Product Audit - TS 16949 Clause 8.2.2.3
#12
How did you get to PPAP from this TS requirement? I don't see it.
It used to be called "dock audit" in QS 9000 days, and we treat it as that even today. We pull a lot off the truck and have at it.
It turns out I have full text versions of TS and QS on my home computer so now I will log off and go drink heavily, because it is very clearly time for me to get a life!
Cheers
Caster
Bad OLD Discredited QS 9000 Version
Final Product Audit - 4.10.4.2
The supplier shall conduct audits of packaged final product to verify conformance to all specified requirements (e.g. product, packaging, labeling) at an appropriate frequency.
NOTE: This activity, also known as a "dock audit", is based upon sampling and is generally performed after final inspection but prior to shipment. Where customer PPM requirements are met, the frequency of Final Product Audits may be reduced.
New Improved Way Better TS 16949 Version
8.2.2.3 Product audit
The organization shall audit products at appropriate stages of production and delivery to verify conformity to all specified requirements, such as product dimensions, functionality, packaging and labeling, at a defined frequency.
Not all organizations can get away with just doing a 'dock audit'. It isn't really the intent anyway. I have heard that doing only dock audits has resulted in NC's for not doing them at 'appropriate stages of production'.........
SilverHawk
#13
The SMMT March 2007 newsletter explained the best part of the Product Audit. There are still many good people think that product audits are to be conduct / carry out by QC Inspectors. Most importantly, we cannot reach the clause 8.2.2.3 as it stand-alone on it own but to read in totality with the whole clause 8.2.2.
Raffy
#14
The attachment provided by Howard was very informative. I was totally enlightened with that attachment, because I don’t have the luxury of a formal training in TS16949, that’s why I’m trying my best reading a lot of information about ISO/TS16949, even source out books locally and international, just to abreast with the latest information about TS16949.
Thank you very much Howard for sharing the attachment.:thanx:
Best regards,
Raffy:cool:
Sharon_Noble
#16
We have continued with our Dock Audits, even after the death of QS, however the dock audit doesn't really cover the part of the clause "at appropriate stages of production" We now have product audits incorporated into our production process. The "First Off" produced on a line is subject to an audit by an independant person (usually Supervisor, QA Inspector, or other designated associate) A document follows the product through all processes and on it is recorded conformance/non-conformance to specified requirements. If there is a non-conformance, the production line is stopped until appropriate corrective actions have taken place. The document is used to record the NC, the action, the persons with authority to implement the action, the date of the actions, and then the re-audit to requirements. This sounds like a big thing but actually it could be as small as:
The product label was smudged in process and therefore unreadable
1) Note on form "Label is not readable" Stop process and notify Supervisor
2) If there is an issue with all labels then they are segregated and scrapped and new ones are produced and reviewed for acceptance.
3) New process of creating labels only when product is ready to be cased is implimented. (not days before and sitting around) "Preventative Action"
4) Actions taken noted on form and dated, with supervisors signature. "Authorization"
5) New labels attached, then "First Off" re-audited again to specifications.
6) Note that product now meets specifications, and form is filed with Quality Dept. "Close the Loop"
These are then reviewed as input to continuous improvements, preventative actions, even additional resources or machinary maintanance needed.
We have reduced our Dock Audits (1 shipment/week) based on declining #s of customer complaints but increases our "Product Audits" based on internal compliants. (NCs caught in process)
Since changing our process we have been able to catch alot of "little" issues that would not cause our Customer to create a formal complaint, but over time would probably p*ss them off. We are now able to catch these issues, deal with them immediately, so the next time the product is built we know there wont be any issues.
We also conduct Annual Layouts as required but I don't believe that these could be considered Product Audits as they are, like Dock Audits, not "at appropriate stages of production".
Raffy
#17
Hi ayfergoymen,
In our end, our product audit instruction was incorporated in our Internal Audit Procedure. We create a form to determine what
are the criteria that we should cover.
There are product audit sample available in this forum, all you have to do is browse and search.
Remember...patience is a virtue.
Raffy
hello I need to write a final product audit instruction.Could you please give a sample ?
thanks
howste
Thaumaturge
#18
thanks
If you look at the top of the page there is a green "Post Attachments List" button. It indexes all of the various documents that users have posted over the years. Here's a list of documents that come up with a quick search for "product audit."
http://elsmar.com/Forums/fileslist....tby=filename&pageamt=2&criteria=product+audit
Hopefully one or more of these may be useful to you.
K
KayBee4
#19
Wouldn't using your Control Plan as a check sheet work and align well as a product audit? As opposed to trying to come up with something else?
Maybe I'm oversimplifying the Product Audit process?
