Document Control Systems, Procedures, Forms and Templates 8
P Product Audit looking at Conformity, not Effectiveness General Auditing Discussions 6
C Audit NonConformance - Evidence of Post Market Vigilance and Product Recall. ISO 13485:2016 - Medical Device Quality Management Systems 6
J AS9100 Clause 7.4.3 Verification of Purchased Product (audit Finding) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 30
Q Dock Audit - Reasons to do dimensional checks during product dock audit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Icy Mountain Product Audit Process Requirements - Clause 8.2.2.3 IATF 16949 - Automotive Quality Systems Standard 35