Curious if anyone else takes that approach,. - Thanks, KB
Q IATF 16949 - Product audit - Must each product be audited? IATF 16949 - Automotive Quality Systems Standard 6
W Product Audit - It must be a separate and distinct activity (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 4
S IATF 16949 - Manufacturing and Product Audit Approach IATF 16949 - Automotive Quality Systems Standard 19
J Product and Process Audit according to ISO/TS 16949:2009 Process Audits and Layered Process Audits 9
R Product Audit Checklist according to ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 24
B What is in a Product Audit? TS 16949 Clause 8.2.2.3 Process Audits and Layered Process Audits 21
K Help in meeting the requirements in 8.2.2.3 Product Audit of TS 16949 IATF 16949 - Automotive Quality Systems Standard 5
M Iso/ts 16949 Product Audit Auditor Criteria and Qualifications General Auditing Discussions 3
C Audit Differences - Process, Product, Internal? (4 questions) - TS 16949 General Auditing Discussions 7
M Product Audit - Explanation and samples of the report - TS 16949 General Auditing Discussions 53
P TS 16949 Product Realization Audit - Seeking Plan and Questions to ask General Auditing Discussions 4
T Seeking: Product Audit WI (section 8.2.2.3 / TS-16949) Template Document Control Systems, Procedures, Forms and Templates 3
L TS 16949 Clause 8.2.2.3 - Product Audit Frequency IATF 16949 - Automotive Quality Systems Standard 26
I Product and Process Audit Procedure Example for ISO/TS 16949:2002 Process Audits and Layered Process Audits 9
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
F Product audit sampling plans IATF 16949 - Automotive Quality Systems Standard 3
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
D What are the important things to keep track of in product audit checklist? Software Quality Assurance 3
B Is it necessary to conduct product audit of entire product which is manufactured in the company as per IATF IATF 16949 - Automotive Quality Systems Standard 4
U Dock Audits - Isn't waiting to do an audit when the product is "supposed" to ship a little late? Manufacturing and Related Processes 12
B TS16949 Section 8.2.2.3 Product Audit - Requirements for various Customers IATF 16949 - Automotive Quality Systems Standard 10
K Please share a Product Audit Checklist for a Wafer Fab Document Control Systems, Procedures, Forms and Templates 3
Q Internal Audit of Product Quality Complaint System (21 CFR Part 820) Customer Complaints 9
C TS16949: Product Audit vs. "Regular Checks" Internal Auditing 1
P May I combine the Process Audit and Product Audit into Delphi's LSR? Customer and Company Specific Requirements 3
J Questionable Audit Finding about Revision Levels of Product Manual CD's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Requirement for NB audit with Discontinued Product EU Medical Device Regulations 3
S Supplier Audit Questionnaire for aerospace product suppliers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
C Anvisa Manufacturer Audit - Product produced at two different Sites Other Medical Device Regulations World-Wide 3
W Definition Product Audit - Definition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
O Product Audit for Rubber Parts for Automotive Industry IATF 16949 - Automotive Quality Systems Standard 3
Q How to Audit the Client Quality System - Product Failure caused by no Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L EN 45011 (European Standard for Product Certification) Audit Checklist needed Other ISO and International Standards and European Regulations 3
A Non-Conforming Product vs. Supplier Audit Finding Supplier Quality Assurance and other Supplier Issues 8
Q Product Audit Check List according to VDA VDA Standards - Germany's Automotive Standards 1
A Seeking: documentation for intrinsically safe product audit General Auditing Discussions 6
A How to calculate the Effectiveness of the Process and Product Audit System Internal Auditing 10
michellemmm Software Product Development Quality Assurance (PDQA) Audit Checklists Software Quality Assurance 12
Q Product Characterization Audit - What is "Characterization" IATF 16949 - Automotive Quality Systems Standard 7
D Dock Audit (Product Audits and Process Audits) database wanted Quality Assurance and Compliance Software Tools and Solutions 20
Q What should be Audited in a Product Audit IATF 16949 - Automotive Quality Systems Standard 14
harrysons Product Audit Checklist - Please give some advice or share your opinions Software Quality Assurance 10
A Product Audit - Traceability of Sand used Internal Auditing 8
I Definition Product Audit vs. Dock Audit vs. Layout Audit - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 29
V Is Product Audit Mandatory as per ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 19
somashekar Product audit for using the safety mark (ETL) on label Other Medical Device and Orthopedic Related Topics 2
Ajit Basrur Process and Product Audit format needed Process Audits and Layered Process Audits 1
R Product Audit Summary Form needed IATF 16949 - Automotive Quality Systems Standard 5
B What is the full name of QKZ in product audit? IATF 16949 - Automotive Quality Systems Standard 8
K Mock Audit Log Form Template for Product Recall/Return at Food Plant Document Control Systems, Procedures, Forms and Templates 8
